JohnDF's JKU
    #15130 Dec 2015, 12:26 AM
    Still left to do:
    Fire extinguisher
    CB Radio (had one but Jeff stole it)
    Install new tie rod
    Install rocker guards
    Winch and winch plate
    Regear diffs to 4:88s
    #15230 Dec 2015, 1:28 PM
    Chop shop in Dixon has a $999 gear install special for jks.
    #15330 Dec 2015, 2:15 PM
    Build party!!!
    πŸŽ‰
    #15430 Dec 2015, 10:47 PM
    Chop Shop?
    #15531 Dec 2015, 6:39 AM
    http://chopshopoffroad.com
    #15631 Dec 2015, 7:09 AM
    Awesome! How do I find out about the gear special?
    #15731 Dec 2015, 10:17 AM
    Tell them you were listening to the High Sierra 4x4 Podcast and heard them mention the $999 gear install special. πŸ˜‰ They are a good group of guys.
    #15831 Dec 2015, 10:46 AM
    Tell them you were listening to the High Sierra 4x4 Podcast and heard them mention the $999 gear install special. [https://posse4x4.org/wp-content/sp-resources/forum-smileys/winking.png] They are a good group of guys.
    Awesome! Thanks.
    #15931 Dec 2015, 12:31 PM
    No worries, I plan to use them for my gear install when I get the mulla saved up. I tried to get OTRT to price match, but they couldn't come close.
    Side note though, the $999 includes the gears, install kit and labor. They will charge extra for the gear oil.
    If you need any feedback, Brett used them for his re gear.
    #1601 Jan 2016, 7:20 AM
    I have an extra fire extinguisher you can borrow until you find one you like. Let's get the Red Beast on the trails! 😈
    #1611 Jan 2016, 9:47 AM
    I have an extra fire extinguisher you can borrow until you find one you like. Let's get the Red Beast on the trails! [https://posse4x4.org/wp-content/sp-resources/forum-smileys/devil.png]
    Yeah bring on the Red Beast πŸ™‚
    #1624 Jan 2016, 6:34 AM
    Thanks Greg!!!
    I take my Jeep to the Chop Shop for new gears on Saturday.
    I'll pick it up the Saturday after that. Now the big question...
    Do I go 4.88s or 5.13s with my manual transmission and 37" tires???
    I was pretty set on 5.13s, but the guy at Chop Shop is trying to talk me into 4.88s for my setup. Said he will do either one, but says the 4.88s are preferred for manuals with 37s. Hmmm...
  13. Guy and Lynda Member Joined: May 2015
    #1634 Jan 2016, 8:35 AM
    Thanks Greg!!!
    John, for what it's worth, we just had 5:13s put in with 37" tires and it seems to be working nicely. We did have 4:56s with the 37s and it was too high. Silver is a manual as well.
    #1644 Jan 2016, 9:13 AM
    Guy and Lynda said John, for what it's worth, we just had 5:13s put in with 37" tires and it seems to be working nicely. We did have 4:56s with the 37s and it was too high. Silver is a manual as well.
    Thanks for your input. I've been researching this for hours and it's driving me crazy. Most shops say 4.88s while most internet posters are torn between 4.88s and 5.13s. Maddening...
  15. Guy and Lynda Member Joined: May 2015
    #1654 Jan 2016, 9:35 AM
    John, if driving our Jeep would help, please do so anytime.
    #1664 Jan 2016, 9:55 AM
    Is yours a manual or automatic?
    #1674 Jan 2016, 10:26 AM
    I'm running 5.38s with 38" tires and think it rides great. I easily cruise in 6th gear at around 60mph and up on flat and mild hills. 5th gear for the steeper hills on the freeway heading to the mountains. Did the Rubicon day run without issue running the 2.72:1 t-case as well (a few stalls here and there).
    #1684 Jan 2016, 11:41 AM
    Manual with 5.13s and I have 40s.
  19. Guy and Lynda Member Joined: May 2015
    #1694 Jan 2016, 11:50 AM
    John, we have a manual
    #1704 Jan 2016, 12:02 PM
    See, it's all over the place; 5.13s with 37s and 40s, 5.38s with 38s.
    I guess I need to drive Guy and Lynda's...
  21. Josh Subscriber
    #1714 Jan 2016, 12:35 PM
    I run an automatic with 5.13 with 37's. Runs great for me.
    #1724 Jan 2016, 1:27 PM
    I wouldn't go 4.88s. I plan to do 5.13s or 5.38s when I do gears. What do you like when your offroad? Crawling like a Toyota or speeding through?
    Have you seen this chart?
    http://www.google.com/search?q=jk+gear+chart+3.6&client=safari&hl=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwievLuh95HKAhUW9WMKHW54D3cQ_AUICCgB&biw=1024&bih=672#imgrc=eJ7eaJZXdABFoM%3A
    #1734 Jan 2016, 1:43 PM
    I'm thinking 5.13s, it was my original thought before the Chop Shop guy put 4.88s in my head. Seems to be working well for others.
  24. scoped Subscriber
    #1744 Jan 2016, 4:12 PM
    Do 5.13s the only down fall to them over the 488s is over a year you will spend 15 dollars extra in gas when street cruising but will be slightly better off road and If you ever did go bigger on the tire just that much better.
    If I could fit something in the mid to high 5s in mine I would but first off they don't fit and I was also stuck with the 4 speed slush box by the wife and have a 1980s Era type motor. Not that appropriately set up 3 pedal, quad cam, real interior piece of equipment you have
  25. kris_olof Trailmaster Joined: October 2015
    #1755 Jan 2016, 2:31 AM
    Probably because they are flat landers out in Dixon where everything requires at least an hour and a half on the freeway to access. If this is a weekend rig and not a daily driver or you commute isn't a half hour on the freeway then 5.13s are the better choice. The 4.88s make more sense for daily freeway use and are also a stronger gearset than 5.13s in an engineering sense. Based on the number of people running the 5.13s trouble free the strength issue seems to be irrelevant.
