As may of you know, I bought Rob's Jeep and I need help! My plan it to swap over the axles, transfercase, steering and other goodies to my 06 LJ. Then put the LJ axles on the TJ. This is a lot of work and I would appreciate any help. Thanks in advance!
Where: My House
When: July 1, Sunday, 8:15
Food: We will provide pizza and drinks
Work Party- Project Swaparooni
Josh Subscriber
Tom SubscriberTom SubscriberYup, count me in for a few hours as well.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I'll make it there. I don't want to miss out on seeing Rob's Jeep intact for the last time. I'll be sad to see it gutted, I've spent many an hour under that thing helping to build it up.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012I might be by, but I'm still on DR. restrictions. I can only lift pizza.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"finder_87" wrote: I can only lift pizza.
No problem...You can serve everybody 😁
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I will be there. I don't see a "start" time. Is 9 ok?
Great thanks Guys! I get off work at 8 so lets start at 815. we'll have coffee and goodies.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012"JohnDF" wrote: [quote="finder_87"]I can only lift pizza.
Haha!!
If a pending member buys pizza will they be granted membership for this event?Um...what?- Guest former userGuest former user
Quite the pit crews could be formed here Bill!! Maybe vote John lead on what he is most familiar with. 😎 jk
I'll be there. Livermore park close enough for the kids to go chill over there.
Any aversion to suggesting sandwiches like what Josh did on his Member day? Not that I don't like pizza, just another option so that Greg will have to work a little more. hahahahah
If a pending member buys pizza will they be granted membership for this event?I don't see why not; It's a posted event.
That's a good Idea! The Pending member could bring whatever. I was thinking pizza because it is easy and you can eat it with greasy hands.
scoped Subscriberscoped SubscriberI may be able to stop by for a few hours and help if needed - i just dont know where your house is?
I'm a pending member aren't I ?
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012I believe you are Rick-rock. It's about time you stepped to the cool side!
I live at 200 Luna Cir. Folsom. Sounds Like a party!
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"rick-rock" wrote: I'm a pending member aren't I ?
You are pending member status, as is Johnathan, and Jason from what I recall.Kathleen and Brad
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"rick-rock" wrote: I'm a pending member aren't I ?
I just added you, they need to keep me current on these things 😁
Now, off to find Johnathan's username...I used to wheel a lot. . .- Guest former userGuest former user
I'm in for the work party.
I'm on the sandwiches.
Bill I have four 12 ton jackstands I can bring. They reach 30 inches off the ground. Their the biggest ones Harbor Freight has I believe.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Bill, have you done the frame notching, and built the stub for the rear suspension shock outboard? I know you're working on the rear link set up, but didn't want you to forget that piece. Also, does Rob's TJ still have the upper shock mounts for your rear end set up? What about the standard 4 link rear? Upper track bar mount? It looks like you have a LOT of pre-work, but the end swap should be pretty painless.
Will the PS pump and box (plus ram for the one set up) come out cleanly without disconnecting the lines and re-bleeding everything?
These are some things I could think of....Kathleen and Brad- Guest former userGuest former user
I plan on showing up although with my jeep sleeping away from home the last 23 days and likely not be back in my possession until middle next month my jeep envy may not allow me to show up 😢 . I have 2 6ton jack stands and a jack.
Mystery solved Pjohn is Johnathon! At least I think I am. - Guest former userGuest former user
"rick-rock" wrote: I'm in for the work party.
Rick, sounds like you are willing to do sandwiches? Please bring the jackstands. This is the first I have been able to log in since the round up. I'm trying to plan food and drink for every one.
Attendees:
Brad
John
Carl
Rick
Jeff
Greg?
PJohn
Scoped
I am excited and thankful all of you are willing to come over and help.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012I will be there but not of much use. 🙄
Josh SubscriberJosh SubscriberPlanning to come and help as well Bill. Morning shift.
Tom SubscriberTom SubscriberBill, I'm planning on being there as well. See you at 9:00.
