Rubicon oct 20-21
    #118 Oct 2012, 4:21 PM
    Running the Rubicon this weekend Sat and Sunday. Let me know if you are interested.
    The goal is to be on the trail early and get to the springs day 1 out to Tahoe day 2.
  2. huck271 Subscriber
    #218 Oct 2012, 6:14 PM
    Whst time Sat? I might be up to run the first bit and exit Wentworth. Can't camp this weekend.
    #318 Oct 2012, 6:34 PM
    "huck271" wrote: Whst time Sat? I might be up to run the first bit and exit Wentworth. Can't camp this weekend.
    I want to start early we plan on going all the way to the springs first day. Leaving Sacramento about 6 am hope to be on the trail about 8:30-9
  4. Josh Subscriber
    #418 Oct 2012, 9:57 PM
    Very interested! However, I have soccer games to attend. Thanks for posting it up though. Have fun!
  5. huck271 Subscriber
    #518 Oct 2012, 10:24 PM
    "Pjohn" wrote: [quote="huck271"]Whst time Sat? I might be up to run the first bit and exit Wentworth. Can't camp this weekend.
    Hmm... I may be a little later than that. If I come I may have to catch up to you. I was planning on starting about 9:30-10a that way I can be off and heading home by 2ish.
    Let me think about this and get back to you.
  6. Josh Subscriber
    #621 Oct 2012, 8:53 PM
    How was the trail Jonathan?
    #721 Oct 2012, 9:36 PM
    "Josh" wrote: How was the trail Jonathan?
    We had a great time.
    It's been tamed down in some sections. About 10 feet of the little sluice was difficult to navigate. The decent after little sluice have been tamed as well the crevice has been filled and the big boulder in the middle moved. Some sections of the trail are wider now. There is only 1 path through Buck now. Big sluice has some major changes the left turn that use to be off camber around the big boulders is now flattened to almost 0 camber. The squeeze between the boulder and rock is still there but you can opt to go to the right of it. Rocks have been piled so the drop isn't big. The next squeeze after that the tree is no longer there. The right turn up Cadillac hill has been flattened out a little but the rest of it is unchanged.
    Not sure if this is what you asked but 🙂
    #822 Oct 2012, 9:06 AM
    Thanks for the update Johnathan. Did they shut off the slabs and old sleuce is the only trail now? Or are both options still available?
    #922 Oct 2012, 9:09 AM
    Glad you had a good time, good report.
    #1022 Oct 2012, 10:35 AM
    "BKGM Jeepers" wrote: Thanks for the update Johnathan. Did they shut off the slabs and old sluice is the only trail now? Or are both options still available?
    The bypass that is directly above little sluice I seen someone run I am no sure about further left of that. The decent after Little Sluice is now 1 path.
