DIY Onboard Air - 2nd Gen Ram - ARB Compressor and 5 gallon|Fabrication Talk|Forum|Gold Hills Posse 4x4
November 14, 2011
12:57 am
DIY On Board Air -- ARB CKMA12 and 5 Gallon Tank
Thought this might be useful up in here.
This is a common air compressor for offroading these days being used for ARB air lockers. Additionally, this compressor is able to fill tires.
**Note: this compressor is not rated to run air tools: 2.18 CFM @ 29 psi
Choice of tank (size, orientation, number of ports) is vehicle and owner dependent. Use the DIY as a guideline for your configuration.
I wrote this up to document what I've done so far and plan to add any changes as it is only ~90% complete.
Here is the compressor and tank. Tank purchased off ebay. Shipping is the most inhibiting aspect. I did not find, what I thought, good deals from offroad shops or other stores. Best bet for low dollar, decent tank, is a semi-truck junkyard or salvage yard, such that you can get an air suspension tank. They are already rated for high pressure and plenty of ports. Mounting straps even accompany them. Unfortunately, I couldn't get one of these due to travel distance.
Image Enlarger
Use mounting plate to locate the compressor install spot. You can see my pilot holes drilled. I had already prefit for this lcoation.
Image Enlarger
I went and painted the mounting plate 😉
Image Enlarger
I had some rubber laying around (from my thule rack system) and used for vibration isolation.
Image Enlarger
Set in place with mounting plate and rubber.
Image Enlarger
Image Enlarger
Bottom side of the wheel well. Those of you with wheel well covers, you'll have to remove them. You can get replacement grommets at Autozone. They are 1/4" size and come in packs of 10. They have a phillips head screw that engages and spreads the wings.
Image Enlarger
Image Enlarger
Image Enlarger
Wiring installed. Added the wiring conduit for protection, ease of routing, and identification. Note that the relay is mounted to the wheel well (black box on the left).
Image Enlarger
Current setup has a T-fitting, the pressure switch that came with the compressor, and a cheap pressure gauge. All 1/4" npt.
Image Enlarger
Wiring for Hot and Ground. The conduit off to the right is the harness that goes into the firewall. That location back behind the brake master cylinder.
Image Enlarger
Fire wall access. I poked through the diamond shaped rubber on the left. The hole for the hood cable was maxed out.
Image Enlarger
So now wiring inside the cab. This is the wire bundle right on the steering column upon removing the kick panel. Three screws across bottom, then lift panel straight out and up.
Image Enlarger
Used the Black and Yellow wire for Dash Illumination!!
Image Enlarger
Tried to use Black and Orange for Ignition. This one did NOT work. See next picture for correct wire, Dark Blue!!
Image Enlarger
Used the small DARK Blue wire for Ignition.
Image Enlarger
Kick Panel done. Left switch is Aux light in rear. Right switch is the compressor isolator switch. Start vehicle, then flip switch for compressor to run.
Image Enlarger
System tested with air line hooked up. Got 100' from HD for ~$25. Red wiring conduit all zip tied in place.
Image Enlarger
Zip tied on Driver Side.
Image Enlarger
Added Quick Connect at Comopressor for eash removal or changes in the future.
Image Enlarger
Routed hose down under passenger side. Zip tied to existing vacuum lines and emissions schtuff.
Image Enlarger
Image Enlarger
Image Enlarger
5 gallon tank getting prepped.
Image Enlarger
More to come. Current system is operational. My hose is rolled up and hung up inside, underneath the bed on passenger side. It's hidden away and partially protected from elements. Plan is to add a 5 port manifold to make for more options.
Plan is to route the hose to the tank. This will be once I've finalized tank location. Considering on front of bed, sideways. Then air hose to be run from tank. I'd like to have the tank mounting be quick disconnect too. Some sort of quick release such that the tank could be filled and taken away from the truck if need be to assist other vehicles.
November 14, 2011
12:59 am
Reserved for later.
November 14, 2011
3:03 am
Forum Posts: 7426
Nice write up so far. I run that compressor for my ARB's in the JKU. It works great for that purpose.
4:35 am
Any input is welcome. Still in progress and some things can still be worked better. I think my pressure gauge is crap.
Think I should add a water trap?
