Fordicon V 2.0?
    #2615 Feb 2012, 5:56 PM
    "BKGM Jeepers" wrote: [quote="LJ3"]who knows i might be back up north by then...then it would just be a call in sick day 😁
    Let's hope you can make it. It is one of the more challenging runs. And my favorite.
    One of the more challenging run? It's got to be about the most challenging you can do around here!
  2. RobD Subscriber
    #2715 Feb 2012, 6:09 PM
    Yep, at the pace we run, every weak link you have will break or wear out. I had to replace several joints and a leaking shock after the last trip!
    "Bender" wrote: [quote="BKGM Jeepers"][quote="LJ3"]who knows i might be back up north by then...then it would just be a call in sick day 😁
    #2815 Feb 2012, 7:45 PM
    First time in the black jeep...
    #2911 Mar 2012, 12:56 AM
    both trails in one day? you guys are nuts πŸ˜›
    If in early/mid July I might be in.
    #3011 Mar 2012, 4:22 PM
    The date is set at July 11 and Rob,John and Myself completed this run two years ago in about 12 hours total from airing down to all of us back home.
    We were held up 2 hours on true big sleuce from a broken rig blocking the trail and were held up more than an hour by a very slow group coming down old sleuce that we didn't want to by-pass.
    #3111 Mar 2012, 7:34 PM
    "BKGM Jeepers" wrote: The date is set at July 11 and Rob,John and Myself completed this run two years ago in about 12 hours total from airing down to all of us back home.
    I wonder if my back could take that much punishment in that short a time...after 3 surgeries πŸ˜›
    I only have 3wks during July to play with in the summers so I try to cram as much wheeling in as I can.
    #3217 Mar 2012, 11:49 PM
    I'm a definite maybe for this run πŸ˜€
    #3329 Mar 2012, 3:11 PM
    Ill put it on the calander....7/11 got a interview this weekend up north so might be a reality by then...
    #3429 Mar 2012, 4:19 PM
    "LJ3" wrote: Ill put it on the calander....7/11 got a interview this weekend up north so might be a reality by then...
    Good luck on the interview.
  10. scoped Subscriber
    #3514 May 2012, 12:08 PM
    Is this a run I could go on or is this something I should stay away from?
    #3614 May 2012, 2:13 PM
    It's a pretty fast paced day. If you haven't been on both trails all the way through you might want to sit this one out. Just cause the group probably won't want to wait for you.
  12. BKGM Jeepers started this President Joined: June 2003
    #3714 May 2012, 8:14 PM
    We don't want to stop people from the run.
    Anyone considering running with us here should be comfortable running the rubicon in 4hrs and running Fordyce in 4 hrs.
    We were close to this pace last time we ran it.
    #3814 May 2012, 8:48 PM
    "BKGM Jeepers" wrote: We don't want to stop people from the run.
    hmm, I like running Rubicon in 2 1/2 days πŸ˜›
  14. huck271 Subscriber
    #3914 May 2012, 9:47 PM
    "finder_87" wrote: It's a pretty fast paced day. If you haven't been on both trails all the way through you might want to sit this one out. Just cause the group probably won't want to wait for you.
    I haven't done either trail all the way through. My plan was to mark those off the list this summer. I'm up to try it, I just got to get the 11th off of work. I'm a maybe at this point.
  15. scoped Subscriber
    #4014 May 2012, 10:46 PM
    I have run neither of these trails ?
    #4114 May 2012, 11:01 PM
    "scoped" wrote: I have run neither of these trails ?
    then I would pass.
    #4215 May 2012, 7:38 AM
    For those wondering...
    This is a more 'advanced' run. We are running the two hardest trails in the area back-to-back. Typically it takes people a whole day to run one of these trails at their typical pace. We will be running these trails at an exelerated pace with minimal stopping. To do this, you must know these trails very well and not rely on spotting and rock stacking to get you through. Your rig must also be very well built and fairly large to take the abuse and keep up with the pace.
    There will be other runs on these trails more suited for a slower pace and enjoyment of the trip.
    #4315 May 2012, 7:59 AM
    When you folks do this and hit the river crossing(s) (b/c I've only seen in videos) do you replace your diff oil b/c of water intake? What kinds of "water" protection basics are done, if any?
    I was just curious as I have no idea. No urgency in answering this here if it clutters up the attendance list.
  19. Fred Subscriber
    #4415 May 2012, 9:20 AM
    "Wh1t3Nukle" wrote: When you folks do this and hit the river crossing(s) (b/c I've only seen in videos) do you replace your diff oil b/c of water intake? What kinds of "water" protection basics are done, if any?
    They'll be going fast enough to hydroplane across the water crossings. πŸ˜‚
    #4515 May 2012, 10:00 AM
    I just change my diff fluid once a year...if I'm lucky πŸ˜‰
  21. RobD Subscriber
    #4615 May 2012, 10:23 AM
    Liar! It's more like once a decade 😁
    "JohnDF" wrote: I just change my diff fluid once a year...if I'm lucky πŸ˜‰
    #4715 May 2012, 11:59 AM
    Scoped, we do have an upcoming newbie run to the rubicon that Jeff is putting together. plus there will be plenty of opportunities to run the rubicon this summer.
    #4815 May 2012, 1:31 PM
    "RobD" wrote: Liar! It's more like once a decade 😁
    Well, my Jeep is 10 years old, and I've changed my diff fluid 3 times. So, do the math πŸ˜‚
    #4915 May 2012, 8:41 PM
    When I was wheeling a fair amount I would go through all my fluids/bearings/etc. every winter. That was mainly driven by my front end which would chew the little trunion bearings if I didn't keep on top of them. Ask some of the old timers how much fun I was to be around when I lost the trunion bearings in my cruiser. I promised myself I wouldn't let it happen again.
  25. RobD Subscriber
    #5016 May 2012, 6:07 AM
    Seldom is the water deep enough to worry about water proofing anything. Just check the breather tubes on the front and rear diffs. Make sure they are secure and tight and the tubes run to a high location about 24 inches or more above the diff. Crossing rivers a couple times a year won't do anything. If you run Fordyce 20 plus times a year like me, then the water will start damaging things. I have to tear down my front end a couple times a season to lube the bearings and let everything dry out.
