Help pick between two axles|General 4x4 Discussion|Forum|Gold Hills Posse 4x4
February 19, 2017
4:55 pm
Which axles would you buy?
  • Dynatrac Prorock 60s(29% : 2 votes)
  • Dana Ultimate 60s(71% : 5 votes)
Total Voters: 7
Help me choose between these two axle brands...
Both are about the same money and come with pretty comprable components.
https://www.dynatrac.com/axle-assemblies/jeep-jk-wrangler/dynatrac-axle-sets/serious-performance-prorock-44-60-axle-settm-140.html
http://www.rivercityoffroad.com/Ultimate-Dana-60-Package-Includes-1350-Driveline-p/ud60pkg.htm
6:25 pm
I tried to post a poll, but I "failed" 🙁
I'm getting ready to pull the trigger on one of these axle sets but want to be sure I make the right decision.
Prorock pros: ARB locker option, super beefy brackets and high quality welding, steering included, Dynatrac ball joints, ram assist bracketry, includes an adapter for the parking brakes.
Ultimate 60 Pros: Larger u-joints, larger brakes, comes with drive lines, probably a "slightly" stronger unit besides the locker and welds/brackets.
12:32 am
k-jeep
Parts Unknown
Forum Posts: 2287
Fixed! Had to make a code change in the plugin.
Kevin
February 20, 2017
12:49 am
k-jeep
Parts Unknown
Forum Posts: 2287
Wow, tough choice. 4 years ago that Dynatrac set would have been over $17K. I know because that's what I was quoted at the time for similar specs. Oh, and Currie was only $600 less at the time and required reusing the stock JK brakes. They were both surprised that I wanted 8-lug at the time. Glad there are more options now.
Kevin
February 20, 2017
6:40 am
Thanks for fixing the poll Kevin.
I know, it's a tough choice for sure. I don't think I could go wrong with either set, which makes it tougher.
I do have a question about wheels though. Will I be able to run 17" wheels with the Dana's bigger brakes? Because I will have to keep my 37" tires for a while.
7:35 am
Forum Posts: 3113
You can use most 17" wheels...Some do not clear.  I know Trailready, Walker Evans and KMC or ATX beadlocks will clear the larger brakes.  But I have heard of wheels not fitting too.
12:16 pm
k-jeep
Parts Unknown
Forum Posts: 2287
It may depend on the backspacing with 17s. I have 18s with 4.5BS and don't think that same wheel would fit in 17s with the same BS and tape weights. I'd have to measure to confirm.
Kevin
February 20, 2017
2:51 pm
Questions: If I go with the UD60s
1. What else will I need besides the drive lines and brake lines that come with it.
2. Can the lockers be wired to the factory dash buttons? I know it's not the best but it would be cool.
3. Is there any short-comings (weaknesses) that I need to be aware of with these axles?
4:35 pm
kris_olof
Forum Posts: 1220
Looking at the details on the prorocks that is a really tough one. I voted for UD60s for two reasons. 1 inner Cs are larger, and 2 brake parts can be had at any parts store.  Note I voted this way assuming you are keeping this rig forever and thus servicing with be your problem.
February 20, 2017
5:35 pm
Good insights.
5:36 pm
That's my biggest problem with the UD60s right now, everybody lists beadlocks that will fit and I don't want to pony up for beadlocks. That would add significantly to the cost. I'm having a hard time finding 17 inch wheels that will work with these axles.
11:26 am
Forum Posts: 3113
1. They don't come with brake lines, that is a separate purchase.
2. I heard they can be wired to the factory switches but I've also heard they can be tricky.
3. Front track bar bracket.
My suggestion would be to call  Marcus at River City Off Road or Northridge 4x4 and ask them for details.  They have done the swaps themselves on several rigs and can get you all the info you would want.
4:22 pm
kris_olof
Forum Posts: 1220
Thanks for the info Greg.
I've been on the phone with WFO and they said I shouldn't have a problem with getting non-beadlock wheels to fit.
One more question... Do you forsee any problems with these axles being installed on a short arm lift?
That is a question best directed at Kevin since he has the UD60s and a Metal Cloak short arm kit.
February 21, 2017
5:08 pm
The price to get this done is climbing higher than I expected. I'm up to $20,000+. A little more than I was expecting. I may need to save for a little longer to get it all done.
The plan: UD60 axles, reinforce all the brackets and replace the track bar bracket with the Synergy unit, 4.5" Synergy long arm upgrade, hydro steering, 1350 drive lines, fender trimming, 17 inch trail ready beadlocks, and 40 inch Toyos.
Until then I'll throw some quality shafts in my axles to get me out on the trails.
6:11 pm
Josh
Forum Posts: 1630
Caution. It just keeps climbing!
Its an investment in fun! Yolo
6:19 pm
Maybe I'll take my wife out wheeling, hammer it up a ledge, break all my junk, take forever to get off the trail, and say, "was that worth saving $20,000" 🙂
7:00 pm
kris_olof
Forum Posts: 1220
Not to throw more fuel onto the fire that is your wallet but Tom Woods just released a 1410 CV if you want to go even bigger.
February 21, 2017
9:39 pm
k-jeep
Parts Unknown
Forum Posts: 2287
If you want to go UD60s AND get on the trails now, you just need axles w/parking brake lines, drive lines, and wheels (keeping the 37s for now). What are the specs on the Trail Ready wheels, and can you find a similar spec non-beadlock for less?
I ran for a year without hydro. Even did a Rubicon day run with the stock tie rod and drag link on the UD60s. I also run hybrid 1310/1350 drive lines which, at the time, saved around $300-$500 (can't remember exactly) from DLSac.
Also remember, my brackets broke attempting a Fordicon run. Although, reinforcing them should be one of the least expensive items. We have welders in the club (people and equipment). 🙂
My suspension is not a long arm so no issues there.
Kevin
February 22, 2017
5:05 am
I know, I appreciate all the help you guys have given me.
I'm still crunching the numbers and will figure out a way to get it done.
I know I'm going to do it, it's just scary spending that much money.
8:44 am
Found some wheels that should work. They are Method brand and have 4.5" backspacing and a 131mm hub bore.
7:17 am
Forum Posts: 3113
Think of all the money you will make selling your stock stuff!!
7:37 am
I'm going to get this DONE in the next few weeks. Thanks everybody for helping me make up my mind. I think the UD60s are the best option for me.
I will make sure all the welds are inspected, the track bar mount is replaced with a heavier unit, and make sure the hubs are tight. Am I missing anything?
8:42 am
k-jeep
Parts Unknown
Forum Posts: 2287
Cool! When you get them I can help point out what to look at. thumbs-up
Kevin
February 23, 2017
4:51 pm
Josh
Forum Posts: 1630
Awesome! Can't wait to see the finished build!
6:06 pm
Forum Posts: 2003
Very interesting to watch the thought process involved here. You guys amaze me with your research and knowledge. I wish I had a fraction of your mechanical skill and knowledge.
Most Users Ever Online: 472
Guest(s) 5
Gregulator: 3113
Jeff_R: 2003
Gilbert & Betty: 1446
Members: 143
Topics: 4468
Upcoming: Guy and Lynda, Mike G, ironskullfab@gmail.com, Eric and Dawn
