OK, I will DEFINITELY be out at PC this Thursday. Now way going to MET without a full "shake down". There is no set time as yet ... probably wait for the sun to come up for a bit before going out.
This will be a rain, sun, snow, mud, WHATEVER test of the XJ.
Prairie City on 1/31/13
Tom SubscriberTom SubscriberIf you do not change direction, you may end up where you are heading -- Lao Tzu- Guest former userGuest former user
wat time on thursday
depending on recovery of surgery pain i may be there
better 2 vehicles than one
i also have a free pass
Tom SubscriberTom started this SubscriberWell, that works!
Let's hold off an a specific time until we see who else might want to join us. I'm off Thursday but I do need to be "shorn" at 0800.
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberI can swing out after work. No idea when that would be though.
Tom SubscriberTom started this Subscriber"Path 88" wrote: I can swing out after work. No idea when that would be though.
When would you know? Thursday morning? When you return from a drop and there are no more loads?
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberYep. It would be that kinda thing.
Tom SubscriberTom started this SubscriberOK, it's looking more and more like PC will be around the noon hour or a bit later.
Depending on fun factor, etc no telling how long I, myself, will be out there. If I had to guess, it'd be a while. π
As always, I'll be monitoring CB channel 10.
I'll be watching for your actual time.
im not loading recovery gear
took all i had to switch tires
ill leave around noon be there by noon30
ill bring go pro
The current state of my truck!Does not look Offroad ready yet.
You should have dropped that Sterling rear end in there. π
scoped Subscriberscoped SubscriberI should be out there
- will update if not- Guest former userGuest former user
still leaving around noonish
yellow tj
i think nephew is in black yj
Tom SubscriberTom started this SubscriberI'm headed out about 1230, should be there 1-ish. Should be a beautiful day.
scoped Subscriberscoped SubscriberBah - no can make it
I left Tom w/ it running great!
Tom SubscriberTom started this SubscriberSUCCESS!! All is working well.
Thank you Carl and Ray for spotting and pics.
as soon as kayla has a chance ill have her upload
