School me on trailers.
  1. Justin Subscriber
    #120 Feb 2008, 2:19 PM
    This borrowing a trailer thing has me all messed up. I hate borrowing stuff. Now I want to buy a trailer. I see 16' tandem axle trailers brand new going for $2000. Are these any good. What do you all recommend I look for when buying a trailer? I want to go as small and cheap as possible.
    How about something like this?
    http://sacramento.craigslist.org/car/575466564.html
    #220 Feb 2008, 2:44 PM
    To me that looks like a great deal! With an LJ, you may need the longer trailer, but it is great they offer the 16' and 14' models too! If I only had a truck to tow it! I was thinking about buying one and keeping it at John's... 😎
  3. Justin started this Subscriber
    #320 Feb 2008, 2:47 PM
    I don't have a truck to tow it, just the motorhome. I see myself trading my Honda in on a diesel truck in the next year.
    The down side of me buying a trailer is that it won't get much use. I don't need to trailer to the local trails......wait.......people seem to break stuff when they wheel with John around here.......the trailer might come in handy. 😏
    #420 Feb 2008, 2:51 PM
    Looks like a good deal to me too. Almost too good to be true. Make sure you fit between the wheel wells you'll squash those if you have to drive over them. Check the weight of the Jeep to make sure the trailer is rated high enough. Remember that the 7k is gross. My 4Runner on Larry's trailer pretty much maxes it out. Of course you don't want it rated too high or you start having to worry about your license.
  5. JohnDF Subscriber
    #520 Feb 2008, 3:00 PM
    "Justin" wrote: people seem to break stuff when they wheel with John:
    Don't follow me...You won't make it πŸ˜€
  6. JohnDF Subscriber
    #620 Feb 2008, 3:03 PM
    "Bender" wrote: Make sure you fit between the wheel wells you'll squash those if you have to drive over them.
    Justin can weld. He could build ramps over the wheel wells to drive over them.
    #720 Feb 2008, 3:11 PM
    "JohnDF" wrote: [quote="Bender"]Make sure you fit between the wheel wells you'll squash those if you have to drive over them.
    There are definitely ways around it, but you start piling on the cost of steel and the additional weight to beef things up and you may end up wishing you'd bought one that would work in the first place. Seems like one of those things that could get out of control quick.
  8. JohnDF Subscriber
    #820 Feb 2008, 3:17 PM
    Is this turning into a trailer queen club??? Even Brad is talking about a trailer 😲
  9. Justin started this Subscriber
    #920 Feb 2008, 3:24 PM
    We will see who is a trailer queen when you want to borrow my way cool trailer. 😎
  10. Fred Subscriber
    #1120 Feb 2008, 4:24 PM
    "Justin" wrote: I don't have a truck to tow it, just the motorhome.
    I asked in the Hammers topic, but I think it was over looked. Does your motorhome have the towing capacity to tow a Jeep on a trailer? Most in that size range have only 5000 lbs capacity which isn't enough for the combination. Some are even limited to 3500 lbs, depending on how the motorhome was built. My guesstimate is your LJ on one of these trailers would probably weigh in about 6500 lbs.
  11. JohnDF Subscriber
    #1220 Feb 2008, 4:57 PM
    Tow ratings are guidelines. I've exceded tow ratings by huge ammounts without issues. I used to tow a 24' stock trailer filled with cows using a Ford 1/2 ton, regular cab, short bed pickup with a 6 cyl motor 😲
  12. Fred Subscriber
    #1320 Feb 2008, 5:05 PM
    "JohnDF" wrote: Tow ratings are guidelines. I've exceded tow ratings by huge ammounts without issues. I used to tow a 24' stock trailer filled with cows using a Ford 1/2 ton, regular cab, short bed pickup with a 6 cyl motor 😲
    Until you're in an accident, someone gets hurt or killed, and some lawyer sues you for being criminally negligent by being knowingly overweight. Yeah, one can get away with it, I've done it before too, but it's a gamble.
  13. Fred Subscriber
    #1420 Feb 2008, 5:14 PM
    As far as trailers go, for the load you're intending to carry, brakes are required. Legally you only need brakes on one axle, but if you find a trailer with brakes on both axles it would stop better.
