anyone discuss a time & meeting place ? :? :rasta:
Barrett run
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Good post. I'm not leading the run but planning to go. I think George did the calendar post.
What time and where? Can we meet at fresh pond Chevron so I can grab a breakfast burrito there?Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: I'm not leading the run but planning to go. I think George did the calendar post.
George put most of this year's events since he was at the meeting when we planned them. Sounds to me like you or Earl are organizing the run. I doubt I'll make it. - Guest former userGuest former user
Well, anyone wanting to meet at fresh pond lets say we'll leave there at 8:30 so be there by then. lets see how many we drum up. 😤 🍺
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I'm planning on going.
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009I'm in IF I can get a new cat and pass smog in time.
The old (new) one is out and I'm returning it today for warranty.
It took six weeks to get that one though. Hopefully I can get another new one quicker.- Guest former userGuest former user
Joe & I are in :rasta:
I should be able to make it. I won't be able to make it to the trail head until ten. I hope Im not be too far behind.
I'm in and so's the co-driver. (not one scratch on these new skids yet)
- JZ Crawler former userJZ Crawler former user
I'm in as well. First timer...
Wow...looks like a fun run with a bunch of newish folks!
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003We need to bring some waivers!
Kathleen and Brad- JZ Crawler former userJZ Crawler former user
Just wanted everyone to know this will be my first "extreme" trail run but I'll try my best to not hold up the group. I'm currently running 33's with a short-arm lift and picking up a CB tonight and recovery straps. I'll be watching closely and taking notes. Any tips or advice is much appreciated...
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003You'll do fine with 33s. You may want to by-pass some of the more "extreme" sections. You'll have a blast...and we'll wait up for you 😀
I used to wheel a lot. . .- JZ Crawler former userJZ Crawler former user
Just picked up a high lift jack on ebay as well. $33 bucks!
"Jamison Zierman" wrote: JAny tips or advice is much appreciated...
You'll be fine on 33s. I know a guy that's crazy enough to try Fordyce on 33s. 😀 Check out the recovery section. of our website. If you don't have good recovery points, this isn't the run for you.
http://wiki.posse4x4.org/Recovery_Points_and_Equipment
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003He's got a Jeep...they come standard with good tow points...as opposed to Toyotas that come standard with power windows 😉
"JohnDF" wrote: He's got a Jeep...they come standard with good tow points...as opposed to Toyotas that come standard with power windows 😉
We have good cup holders too. 😀
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"Bender" wrote:
We have good cup holders too. 😀Okay, that's kind of a good thing 🍺
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"Bender" wrote: [quote="Jamison Zierman"]JAny tips or advice is much appreciated...
I hope I can make this one too. :rasta:
New cat is on order but not sure if it will be here on time.- Guest former userGuest former user
New cat is on order but not sure if it will be here on time.Be a rebel, just go without the cat
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"bobf777" wrote: [quote="kevheb"]
New cat should be here Monday! 👏
Fred SubscriberFred Subscriber"Jamison Zierman" wrote: I'll be watching closely and taking notes. Any tips or advice is much appreciated...
Do you have rocker guards on your Jeep? If not, my advice would be to get some before this trip. I'd also recommend getting an engine skid plate if you don't already have one, particularly if your Jeep has an automatic transmission.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"kevheb" wrote: New cat should be here Monday! 👏
Get it on!
"FAM" wrote: [quote="Jamison Zierman"]I'll be watching closely and taking notes. Any tips or advice is much appreciated...
Thanks. I'm putting on sliders today and installing a CB. My TJ is a 4 cylinder w/ manual trans.
