Very beef, very nice
The Build
Gilbert & Betty Member Joined: September 2014Gilbert & Betty Member Joined: September 2014
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009
BKGM Jeepers President Joined: June 2003
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Looks great Kevin.
Josh Subscriber
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Sweet!! I'll need another ride to see how your handling has been affected...😁
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Lockers are wired up and PDM60 is installed! Running wire is a huge PITA! [https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_rasta.gif]
I still need to wire up the locker switches but all the wire is run and everything is working well so far. I'll add a picture of the switches once installed.
I created this schematic as a guide for the installation. Circuits 1 and 2 power the lockers. The rest are inactive until I get other accessories.
For the ignition trigger I tapped into M9 and for the dash light M18.
I ran the wires through a hole behind the passenger side dash panel.
I found that the dipstick works well for fishing wires through tight places. Although, there is a hint of 10W-30 in the cabin now. [https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_lol.gif]
The wires shown are for the 4 inactive circuits. I plan to install switches for them above the stereo.
Safety switch installed.
PDM60 operational. My 2 active circuits for the lockers are green when the ignition is on and the safety switch is on.
A shot of the software used to program the PDM60.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Awesome Kevin! Though, I have a fish you could have borrowed to save the oil smell!
Pretty cool project!
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Very cool. You are much braver than I am when it comes to wiring stuff.
Josh Subscriber
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Josh said
Kevin,
What is the "Safety Switch"?It controls the ground trigger. Right now I have circuits 1 & 2 (lockers) programmed to only be on with ignition trigger AND ground trigger. So with the ignition on, turning on the safety switch enables the locker switches. I did it that way because my lockers are wired independently of the Jeep's system (I can turn them on/off any time I want, front or rear, hi or low, 2WD or 4WD) and I don't want to turn on a locker accidentally doing 70 on the freeway. 🙂
Gilbert & Betty Member Joined: September 2014Gilbert & Betty Member Joined: September 2014Looks very cool Kevin
Josh SubscriberJosh SubscriberNice work Kevin. Thanks for the explanation above. Very cool.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012No wonder you left early!! Looks good!
Specialsoundman Member Joined: January 2013Specialsoundman Member Joined: January 2013k-jeep said
Latest unplanned addition is in! My stock battery was leaking on Hell Hole.
Shocking....
Gilbert & Betty Member Joined: September 2014Gilbert & Betty Member Joined: September 2014It looks very cool and coming a long
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012How does that affect your visibility when looking out your rear view mirror?
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Gregulator said
No worse than a full size spare would. 😛
Plus, it can be easily moved up or down if I need to. 🙂
Guy and Lynda Member Joined: May 2015Guy and Lynda Member Joined: May 2015That's clever. Can u put ur windows on with that? From the pix it looks like it sticks out beyond...?
Josh SubscriberJosh SubscriberLooks cool Kevin. Nice build. Jeep is coming along great! Congrats.
