Need stock JL sport axle w/ 3.45 gears
  1. Brian Subscriber
    #115 Oct 2022, 9:55 AM
    Looking for a stock rear sport axle with 3.45 gearing.
    Trying to pass my o2 sensor. Nothing else is working and dealer/ corporate are blaming the gears and tires.
    So plan is swap in a stock axle and some stock size tires. Make it their problem again
  2. Lynda and Guy Member Joined: June 2021
    #217 Oct 2022, 11:55 AM
    That's awful!! That seems like a lot of work that no one else has to do!  There has to be another solution.
    L\👧
    "No beans!"
    #320 Oct 2022, 8:12 AM
    3.45 gears?  That's a factory ratio?
    Just get any sport rear axle, and remove your front DL.  Then drive it around if that's a problem.
    4.10 is Rubicon stock, so I never learned the other model ratios... Sorry.
    #423 Oct 2022, 2:31 AM
    I tried looking up a solution and came across your rant (I assume it was you) on the JL forum with the guy with the crazy drive cycle. Hopefully you can get it resolved. I use the smog place next to the Quick Quack car wash on Blue Ravine and Prairie City.  My TJ is temperamental but they get it smogged after a couple of tries.
