The 3rd update on results from our rear axle incident, heading to our first snow run, is turning into an improvement, making the best of a bad event. After working with Marc (MCM Motorsports), an agreement has been made to replace the rear axle with a brand new Dynatrac Pro60 axle assembly. The credit for parts & labor to replace the stock assembly was a no-brainer improvement & equitable. An improved, heavier, driveline is also in the deal. By the time the axle shows up & the work is completed, most likely the batteries will be dead, but at least the deal is done & the fix has started. As a side note; Marc backed-up everything he said & will do. He has been reimbursed resulting from the bad pinion shaft bearing, passed it on to me as a part of this agreement. To refute anything to the contrary is wrong. He is a stand-up guy, make no mistake about it.
Stand-by for the improvement updates. Hopefully we be able to make at least one of the snow runs. Thanks for all of your concerns.
