As the installation of my rear D44 gets ever closer to becoming a reality a question on placement. Running 6-1/2" of lift front and rear give the "view" of a shorted wheelbase with tires moved to the edge of the fender openings.
The front was no issue as I have adjustable upper and lower control arms. Checked with the manufacturers before doing anything, but extending each 1" was well within tolerance and centered the tires just right. Also gave the alignment guy just a little more to work with when adjusting caster angles. Now to the question ...
I've seen spring perches and axle plates with multiple holes drilled so the axle could be move fore and aft 1", or so" from the standard placement. Can I accomplish the same by drilling or are these aftermarket plates and perches dimensionally different from the standard?
BTW, I am only looking to move the axle 1" to the rear.
Thanks!!
Drilling Spring Perch and Axle Plate
Tom SubscriberTom SubscriberIf you do not change direction, you may end up where you are heading -- Lao Tzu
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Can you drill accurately twice?
Tom SubscriberTom started this Subscriber"finder_87" wrote: Can you drill accurately twice?
Yup 😁
Keep that e/d ratio good though? 😉
Done yet?
Tom SubscriberTom started this Subscriber"Wh1t3Nukle" wrote: Keep that e/d ratio good though? 😉
Done yet?e/d ratio?
No, not done ... bummer.
