2017 Chainsaw Class Dates Announced
    #2613 Dec 2016, 9:22 AM
    kris_olof said
    No problem, just let me know some time after the Jan class and I will bring them to an event.
    Can I barrow one as well for the march class if its still available?
    #2713 Dec 2016, 9:23 AM
    Kris, can I borrow a set of safety gear for the February class?
  3. kris_olof started this Trailmaster Joined: October 2015
    #2813 Dec 2016, 9:35 AM
    Ok, I am posting here to keep track.  I have 3 sets of sawhelmet and chaps.  Again, all are spoken for for the Jan Class
    Feb Class: Jeff R (2 remaining available)
    March Class: Darrel, Mike G (1 remaining available)
    #2913 Dec 2016, 9:40 AM
    kris_olof said Ok, I am posting here to keep track.  I have 3 sets of sawhelmet and chaps.  Again, all are spoken for for the Jan Class   Feb Class: Jeff R (2 remaining available)   March Class: Darrel, Mike G (1 remaining available)
    Hey Kris, some of us responded about wanting to go to these classes a while ago, but never heard a confirmation of our attendance. Can you list whose in for what class?
    Thanks,
  5. kris_olof started this Trailmaster Joined: October 2015
    #3013 Dec 2016, 10:34 AM
    Will do, just wanting to get conformation from Kyle.
  6. Darrell and Jill Subscriber
    #3114 Dec 2016, 1:02 PM
    Thank you!
  7. kris_olof started this Trailmaster Joined: October 2015
    #3216 Dec 2016, 7:54 AM
    So this is who I show and am confirming with Kyle now.
    Jan: 1. Me  2. Abby (will be with me) 3. Andrew (will be with me) 4. Gill  5. Jesse  6. Guy (may have already contacted kyle separately) 7. Bret (maybe) 8. Jeff B (maybe, not clear on what date you wanted)   Feb: 1. Jeff R    March: 1. Darrel  (may have already contacted kyle separately) 2. Mike
  8. Jeff- that guy with the foolsize Subscriber
    #3316 Dec 2016, 11:19 AM
    That works for me.
  9. richfroh Subscriber
    #3417 Dec 2016, 2:53 PM
    kris_olof said So this is who I show and am confirming with Kyle now. Jan: 1. Me  2. Abby (will be with me) 3. Andrew (will be with me) 4. Gill  5. Jesse  6. Guy (may have already contacted kyle separately) 7. Bret (maybe) 8. Jeff B (maybe, not clear on what date you wanted)   Feb: 1. Jeff R    March: 1. Darrel  (may have already contacted kyle separately) 2. Mike
    Kris,
    I don't see my name on the list for the January class. Am I confirmed for this class?
    #3518 Dec 2016, 3:28 AM
    Thanks for all this Kris.  Guy did not get with Kyle. Wasn't sure if it would cause confusion. Do confirm him for Jan!  U rock!
  11. kris_olof started this Trailmaster Joined: October 2015
    #3618 Dec 2016, 5:19 AM
    richfroh said
    Kris,
    Yes you are. I didn't transpose the names over correctly. Sorry
    #3719 Dec 2016, 8:50 AM
    I took the Adult First Aid/CPR/AED Online course from the American Red Cross today. The cost is $25. After you complete the course you can print out your certificate of completion. You can start and stop the course at any time and work on it at you own pace or as time allows. It will probably take between 2 to 5 hours to complete depending on your beginning level of knowledge and experience. It's a little like playing a video game and you have to do things in the proper order or you may fail and have to do the section over again. The online course uses animated tutorials and scenarios and you have to complete each section in all three levels of the first aid and CPR sections. A hands-on class would be more beneficial for someone who has never had formal training but it sounds like the online class is all that is required for chainsaw certificate. A hands on class would be more time consuming.
  13. Mike G Member Joined: October 2016
    #3819 Dec 2016, 9:26 AM
    Jeff_R said I took the Adult First Aid/CPR/AED Online course from the American Red Cross today. The cost is $25. After you complete the course you can print out your certificate of completion. You can start and stop the course at any time and work on it at you own pace or as time allows. It will probably take between 2 to 5 hours to complete depending on your beginning level of knowledge and experience. It's a little like playing a video game and you have to do things in the proper order or you may fail and have to do the section over again. The online course uses animated tutorials and scenarios and you have to complete each section in all three levels of the first aid and CPR sections. A hands-on class would be more beneficial for someone who has never had formal training but it sounds like the online class is all that is required for chainsaw certificate. A hands on class would be more time consuming.
