Coffee's Brewin' 😎
Rubicon Roundup 2010
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I used to wheel a lot. . .- Guest former userGuest former user
Have fun gents. While the Jeeps are away, the Toyota's will play (on the internet). 😂
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Didn't get home until 11:30 😲
Expect a full write-up from KEVIN 😂 (I volounteered him) 😂
BTW, there was no carnage on the Sunday portion, except a couple of slashed sidewalls.I used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: Didn't get home until 11:30 😲
BTW, there was no carnage on the Sunday portion, except a couple of slashed sidewalls.i thought the kevlar was supposed to help with that problem? 😉
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003The tires that got cut were not Kevlar. They were both old style MT/Rs.
Both Bill and I cut our tires on the same rock 😈I used to wheel a lot. . .
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Fun run. A few scars but made it out in one piece.
Here's my write-up...
"Wicked awesome!"
I'll post pics soon.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"kevheb" wrote: Fun run. A few scars but made it out in one piece.
"Wicked awesome!"
I'll post pics soon.Nice write-up...you're fired 😈
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"JohnDF" wrote: [quote="kevheb"]Fun run. A few scars but made it out in one piece.
"Wicked awesome!"
Never be good at anything you don't want to do. 😏
Fred SubscriberFred Subscriber"kevheb" wrote: [quote="JohnDF"][quote="kevheb"]Fun run. A few scars but made it out in one piece.
"Wicked awesome!"
If you're not careful, we'll vote you in as the next Trail Master so you can get more practice
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"FAM" wrote:
If you're not careful, we'll vote you in as the next Trail Master so you can get more practiceI like Fred's way of thinking 🍺
There are some photos in my gallery of the trip. Under Rubicon 2010
http://gallery.me.com/robertdellinger
Fun trip. You will see a lot of straps and winches in the photos 😁__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Can't wait for a report from the other half of the group. I wonder if they ever found CJ Joe?
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"JohnDF" wrote: I wonder if they ever found CJ Joe?
Or the bear. 😁
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Still not back yet. I wonder if they went back down and ran Old Sluice again?
Justin SubscriberJustin started this SubscriberI'm home safe. 😀
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Here's my pics...
http://pics.posse4x4.org/v/20100718KH/- Guest former userGuest former user
Somebody had better write up something or us web wheelers are going to go nuts!
Made it home with out a problem. Had a great time! Thanks for everyone's help. I hope goodyear will warranty the tire. We will see.
P.S. Rob and Kevin the pics are great! - RobD SubscriberRobD Subscriber
If your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
"lj4x4" wrote: Made it home with out a problem. Had a great time! Thanks for everyone's help. I hope goodyear will warranty the tire. We will see.
P.S. Rob and Kevin the pics are great!__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - Guest former userGuest former user
"RobD" wrote: If your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
[quote="lj4x4"]Made it home with out a problem. Had a great time! Thanks for everyone's help. I hope goodyear will warranty the tire. We will see.
Great info. I originally got the tires in Rocklin so that is where I will go. Thanks again for all your help. I think rock tossing should be an olympic sport...... - RobD SubscriberRobD Subscriber
That is probably the one I use if t is the one on Taylor rd.
"lj4x4" wrote: [quote="RobD"]If your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
Great info. I originally got the tires in Rocklin so that is where I will go. Thanks again for all your help. I think rock tossing should be an olympic sport......__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - Guest former userGuest former user
Great info. I originally got the tires in Rocklin so that is where I will go. Thanks again for all your help. I think rock tossing should be an olympic sport......now you really mad eme jealous.. 🙁 rock tossing and new tires.... 😢 😢 😢
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003The Rocklin GoodYear has really went downhill. I just got back from that store. Yesterday I dropped off my beadlock (ring removed), slashed tire, and replacement tire. They were just supposed to pull the bad tire off and put the replacement tire on (inner bead only) and call me when it was done. No call, so I drove down there today. They had both beads set on the tire and it was inflated (no beadlock ring). I tried to explain to them that the outside bead could not be set. Anyway, a half hour later, and watching them like a hawk, they got it right. That place is useless. They didn't even pull off the bent and mangles balance weights.
Justin SubscriberJustin started this SubscriberSwimming in Spider Lake at night was AWESOME!!! The water was the perfect temperature after a long day on the trail. We all went for one more swim Monday morning before wheeling out.
Thanks again to everybody for stacking rocks and running winch line for me. I must have lost my wheeling mojo. 😢 I had to get strapped once and winch once.
oh yeah........Good Year in Rocklin sucks!
Fred SubscriberFred Subscriber"JohnDF" wrote: The Rocklin GoodYear has really went downhill. I just got back from that store. Yesterday I dropped off my beadlock (ring removed), slashed tire, and replacement tire. They were just supposed to pull the bad tire off and put the replacement tire on (inner bead only) and call me when it was done. No call, so I drove down there today. They had both beads set on the tire and it was inflated (no beadlock ring). I tried to explain to them that the outside bead could not be set. Anyway, a half hour later, and watching them like a hawk, they got it right. That place is useless. They didn't even pull off the bent and mangles balance weights.
I can kind of see why they didn't do it right. You didn't take them all the necessary parts. Generally speaking, tire guys seat the beads by inflating the tire. Without the beadlock ring there was no way to do what you wanted.
