My calendar isn't very pretty, but I'd love to squeeze one more run in before winter.
Rubicon? Fordyce? nocibuR?
A saturday day-run - with food and gear for an overnighter just in case - would be ideal.
Aonther run before winter sets in???
Dan-H SubscriberDan-H SubscriberClosed Mondays.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I'd be up for another Fordyce run. Plus, I still owe Rob another crack at the Little Sluice. I'm hoping to get my Jeep fixed some time this week. Maybe this time you'll take a picture of my Jeep π
Dan-H SubscriberDan-H started this SubscriberA day trip to the box would be OK too.
Are you sure I didn't take any pics of your jeep? I took lots of pics of white jeeps. They all look the same.Closed Mondays.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Mine's not as purdy as the rest of yours.
Dan-H SubscriberDan-H started this SubscriberYour rig has an industrial strength appearance.
Closed Mondays.- Guest former userGuest former user
"JohnDF" wrote: Mine's not as purdy as the rest of yours.
I'm honored. π
I may be up for another run. I've got some bugs to work out. My truck was running like junk at the end of the day on Barrett. It wouldn't idle. It hadn't been running well all day and it just got worse. It had these exact same symptoms before and it was a vacuum issue. Plus, my inner seal on my front axle is leaking like crazy. I guess I didn't get the shims right. :? I guess what I'm saying is that at this point, my vehicle is not in good working order and I would hate to violate the club bylaws by bringing it on a run. π
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Sounds like you already violated the bylaws π²
Welcome to the club...You are banished from Strawberry for three years.I used to wheel a lot. . .- RobD SubscriberRobD Subscriber
Fordyce or the Rubicon from Tahoe to Loon.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"RobD" wrote: Fordyce or the Rubicon from Tahoe to Loon.
Tahoe to Loon is a day run I have never done.Kathleen and Brad- Guest former userGuest former user
Something is going on here. π
https://posse4x4.org/forum/viewtopic.php?p=45410#45410 - RobD SubscriberRobD Subscriber
"BKGM Jeepers" wrote: [quote="RobD"]Fordyce or the Rubicon from Tahoe to Loon.
We will need to do it on a week day..No problem to do it as a day run, but the trail is 3 times harder going from Tahoe..__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF Member Joined: July 20033 times harder...does that make the trail a "30" ???
Dan-H SubscriberDan-H started this Subscriber"RobD" wrote: [quote="BKGM Jeepers"][quote="RobD"]Fordyce or the Rubicon from Tahoe to Loon.
nocibuRClosed Mondays.
