Hi,
What exit number is the Fresh Pond exit?? :hack:
Maintenance Run
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003We aren't meeting at fresh pond. Check out the thread in the strawberry section...
viewtopic.php?f=26&t=4858I used to wheel a lot. . .- Guest former userGuest former user
I'm not sure. But you'll be there alone if you go all the way to Fresh Pond.
We're splitting into two groups which means Pollock Pines is a better meeting place from this run. One group will enter the North Entrance, the other will enter the South entrance, we'll be meeting at the Shell Station/Subway In Pollock Pines.
Take the Sly Park Exit (second Pollock Pines exit), turn left to go under highway 50, right at the stop sign, then immediately left in to the east lot of the gas satation (Subway side).
We're meeting there at 8:30, leaving at 9am. See you there!!!