    If the trailer uses a standard ball hitch, I'd look for one with the larger ball, 2 5/16" I think it is. It's can be hard to find a normal 2" ball and drawbar rated for the GVWR of the trailer.
    You'll want the wider bed width, I think that's 83" which generally puts the overall width of the trailer at the 102" maximum.
    Be sure to get a spare tire. On many trailers its optional.
    You'll need a brake controller on your tow vehicle unless it has one built in already. Many new trucks have it. I've heard Tekonsha's Prodigy controller is one of the best.
  14. JohnDF Subscriber
    #1520 Feb 2008, 5:22 PM
    "FAM" wrote: Until you're in an accident, someone gets hurt or killed, and some lawyer sues you for being criminally negligent.
    I live on the edge πŸ˜‰
  15. Fred Subscriber
    #1620 Feb 2008, 5:32 PM
    "JohnDF" wrote: [quote="FAM"]Until you're in an accident, someone gets hurt or killed, and some lawyer sues you for being criminally negligent.
    Deciding to drive an overloaded vehicle is one thing. Would you want someone else's overloaded vehicle anywhere around your family on the highway?
  16. Fred Subscriber
    #1720 Feb 2008, 5:44 PM
    Another thing about trailers I considered before buying one (sorry don't have it any more) - Many people prefer wood decks versus steel decks. When wet, the steel decks can get slippery, and in the summer can be pretty hot if you need to crawl under your Jeep to tie it down.
  17. Justin started this Subscriber
    #1820 Feb 2008, 6:02 PM
    "troyman" wrote: http://sacramento.craigslist.org/car/579301633.html
    Thanks
    I saw that one and thought I would look at it if it was still available on my next day off.
  18. Justin started this Subscriber
    #1920 Feb 2008, 6:07 PM
    Yeah, it's set up to pull a heavy load.
    #2020 Feb 2008, 6:48 PM
    "JohnDF" wrote: Is this turning into a trailer queen club??? Even Brad is talking about a trailer 😲
    Moab, Hammers or greater trips when I hit 5 weeks/yr vacation - which is coming up.
    #2120 Feb 2008, 8:26 PM
    My wife has been talking about letting me get one too πŸ˜€
    #2220 Feb 2008, 8:41 PM
    where's larry when u need him! πŸ˜‚ he would so dis-own you if he had read this. πŸ˜‚
    i tried to convince him once that it would be ok for me to tow my 71 c10 chevy loaded with spare parts using my 89 corolla from antioch to rancho and he bout took my head off!!! πŸ˜‚ those were the good ol days. πŸ˜‚
  22. JohnDF Subscriber
    #2320 Feb 2008, 8:50 PM
    Can't school an old cowboy about pulling things with a pickup truck πŸ˜€
  23. Fred Subscriber
    #2420 Feb 2008, 9:04 PM
    "JohnDF" wrote: Can't school an old cowboy about pulling things with a pickup truck πŸ˜€
    I was raised in a rural area too and have hauled some insane loads in a half ton and mini truck. One load of hay was so heavy if I tried to accelerate much the front tires came off the ground, and I drove about 40 miles that way. I'm not kidding. I was young and invincible at the time and thought it was fun.
    To advocate intentionally driving an overweight vehicle is absolutely irresponsible.
    I've said enough and won't comment on the overweight issue any further.
  24. RobD Subscriber
    #2520 Feb 2008, 10:13 PM
    "Justin" wrote: This borrowing a trailer thing has me all messed up. I hate borrowing stuff. Now I want to buy a trailer. I see 16' tandem axle trailers brand new going for $2000. Are these any good. What do you all recommend I look for when buying a trailer? I want to go as small and cheap as possible.
    That trailer is perfect. My Jeep is 83 1/2 inches wide and your Jeep is no where near that. You would fit on it with no problem. Your Jeep weighs about 4000 pounds, so you are fine on the weight.
    Watch out talking about towing your Jeep, next thing you know, everyone will be calling you a trailer queen and you will want to hack up your Jeep and you won't be be one of the cool kids anymore πŸ˜‚
