Meeting at Fresh Pond at 08:00 leaving at 08:30.
Bring gloves and loppers, plus chainsaws, garbage bags, trimmers and clippers.
You can also show up, leave your car at Fresh Pond and grab an empty seat from someone going up.
We'll have waivers for non-club members to sign at Fresh Pond.
See ya there! :rasta:
Strawberry Trail Maintenance Fall Run
Fred SubscriberFred SubscriberStill on Oct. 9?
If so, I'm not on-call so count me in!
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Thanks Sue! I will be there and have at least one open seat!
you lost me on the waiver thing
can you explain wat that mite be for
thankyou
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003The waiver is a disclaimer that holds you responsible for your actions and not the club. It's pretty straighforward. Once you see one it will make sense to you.
"FAM" wrote: Still on Oct. 9?
Hi Fred,
Yes still on for October 9th 😀
JohnDF Member Joined: July 2003- Guest former userGuest former user
"BKGM Jeepers" wrote: The waiver is a disclaimer that holds you responsible for your actions and not the club. It's pretty straighforward. Once you see one it will make sense to you.
no problem being responsible for my own actions
where is fresh pond and or strawberry trail
wouldnt mind going to check out and help
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Fresh pond is on hwy 50 about 18 miles east of placerville. The highway goes from 2 lanes, down to 1. When the highway opens up to two lanes again, there is a Chevron on the right. That is freshpond. The Strawberry pass trail is located off 50 at the 42 mileston bridge. Hope to see you there!
thank you
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberI will be there 😁
Tom SubscriberTom SubscriberSounds like a plan. Having not been on that trail before, will my open diff XJ have any difficulty?
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"TomD" wrote: Sounds like a plan. Having not been on that trail before, will my open diff XJ have any difficulty?
Only one spot will require a strap if you run it uphill. If you come from the other side, you shouldn't have any problems.Kathleen and Brad
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"BKGM Jeepers" wrote: [quote="TomD"]Sounds like a plan. Having not been on that trail before, will my open diff XJ have any difficulty?
This trail is rated Easy by the Posse Trail Rating System. 😁
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Easy? See, another by-laws update! Maybe bump it up to the moderate category?
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"BKGM Jeepers" wrote: Easy? See, another by-laws update! Maybe bump it up to the moderate category?
:hijack:
Actually, I like the idea of updating to make sure current trails listed are in the correct rating and including more local trails in each rating. Maybe a topic for the next meeting?- Guest former userGuest former user
"kevheb" wrote: [quote="BKGM Jeepers"][quote="TomD"]Sounds like a plan. Having not been on that trail before, will my open diff XJ have any difficulty?
Strawberry has whooped me harder than any other trail out there. I'll have to dig out some pictures of the old Cruiser being towed off. 😢
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Strawberry has handed me my butt a couple of times too.
"JohnDF" wrote: Strawberry has handed me my butt a couple of times too.
X2
(beating Alex to it) :rasta: - Guest former userGuest former user
I wont be able to make this run either. guess we will have to talk about my active member status. I will be working for 3 weeks stright starting on the 30th of this month to get a large milestone on my project completed. (Sunset Bridge over I-405) 🙁
Justin SubscriberJustin SubscriberI have to dig up that picture of Alex doing the wheel stand in his 4-Runner up the snow bank a few years back. 😎
I'll be there.
Justin, were you still thinking of bringing your trailer. Even if someone else needs to haul it on the trail. So we can use it for hauling rocks. would really like to fill in the two large holes on the bottom half of the trail.
Tom SubscriberTom SubscriberOK, that being the case I may have as many as 2 open seats when we go up ... depending on whether or not my son wants to "work" on one of his days off.
I ran Strawberry two weeks ago and hopped right up and over V Rock with my little 33's and a limited slip rear end (Yoda's had been there stacking rocks). Tried it again last week right after a Saturday morning thunderstorm and slid right off the rocks; had to get the high-lift jack out to stack rocks under the tires... I ended up turning around with my tail between my tires.
You just never know about Strawberry
