January 22nd Crystal Basin Snow Run
    #2620 Jan 2011, 7:20 AM
    "RockinCrawler" wrote: [quote="GonZo"]Was hoping to make this run, but picked up a really bad vibration and noise in the rear end on the last snow run. 45 mph is max speed before it sounds like it is going to explode. 🙁
    U-Joint?
    I plan to make this one with my broken front diff.
    Check out the Basic Requirements on the About Us section of the main page. Going wheeling in 2wd is one thing, going without a working front locker may be another. We all keep learning more about our rigs weak points the more wheel them. I believe we have all had to pass-up on events due to vehicle issues. Maybe you could post with a " what do you think " to get input from others to help decide what is ok or not.
    #2720 Jan 2011, 9:47 AM
    Richard, are you seriously contemplating the trip with a 2WD vehicle?
    #2820 Jan 2011, 11:40 AM
    Got the rig fixed last weekend. But have been sick all week. So I am still not going.
    Scott, glad you reconsidered bringing your chili on the snow patrol run, I like me some hot chili and am looking forward the the BURN!! 😏
    #2920 Jan 2011, 11:41 AM
    Richard PM sent.
    #3020 Jan 2011, 12:38 PM
    "GonZo" wrote: Got the rig fixed last weekend.
    What was the problem?
    #3120 Jan 2011, 12:42 PM
    "Bender" wrote: [quote="GonZo"]Got the rig fixed last weekend.
    Not a 100% sure, but think it may have been snow and ice lodge in a wheel. Because when I test drove it down here, there wasn't an issue anymore. Did do some other maintenance to it do to looking around for the problem. 😉
  7. Fred Subscriber
    #3220 Jan 2011, 1:04 PM
    "GonZo" wrote: [quote="Bender"][quote="GonZo"]Got the rig fixed last weekend.
    Must be one of those problems that only happen when its really cold outside. 😂
    #3320 Jan 2011, 1:12 PM
    #3420 Jan 2011, 3:11 PM
    Any problem that fixes itself that easily is my kind of problem!!
    #3520 Jan 2011, 4:07 PM
    "Bender" wrote: Any problem that fixes itself that easily is my kind of problem!!
    It didn't go away, it will just completely break at a more interesting time 😏
    #3620 Jan 2011, 4:15 PM
    So I re-wired my rear locker to work on my front axle. It works great! Now, it won't dissengage - not so great. Any ideas?
    #3720 Jan 2011, 4:24 PM
    "BKGM Jeepers" wrote: So I re-wired my rear locker to work on my front axle. It works great! Now, it won't dissengage - not so great. Any ideas?
    I'd start with "un-re-wiring" it. Clever concept for the JK though, have others done that?
  13. Fred Subscriber
    #3820 Jan 2011, 4:28 PM
    Cut the green wire. Or is it the red wire?
    #3920 Jan 2011, 4:32 PM
    Turn your hubs out...problem solved 😁
    #4020 Jan 2011, 5:06 PM
    Is the solenoid releasing and the locker staying locked?
    #4120 Jan 2011, 8:01 PM
    Fred, I cut both.
    The solonoid did dissengage but the locker won't release. My thinking is that it's kind of sticking because it hasn't been used in 2 years. Driving may free it up. We'll find out saturday. If not, the ride will be dangerous but the 38's will come sooner...
  17. Anonymous former user
    #4220 Jan 2011, 10:06 PM
    Drive backwards?
    #4321 Jan 2011, 8:28 AM
    "BKGM Jeepers" wrote: If not, the ride will be dangerous but the 38's will come sooner...
    Dangerous? Why? Real men don't disengage their lockers... wait, maybe that's backwards. Either way, I wouldn't call it dangerous, but it's definitely different. 😏 You'll learn to steer with the gas pedal. 😀
  19. BKGM Jeepers started this President Joined: June 2003
    #4421 Jan 2011, 8:50 AM
    Steering withthe gas pedal? I like the sound of that but may need some training.
    #4521 Jan 2011, 9:19 AM
    So your saying we can look forward to your tires chirping all the way up there 😁
  21. Anonymous former user
    #4621 Jan 2011, 12:04 PM
    "RockinCrawler" wrote: Drive backwards?
    Seriously, drive backwards a few hundred feet, it may unbind and release.
    #4721 Jan 2011, 8:21 PM
    Jeep is ready! 😁
  23. RobD Subscriber
    #4821 Jan 2011, 8:24 PM
    Jack up the rear of your jeep to un-bind the gear teeth. Rotate one tire forward then backward several times to to see if the teeth will unlock. Also check the wires at the difff to see if one of the wires is getting power from somewhere other than your switch.
    #4922 Jan 2011, 5:57 PM
    Anyone heard from this crew yet?
  25. Fred Subscriber
    #5022 Jan 2011, 6:19 PM
    I hope there wasn't a catastrophic chili incident 😲
