Help pick between two axles
    #2623 Feb 2017, 11:18 AM
    Jeff_R said    Very interesting to watch the thought process involved here. You guys amaze me with your research and knowledge. I wish I had a fraction of your mechanical skill and knowledge.
    It's all about your internet web wheeling abilities...🥷
    #2723 Feb 2017, 8:46 PM
    No doubt. I must have spent about 10 hours just reading through various threads on the internet.
    #2824 Feb 2017, 12:23 PM
    Only 10 hours?! Amateur! 😀
  4. Brian Member Joined: February 2020
    #2924 Feb 2017, 1:07 PM
    I have spent WAY too many hours web wheelin'
    #3025 Feb 2017, 12:11 AM
    Bit the bullet yesterday... I went up to WFO and wrote them a BIG FAT CHECK.
    They will be doing all the welding and installation for me because I'm a lazy bastard.
    Build list: Spicer Ultimate 60s 5.38 gears, Synergy weld-on track bar bracket, 1350 drive lines, new parking brake cables, HD master cylinder, sPOD switch panel, new Method wheels, and they will inspect all the control arm bracket welds and make sure the hubs are on tight. Am I missing anything Kevin? This Jeep will hopefully be fairly "worry-free" on my little 37 inch tires. 🙂
  6. Josh Subscriber
    #3125 Feb 2017, 12:14 AM
    JohnDF said Bit the bullet yesterday... I went up to WFO and wrote them a BIG FAT CHECK. They will be doing all the welding and installation because I'm a lazy bastard😀
    Maybee we will see your Jeep on a trail soon now!
    #3225 Feb 2017, 12:17 AM
    That's the plan. The wheeling bug has bitten me hard lately.
  8. Josh Subscriber
    #3325 Feb 2017, 12:23 AM
    Awesome! That's good to hear!
    I get bit about once a month. LOL
    #3425 Feb 2017, 1:37 AM
    sounds like really cool stuff coming for Big Red.  👍
  10. Sharkbyte Subscriber
    #3525 Feb 2017, 1:48 AM
    JohnDF said Bit the bullet yesterday... I went up to WFO and wrote them a BIG FAT CHECK. They will be doing all the welding and installation for me because I'm a lazy bastard. Build list: Spicer Ultimate 60s 5.38 gears, Synergy weld-on track bar bracket, 1350 drive lines, new parking brake cables, HD master cylinder, sPOD switch panel, new Method wheels, and they will inspect all the control arm bracket welds and make sure the hubs are on tight. Am I missing anything Kevin? This Jeep will hopefully be fairly "worry-free" on my little 37 inch tires. 🙂
    John
    This build sounds awesome!!!! WFO has done a great job on my Jeep!  Have you had any other work done by them?  I can't wait to see how it turns out!
    #3625 Feb 2017, 2:00 AM
    This is the first time I've been to WFO. But I was impressed when they crawled all through and under my Jeep to check for proper clearances and parts to make sure we could get this done. Shows an attention to detail and inspires confidence. I've always paid to have my own axles installed, personal preference, but have helped several others install theirs. I could do it myself (with help) but I'm tired of hefting heavy axles and laying on the cement for hours at a time. Install date is March 13th...
  12. Sharkbyte Subscriber
    #3725 Feb 2017, 2:32 AM
    Sharkbyte said This build sounds awesome!!!! WFO has done a great job on my Jeep!  Have you had any other work done by them?  I can't wait to see how it turns out!
    John,
    I am sure you are going to be very pleased with WFO.  They really know what they are doing!  Zack is the mechanic that has done all the work on my Jeep.  He works as a mechanic on the Rubicon Trail for the Jamborees.  He has seen it all and knows what to look for.  What I really like about WFO is that they have many years of on the trail experience.  Most importantly, Trevor the owner of WFO, has a very hands on approach to the business and makes sure that whatever they do it is done right and is always there to help you talk through the pros and cons of what you want to do.  Last of all he never try's to up sell you on stuff you don't need.
    WFO is a great shop with great people!
    #3825 Feb 2017, 9:49 AM
    Dang, that moved quickly!
    #3925 Feb 2017, 10:00 AM
    Gregulator said Dang, that moved quickly!
    Have to stay ahead of you 🙂
    #4025 Feb 2017, 4:02 PM
    Looks like you're pretty well covered. Will you be reusing your tie rod and drag link? Did you already upgrade those?
    #4125 Feb 2017, 10:21 PM
    k-jeep said Looks like you're pretty well covered. Will you be reusing your tie rod and drag link? Did you already upgrade those? 👍
    I have all Synergy HD; track bar, tie rod, drag link, and sector shaft brace.
    #4227 Feb 2017, 5:39 AM
    You forgot hydro assist.
    #4327 Feb 2017, 6:55 AM
    Gregulator said You forgot hydro assist.
    Figured I could get by without it for a while with 37s...
    #4428 Feb 2017, 1:05 AM
    You can, but since it's not my money, I would do it ASAP. 😇
    #4517 Mar 2017, 3:06 AM
    We need a status update!
    #4617 Mar 2017, 6:09 AM
    Gregulator said We need a status update!
    The Jeep is in the shop, the axles are installed, and they just ordered the drive shafts. I should have the Jeep back on Tuesday or Wednesday.
    #4717 Mar 2017, 8:39 AM
  23. Josh Subscriber
    #4818 Mar 2017, 2:00 AM
    Cool. How exciting!
  24. Brian Member Joined: February 2020
    #4918 Mar 2017, 2:57 AM
    #5021 Mar 2017, 10:46 AM
    Jeep is done, sort of...
    They called to tell me the Jeep was done and said, "Good news, we didn't use the Synergy track bar mount so that saved you $150.00"
    I didn't spend a small fortune on new axles to save $150.00 on a critical part. I asked them to pull the Jeep back in and weld it on. I can wait an extra day.
    If you know something is a weak point, and the customer deliberately says to upgrade it... wouldn't you want to make sure that it gets done ???😕???
