OK, incrementalism has gotten out of hand and I need to do something about it. Here's my dilemma ...
RE1462 rear leaf springs: 4-1/2" lift (closer to 5-1/2"π. 5 leaf pack.
Extended shackles for flex: 1-1/2" lift
shackle/leaf adjustment: 1-1/2" lift
Total: ~8" of lift overall which is way more than my XJ needs. Front has spacers to make up the difference over the original 4-1/2" spring lift.
:arrow: Question for the "experienced" leaf spring people out there: 1 - Sell leaf springs "as is" and buy desired height to work with shackles and adjuster. 2 - Remove leaves to achieve desired height. π€·
If #2, which leaf to start with. Realizing each spring is also 1/4" in height.
Thanks!!
GREAT ground clearance but too much height.
Tom SubscriberTom SubscriberIf you do not change direction, you may end up where you are heading -- Lao Tzu
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012I say just go with bigger tires. Lol!! π
Fred SubscriberFred SubscriberWould these help Ronnie?
http://www.urbanoutfitters.com/urban/ca ... _PLATFORMS
I can't help much with your leaf spring question other than it sounds like you'd need to remove most of the leaves to go down 4 inches. I suspect spring replacement may be the best option.- Guest former userGuest former user
Fred said Would these help Ronnie?
You are right I also had a good time with this amazing brand and I bought their many items at low prices by using their Urban Outfitters Discount Codes. They provided the latest deals for their consumer So, check it out before it goes.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Clean up on isle one... πͺ¨
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Russian Cyber attack using posts from 9 years ago?
Nubby Webmaster K6NUB Joined: February 2018Nubby Webmaster K6NUB Joined: February 2018ah man, one slipped by me!