This must be bit elementary compared to all the built rigs here. Starting from scratch AND will all my extra room is all your gonna get out of me.
Thanks
November 14, 2011
4:41 am
Good start to your first air system.
One thing you might want to consider though is the use of that quick disco at the comp. Quick disconnects are not used for maintaining air pressure but a connection point to use the air. If you have that tank connected to the air comp by way of an quick disconnect, it will leak by, starting the air comp more often to maintain pressure in your tank.
November 14, 2011
5:14 am
Tom
Elk Grove, CA
Forum Posts: 1465
Nice work ... clean install!
November 14, 2011
5:23 pm
Tom
Elk Grove, CA
Forum Posts: 1465
Oh, and for the record, I'm paying special attention as I'd like to have OBA as well. mr-green
November 14, 2011
6:13 pm
"rick-rock" wrote: Good start to your first air system.
Thanks for the heads up. What would be the alternative to QCs you'd suggest? I guess any fitting can come to leak, but aren't all shop compressor/tank setups have a QC right after the pressure gauge (e.g, my porter cable 3 gallon)? I only plan to run the compressor upon flipping the cab switch so I'd further minimize frequent re-pressurization. For the tank, in the last picture that is the inlet side. Male fitting, then to ball valve. Outlet side will have attached line with QC for attachments. That's the plan anyways.
November 14, 2011
8:57 pm
Forum Posts: 3113
Nice write up...but I did notice two typos. mr-green
I am paying close attention as well. I need OBA.
3:44 am
I'm curious on how you decided on the ARB compressor? The ARB site says it's good for 2.18 cfm at 29 psi with a 50% duty cycle (30 on/30 off). I'm not seeing a rating at 90 psi (a typical tool pressure). You've obviously got tons of storage, but I think you may struggle to run air tools effectively. Plenty of air for tires/locker though. 8)
November 15, 2011
4:47 pm
"finder_87" wrote: Nice write up...but I did notice two typos. mr-green
"Bender" wrote: I'm curious on how you decided on the ARB compressor? The ARB site says it's good for 2.18 cfm at 29 psi with a 50% duty cycle (30 on/30 off). I'm not seeing a rating at 90 psi (a typical tool pressure). You've obviously got tons of storage, but I think you may struggle to run air tools effectively. Plenty of air for tires/locker though. 8)
Quality control is a welcome effort no matter what the topic is. I decided on this compressor only based on the plan for the lockers and capability of filling tires. The air tools usage was a far reaching capability and confirmed dream. 😕 I'm by no means a regular user of air tools. You cite the specs right and this won't be able to run any but one of these.
[Image Can Not Be Found]
I will revise the post to remove misjudgment.
Thanks Bender, you da man!!!
November 15, 2011
6:02 pm
"Wh1t3Nukle" wrote: [quote="finder_87"]Nice write up...but I did notice two typos. mr-green
I think you'll be able to do better than an air gun! With 5 gallons of storage you may be able to run an impact gun enough to zip on or off some lug nuts, but it would be tight. Worst case blowing the dust off at the end of the day wouldn't be a bad thing. mr-green The reality is most people don't carry air tools. It's a lot of weight to lug around.
November 15, 2011
8:03 pm
Forum Posts: 7426
I don't see the output of the ARB compressor sufficient for air tools. I wonder how many (if any) lug nuts it could spin off. Maybe if they were broken first, it could spin off a wheel at a time...
9:14 pm
The model he's using is the new and improved ARB compressor, not the older, smaller one. It'll be interesting to see how it works in the real world.
November 15, 2011
9:22 pm
Forum Posts: 7426
I have that same compressor in my JKU. It is better than the older compressor, but not fast by any means...
10:50 pm
Will report on how ineffective it is to run air tools soon enough.
Just getting down thoughts of the tank install nailed down. Considering using truck bicycle mounts, like this:
Any flaw seen with this or better ideas? Could use just one and have bracket for the other end where the foot just slides into. This is so the tank can be taken out for any reason. Especially if I've got to transport something big in the bed.
Brad -- does your compressor pressurize up to 70-80 psi or so, assuming you have a pressure gauge installed?
November 17, 2011
12:29 am
Forum Posts: 7426
I run arbs. The cut off on mine is 95 psi from what I remember.