    Hey Jeff R can you send me a link to that online class I would like to get them done before my March class
    #3919 Dec 2016, 1:09 PM
    Mike, try the link below. Put in your zip code and select class category First Aid, CPR and AED then click Search for Classes. I selected the Online class but there are also Online plus Classroom classes for $90 that meet OSHA/workplace requirements. I'm hoping that the Online only one will be adequate for the chainsaw certificate. I did plenty of CPR and medial aid in my days as a firefighter so I'm hoping I (we) don't have to take the Classroom version!
    http://www.redcross.org/take-a-class/cpr/cpr-training/cpr-online
    #4019 Dec 2016, 1:39 PM
    If you have never had training in CPR, the use of and AED (automatic external defibrillator) and first aid, then the online class will take more time and probably isn't the best way to learn the skills. It also might be a little frustrating because the instructional part is brief so you will probably do a lot of trial and error when doing the simulations. The sequence of the steps is often important so if you don't do things in the correct sequence you might fail and have to try it again. Fortunately you can just repeat a section immediately if you fail. In each section you are scored from 0 to three stars. You only need to score one star to pass! Here is a good link if you want to study CPR and AED's before taking the online class but all the information you need for the tests is contained in the online class:
    http://www.wikihow.com/Do-CPR-on-an-Adult
    #4121 Dec 2016, 1:16 AM
    http://www.rescuetraininginstitute.com/
    This is who I have my certification through.  They are located in Folsom.  When I did mine, they have you take an online course and then come in for a few hours for hands on testing.  Pretty easy and straight forward.
  17. kris_olof started this Trailmaster Joined: October 2015
    #4210 Jan 2017, 5:46 AM
    Due to snow at the training site, the Jan 13-14 Class has been Cancelled.
    There is still room in both the Feb and March Class so let me know what date you would like to attend.  I will PM or text you guys and see which dates you want to try and attend.
    This is what I had:
    Jan:  CANCELLED 1. Me  2. Abby (will be with me) 3. Andrew (will be with me) 4. Gill  5. Jesse  6. Guy (may have already contacted kyle separately) 7. Bret (maybe) 8. Rich   Feb 10-11: 1. Jeff R    March 10-11: 1. Darrel  (may have already contacted kyle separately) 2. Mike
    #4310 Jan 2017, 9:35 AM
    kris_olof said Due to snow at the training site, the Jan 13-14 Class has been Cancelled.     There is still room in both the Feb and March Class so let me know what date you would like to attend.  I will PM or text you guys and see which dates you want to try and attend.  This is what I had: Jan:  CANCELLED 1. Me  2. Abby (will be with me) 3. Andrew (will be with me) 4. Gill  5. Jesse  6. Guy (may have already contacted kyle separately) 7. Bret (maybe) 8. Rich   Feb 10-11: 1. Jeff R    March 10-11: 1. Darrel  (may have already contacted kyle separately) 2. Mike
    Move Jesse and I to the Feb. 10-11 class please
    thanks kris
  19. richfroh Subscriber
    #4410 Jan 2017, 1:58 PM
    Please move me to the Feb 10-11 class too.
  20. Jeff_R Member Joined: October 2016
    #4517 Jan 2017, 9:36 AM
    At the last club meeting I believe someone said they are a certified CPR instructor. I have access to some CPR manikins if the club would like to use them. I will know how many I can borrow tomorrow.
  21. Guy and Lynda Member Joined: May 2015
    #4617 Jan 2017, 10:11 AM
    It was Robert who said he was an instructor & he prefers blow-up dolls!
  22. Gilbert & Betty Member Joined: September 2014
    #4717 Jan 2017, 10:13 AM
    Jeff_R said At the last club meeting I believe someone said they are a certified CPR instructor. I have access to some CPR manikins if the club would like to use them. I will know how many I can borrow tomorrow.
    Hey Jeff my brother is a CPR/First Aid instructor.  I'll let him know tomorrow when I see him and give him your contact info 👍
  23. Gilbert & Betty Member Joined: September 2014
    #4817 Jan 2017, 10:14 AM
    Guy and Lynda said It was Robert who said he was an instructor & he prefers blow-up dolls!
    #4926 Jan 2017, 12:54 AM
    Kris, I decided to buy my own safety gear so you can lend the set that I was going to borrow to someone else in the February class. There is a lot more snow down low than there was last month but I'm hoping they don't cancel the class. Maybe they can find a lower location or perhaps the club can just wheel the instructor in!
  25. kris_olof started this Trailmaster Joined: October 2015
    #508 Feb 2017, 4:21 AM
    Due to mud and snow at the training site, the Feb 10-11 Class has been Cancelled.
    They are expanding the March Class to fit everybody and adding a potential class in late march/early april if the March date doesn't work so let me know what date you would like to attend.  Until I hear from you I will put you down for the March class to save you a spot.
    This is what I had:
    Jan:  CANCELLED 1. Me  2. Abby (will be with me) 3. Andrew (will be with me) 4. Gill  5. Jesse  6. Guy (may have already contacted kyle separately) 7. Bret (maybe) 8. Rich   Feb 10-11: CANCELLED 1. Jeff R  2. Me  2. Abby (will be with me) 4. Andrew (will be with me) 5. Gill  6. Jesse  7. Guy (may have already contacted kyle separately) 8. Bret (maybe) 9. Rich
      March 10-11: 1. Darrel  (may have already contacted kyle separately) 2. Mike  3. Jeff R  4. Me  5. Abby (will be with me) 6. Andrew (will be with me) 7. Gill  8. Jesse  9. Guy (may have already contacted kyle separately) 10. Bret (maybe) 11. Rich
      Potential Extra Class: (date TBD)
