Aftermarket JK Axle Question |General 4x4 Discussion|Forum|Gold Hills Posse 4x4
January 22, 2017
8:42 pm
Forum Posts: 3113
For those of you running aftermarket axles on your JK, what width is your axle? Are you running wheel spacers? If so, how wide? What's your rim and backpacing? What tire size are you running?
I am trying to figure out what width I might want. I'm looking to run 40s with no tire to frame contact preferred. I can either go 67" or 70". Factory width is 65.5 I believe.
Thanks for the input.
9:09 pm
Forum Posts: 7426
I run no front spacers and 3" total in the rear.  My rear axle is stock width.  My tires don't rub and are 40s.  If I recall my wheels are .5" back space.
10:31 pm
k-jeep
Parts Unknown
Forum Posts: 2288
I believe the UD60s are 69", 8-lug, and full float rear. Tires are 38x13.50R18 Toyo on 4.5BS wheels. No spacers.
Kevin
January 23, 2017
7:00 am
Forum Posts: 3113
Are you guys both running 9" wide wheels?
8:15 am
k-jeep
Parts Unknown
Forum Posts: 2288
Mine are 9".
Kevin
January 23, 2017
9:56 am
Forum Posts: 3113
Thanks Kevin.
Brad, I'm assuming your .5 is offset not backspacing? If you have a 9" wheel, that would be 5" backspacing.
8:43 pm
Josh
Forum Posts: 1630
I run the RockJock D60's
Tires 37"
Rims are Pro Comp 98-7985R2.5 they have 2.5" of back spacing.
No wheel spacers
Hoping to get beadlocks someday!
9:11 am
Forum Posts: 3113
Tires 37"
No wheel spacers
I hope you get beadlocks too.
Any idea what the axle width is for your RockeJocks?
2:09 pm
Josh
Forum Posts: 1630
68.75" wide per factory spec sheet for JK version
Your choice of tires, rims, backspacing will vary your overall dimensions.
Most Users Ever Online: 472
Guest(s) 12
Gregulator: 3113
Jeff_R: 2006
Gilbert & Betty: 1446
Members: 143
Topics: 4469
Upcoming: Guy and Lynda, Mike G, ironskullfab@gmail.com