3:24 am
Why are you putting the tank in the bed? Put it underneath. It'll be fine down there in the dirt and mud. Plenty of room down there. I wouldn't use any of the valuable bed space.
November 17, 2011
3:34 am
"BKGM Jeepers" wrote: I run arbs. The cut off on mine is 95 psi from what I remember.
So you put in a higher pressure switch then. The one that comes with the pump kicks off at 70 psi.
"Bender" wrote: Why are you putting the tank in the bed? Put it underneath. It'll be fine down there in the dirt and mud. Plenty of room down there. I wouldn't use any of the valuable bed space.
No, its not going underneath. Made that decision based on the tanks size. Underneath defeats the whole purpose of being mobile, which is one of the features I desire.
November 17, 2011
3:46 am
Why do you want it mobile?
EDIT: Not trying to judge anything you're doing. Just trying to come up with something that may meet your needs with a slightly different design. I'm trying to imagine what 5 gallons of mobile air at 90 psi (at most) is going to get you. I didn't do the math, but maybe 1 tire from a "wheeling" pressure to a "street" pressure? Ughhh...PV=nRT.
November 17, 2011
5:17 am
"Bender" wrote: Why do you want it mobile?
You judge? No way. wink I'm in no way trying to over due this thing. Lot of silly ideas with it is all.
The tank is not strictly for the truck and wheeling. Mobility will help out airing up bikes; floor pump upgrade! Will certainly help me out when I get back to racing next season. I also do a bit of Mtn. biking and it's usually with a group of people.
Misc. usage around the house its much easier to carry this tank relative to my cumbersome Porter Cable pancake compressor. Makes some tasks like clearing gutters, dark holes, leaves, etc. actually fun to deal with. 🙂
The tank can be run much higher pressure than 90. Just get a higher rated switch is all, but not more than 180 psi.
It's a silly convenience perhaps, but it outweighs staying underneath the truck. I've seen under mounted tanks get worked over from element exposure, corroded fittings, etc. So I think I'm going to mount on the passenger side, at front of the bed, running left to right. It's not going on the bed floor.
I like that you dropped the Ideal Gas Law, but boo on not showing your work. rasta Just use P1V1 = P2V2. I'm not sure what the volume is of my 35" tires. It may be 2 tires filled with tank detached. Totally rough guess.
November 17, 2011
5:50 am
Tom
Elk Grove, CA
Forum Posts: 1465
"Wh1t3Nukle" wrote: [quote="Bender"]Why do you want it mobile?
As long as there are folks who understand the Ideal Gas Law, maybe we should use calculus to determine the volume of the tire. We could come close ... just need to determine the equation for finding the volume of a donut. thinking
Don't laugh, I had to do it in college.
March 25, 2012
3:38 am
Ok Bender,
I've compromised. 😀 Before I explain, I did plan to put the tank on the passenger side wheel well. To have it wrapped with sheet metal box. It would have been mobile and not consume too much bed space.
The new setup is actually underneath. Having the spare tire out, which can't fit down there anymore, made it much easier to see what I had to work with. It wasn't that much room actually. So the location is right above the driveshaft. Bumpstops provide ~3" of clearance from center section.
I've mocked up the tank where it's mostly permanent. Simple angle bracket (2 thru bolts) secured to a cross beam of the bed. The forward end of the tank just slips over it. The back end is fixed to a bicycle fork mount. It's pretty solid and so far seems to work.
The front support is incomplete though as it will bounce around. I was thinking of bending to wrap around or maybe get another piece and weld on top to act like a sandwich. I hope that makes sense.
I'd love to hear thoughts on either mounting for flaws and improvements. I'm no fabricator and thought I'd get some better input from you all.
Thanks!
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
March 25, 2012
4:00 am
I like that more better, but that tank isn't going to be that purdy for too much longer. 😀
March 25, 2012
11:33 pm
Done!
72277=2990-uploadfromtaptalk1332718356584.jpgImage Enlarger
Most Users Ever Online: 472
Currently Online: Sloguy
Guest(s) 10
Gregulator: 3113
Jeff_R: 2003
Gilbert & Betty: 1446
Members: 143
Topics: 4468
Upcoming: Guy and Lynda, Mike G, ironskullfab@gmail.com, Eric and Dawn
