How's your eye?
Short Notice Bypass Repair!
"troyman" wrote: How's your eye?
I looked a lot like Frankenstien yesterday. That's what I get for trying to hug a tree . . . . .
It's a little sore, but is healing pretty nicely now.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"gamfam" wrote: [quote="troyman"]How's your eye?
One little dead tree hits me in the face and then you in the face within 20 seconds. Sounds like a UFC tree!Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: [quote="gamfam"][quote="troyman"]How's your eye?
Should have cut it down and used it to prop up my Jeep!!! - Guest former userGuest former user
"gamfam" wrote: [quote="BKGM Jeepers"]Have you shown your wife the photo yet? 😲
What are you nuts???????
I showed Kelly and she said that she is crossing Stawberry off the list of trails she is willing to run. 😀 I suggested that she just skip riding with George. 😂 Of course, I guess I'm still the only one in the club with a true flop to my name. That sissy stuff Rob and Justin did on the Rubicon only gets half credit. 😂
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Strawberry just keeps racking up the victims. That is one nasty little dirt road 😉
"JohnDF" wrote: Strawberry just keeps racking up the victims. That is one nasty little dirt road 😉
Quit being mean 😈__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - RobD SubscriberRobD Subscriber
So here is the question of the day. Do we need to set up another work day up on the trail to do some more work? I have most sundays off and can be available to do it. I have a chain saw with a 23 inch bar.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"RobD" wrote: So here is the question of the day. Do we need to set up another work day up on the trail to do some more work? I have most sundays off and can be available to do it. I have a chain saw with a 23 inch bar.
Your saw is big enough to cut every tree we need, except one. I am for setting up another work day. We need to cut two trees all the way over on the other side (beyond our trail responsibility limit), and then close the bypass just past the part where we had the winchfest in the snow. That area will require a lot of cutting and dragging. There are a lot of trees up there so it shouldn't be too bad.
Separate note. Lee ground off his Spyder gears in the front end on this last run. So, Strawberry did claim another driver. He is fixed however. Scott at Extreme really helped him out!Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: That area will require a lot of cutting and dragging. There are a lot of trees up there so it shouldn't be too bad.
Shoot...forget dragging them out of the way...I'll get a fire wood permit, bring the truck, and you all can cut firewood for me. 😎 😀 - Guest former userGuest former user
"Bender" wrote: [quote="BKGM Jeepers"] That area will require a lot of cutting and dragging. There are a lot of trees up there so it shouldn't be too bad.
I thought of that but I'm not sure my Excursion would get through Squeeze Rock without adding some serious Sliders.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I'll bring my Tundra. It should make it to the top.
"JohnDF" wrote: I'll bring my Tundra. It should make it to the top.
look at you john, you get a toy and now you think you can go anywhere!!! 😂 😎
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"lowrider" wrote:
Toyotas Rule!!!I used to wheel a lot. . .- Guest former userGuest former user
I'm planning to run this 50-88 this weekend. Is there a tree that needs to be cut/moved? Cause my buddy who is likely coming w/ is a chainsaw nut and has some big saws.
Anyone want to join us?
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"Ox Driver" wrote: I'm planning to run this 50-88 this weekend. Is there a tree that needs to be cut/moved? Cause my buddy who is likely coming w/ is a chainsaw nut and has some big saws.
Have him cut the HUGE tree you go around way up top into 3' sections. We can move it later!
The tree is almost 5' in diameter.
Post some pics when you get it cut up.Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: Have him cut the HUGE tree
Got any pics of it now so we are sure to cut in the right spot.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"Ox Driver" wrote: [quote="BKGM Jeepers"]Have him cut the HUGE tree
You can't miss it if you are going all the way across. It's 5 feet tall on its side, blocks the whole trail, and has a by-pass around it on the right, if heading to 88.
Hope this helps you find it. Again, it's way up top, past V-rock, pinch rock, and the two main water crossings.Kathleen and Brad- Guest former userGuest former user
Ya I'm sure we wont miss the tree if it's that big. I'm just wondering if it is clear where the trail is meant to cross it? I would hate to cut the trail threw and find out we had made a new bypass.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"Ox Driver" wrote: Ya I'm sure we wont miss the tree if it's that big. I'm just wondering if it is clear where the trail is meant to cross it? I would hate to cut the trail threw and find out we had made a new bypass.
It is clear. It sits across the whole trail. If you are unsure about any tree, don't cut it. It's better safe than sorry.Kathleen and Brad- Guest former userGuest former user
Ooooo! 5'! drool.....
I'm set up for around 7' 😀 - Guest former userGuest former user
hytenor or soprano 😂 no avatar?
"hytenor" wrote: Ooooo! 5'! drool.....
Wow! - Guest former userGuest former user
"Bender" wrote: [quote="hytenor"]Ooooo! 5'! drool.....
Wow!
I might go along just to watch! - Guest former userGuest former user
"lowrider" wrote: hytenor or soprano 😂 no avatar?
this more better? 😛
from "Tanhauser" last season.
