Fordyce Day Run - August 18th
    #269 Aug 2016, 8:12 AM
    Good luck. I hope you guys make good time without any breakdowns or traffic jams.
  2. Bretjk07 Subscriber
    #279 Aug 2016, 12:40 PM
    Im in!
    #289 Aug 2016, 1:40 PM
    Just an FYI Brett. You are second in line but I should know by tomorrow's meeting.
    Sorry for any confusion.
  4. Bretjk07 Subscriber
    #299 Aug 2016, 3:42 PM
    Ok, just keep me posted thanks!
    #3014 Aug 2016, 6:51 AM
    Ok so we unfortunately have to cancel riding along this trip. It really sucks, i was looking forward to doing a Fordicon run. Maybe next time.....
    #3114 Aug 2016, 1:00 PM
    Brett a seat is available if you'd like.
    Since you and Kevin are more on the 80 side you could coordinate and we will meet in Nyack.
  7. Bretjk07 Subscriber
    #3214 Aug 2016, 3:19 PM
    Ill be there!
    #3314 Aug 2016, 3:23 PM
    Bretjk07 said Ill be there!
    You can ride up to Nyack with me if you want, or head to EDH. We won't be going back to Nyack afterwards.
    #3414 Aug 2016, 11:13 PM
    Yes. Either meet at Kevin's house or my house.  I'll be leaving at 545.  So you'd need to be at my house by 535.
  10. Bretjk07 Subscriber
    #3515 Aug 2016, 12:23 AM
    ok i pm'd Kevin, and if he is good with it i will ride with him.
    #3615 Aug 2016, 9:17 AM
    I'll be up there 19 at nite coming back sunday
    #3717 Aug 2016, 1:16 PM
    Packed and ready! Woohoo! 🥳
    #3817 Aug 2016, 3:10 PM
    k-jeep said Packed and ready! Woohoo! 🥳
    X2!
    #3917 Aug 2016, 10:12 PM
    Good luck, have fun, be safe.
  15. Bretjk07 Subscriber
    #4017 Aug 2016, 11:52 PM
    leaving nyack at 7ish
    #4118 Aug 2016, 12:14 AM
    Bretjk07 said  leaving nyack at 7ish
    Have a good trip. I live off hwy 80 above Auburn so if you have trouble and need something I'm probably one of the closest to Fordyce and I can usually cut out of work if necessary. Post up if you need help like parts or something. I will check this thread throughout the day.
    #4218 Aug 2016, 1:08 AM
    good luck have a great trip be safe
    #4318 Aug 2016, 3:20 AM
    Wish we were there!! Good luck guys!👍
    #4418 Aug 2016, 11:43 AM
    You win again Fordyce! You win again! 😠
    My losing streak continues with this trail. Although, I have been able to get out every time. 😮‍💨
    After a first bad line and getting strapped off a rock, I did cruise up Winch Hill 1, so that's gotta count for something. 👍
    So I think it all started when my hydro assist, which was attached to the 1/4 inch thick steel track bar bracket, bent the bracket and eventually broke it off the axle. Before breaking off the axle, I believe this stressed the track bar causing it to break. With no track bar, I believe this stressed the upper control arms causing them to break. Good thing I got the winch because I ended up wrapping a tree saver strap around the diff and axle and cinched it down with the winch. Without that I would have been spending the night on the trail.
    Oh, and Brett's front axle u-joints came loose as well.
    When are we going again?! 😀
  20. Guy and Lynda Member Joined: May 2015
    #4518 Aug 2016, 11:44 AM
    Well everyone, we made it out of Fordyce in one piece. Kevin had a variety of issues that cripled his Jeep to a point where straps, duct tape & a tree hugger was used to eventually lead to a sucessful end, meeting a tow truch at Cisco Grove.
    What made me proud of our club more than anything else was the folks who did or was willing to step up to the plate to do whatever was necesssry to help on a workday yet!
    Thank you all for your kind thoughts & help.
    #4618 Aug 2016, 12:48 PM
    I'm glad everyone is off the trail and safe.  Sorry I wasn't on the forum till this evening.
  22. Sharkbyte Subscriber
    #4718 Aug 2016, 1:21 PM
    k-jeep said You win again Fordyce! You win again! 😠 My losing streak continues with this trail. Although, I have been able to get out every time. 😮‍💨 After a first bad line and getting strapped off a rock, I did cruise up Winch Hill 1, so that's gotta count for something. 👍 So I think it all started when my hydro assist, which was attached to the 1/4 inch thick steel track bar bracket, bent the bracket and eventually broke it off the axle. Before breaking off the axle, I believe this stressed the track bar causing it to break. With no track bar, I believe this stressed the upper control arms causing them to break. Good thing I got the winch because I ended up wrapping a tree saver strap around the diff and axle and cinched it down with the winch. Without that I would have been spending the night on the trail. Oh, and Brett's front axle u-joints came loose as well.  When are we going again?! 😀
    Kevin,
    When I was picking up your parts today at Metal Cloak the guy asked if you were running Hydro assist.  I told him that you were.  He said that they have had a number of similar situations as yours with the track bar bracket giving way.  In particular if they are the bolt on type.  He said they have to be welded and heavily reinforced.  I told him you were running 60 axles and then he put it together as to who you were.   They said that once that bracket goes it throws everything else off and stuff bends and breaks.  So unfortunately, your assessment of what happened is consistent with what they believed to be the cause.  What is really amazing is that those guys at Metal Cloak stand behind their products even if they don't believe they gave cause for the failure.  It certainly gives me cause to think about them when I decide to upgrade my lift kit.
    I learned that they are having an open house this Saturday from noon to ?  I just might take a ride over there and check it out.
  23. Darrell and Jill Subscriber
    #4818 Aug 2016, 1:59 PM
    Sharkbyte said
    Kevin,
    Sharkbyte said
    Kevin,
    I think I will run over there to check it out as well.
    #4918 Aug 2016, 2:23 PM
    Jeff and I will be there at metal cloak also on Saturday.
    Sorry about the trouble today Kevin.  Fordyce seems to treat me the same way.
  25. richfroh Subscriber
    #5018 Aug 2016, 2:26 PM
    I just got on the forum and read about Kevin's problems. I'm glad everyone is back home safely.
    I do think Jeff R is responsible! He jinxed the trip by mentioning having trouble and needing parts.
    Kevin, are you going to have a work party to get your rig back together?
