In order to make the Snake Lake run on Friday I need to replace my cracked oil pan. After watching a few videos I think I need to ask for help with this repair. According to the videos I watched, you need to remove the exhaust and possibly cut and re-weld the exhaust. I ordered the parts (pan and gasket) which are supposed to be in Sunday afternoon. Is there anyone who might be able to help me with this repair? I already drained the oil and I have a broken upper control arm bracket that my son will be welding back on for me tomorrow, so I probably need to do the repair here at my house. My son can also weld the exhaust if needed. Thanks!
Help requested: TJ oil pan replacement
Jeff_R Member Joined: October 2016Jeff_R Member Joined: October 2016Jeff and Kathy Root
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Let me know when and I'll try to make it. Will have to be an evening for me with this darn work thing getting in the way of everything. 🙂
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016k-jeep said Let me know when and I'll try to make it. Will have to be an evening for me with this darn work thing getting in the way of everything. 🙂
Thanks Kevin. I first tried to disconnect the exhaust at the cat but the bolt heads are under the skid plate and I couldn't get enough space and leverage to loosen them. Next I tried to disconnect the exhaust at the engine end. The pipes balloon out making it difficult to get to the bolt heads. I either don't have the right tools and/or the aptitude to get the exhaust off at that end either. At this point I either need to get help or take it to the shop. My local shop is usually at week or more out so if I go that route then I won't be able to make the run unless he can squeeze me in. If you think we can do this then that would be great, otherwise I will take it to the shop. I will call him first thing tomorrow to see if he can squeeze me in or not. I will then know my options. I'm available Monday through Wednesday. If we try it, the sooner the better for me.
Brian Member Joined: February 2020Brian Member Joined: February 2020I didn't realize the oil pan was in that much harder of a location on a TJ!
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016Brian said I didn't realize the oil pan was in that much harder of a location on a TJ!
I didn't either until I saw the YouTube videos.
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009I think I can make it Monday evening. I'll confirm and let you know.
What you will want to do during the day is get some PB Blaster and spray the bolts and entire flanges a couple of times. Hopefully that will help loosen things up. Also check if they use a gasket. We'll want to replace those as well if they do. If I think of anything else, I'll let you know.
I'll look at my old thread and bring any additional tools we might need.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Jeff, got your text. Sorry, I was not on the run with my brother. I think this install is above my pay grade.
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Confirmed, I can make it Monday evening. Text me your address and I'll head out there after work. I usually leave work in Folsom around 4:30pm.
Found the thread that helped me when I did the rear main seal on my YJ...
http://www.dailydriventj.com/forum/viewtopic.php?t=811
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016k-jeep said Confirmed, I can make it Monday evening. Text me your address and I'll head out there after work. I usually leave work in Folsom around 4:30pm. Found the thread that helped me when I did the rear main seal on my YJ... http://www.dailydriventj.com/forum/viewtopic.php?t=811
Thanks Kevin. I will text you my address. Pizza and drinks will be waiting.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Lesson learned?
The very first mod I've put on every Jeep I've ever owned was an oil pan skid.
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016JohnDF said Lesson learned? The very first mod I've put on every Jeep I've ever owned was an oil pan skid.
I have a steering box and fuel tank skid but for some reason never put an oil pan skid on. I called 4wheels parts and they have an oil pan skid but the gentleman I spoke to said he bought, but hasn't yet installed, a Skid Row engine, transmission and oil pan skid. He said it is far better protection so that's the way I'm going to go. Would you agree that this is the way to go John?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I ran the Tera, but I couldn't find that style any more.
It was very similar to this one; http://extrememetalproducts.com/i-13354355-jeep-tj-oil-pan-skid-plate.html
That one you posted seems awfully expensive. It doesn't take that much to protect it.
Guy and Lynda Member Joined: May 2015Guy and Lynda Member Joined: May 2015Jeff, just got on the forum and see u need help. Guy works in Benicia and fights traffic till late, so getting there during the week is difficult. Please keep us posted on ur progress and let us know if there is anything we can do!
Gilbert & Betty Member Joined: September 2014Gilbert & Betty Member Joined: September 2014Hey Jeff I use a Rokmen oil / tranny skid it's been very stout. Checkout Rokman offroad I have no complaints
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016Huge thanks to Kevin for coming to my house to work on my Jeep. We got the rear main seal replaced and the new oil pan on. It was 4.5 hours of non-stop work. All that needs to be done now is to reattach the exhaust, change the oil filter and add oil. Hopefully no leaks and I'm good to go. Once it is drivable, hopefully late tomorrow afternoon, then I will drive it to my son's house to have him re-weld the broken rear upper track bar bracket. Thanks also to my friend and coworker Scott and my son Brian for their assistance.
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016Gilbert & Betty said Hey Jeff I use a Rokmen oil / tranny skid it's been very stout. Checkout Rokman offroad I have no complaints
I ended up ordering the skid row skid plate and a Rock Hard sport cage.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Jeff_R said
I ended up ordering the ... Rock Hard sport cage.
Nice. Good cage.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Glad you got it squared away.
Gilbert & Betty Member Joined: September 2014Gilbert & Betty Member Joined: September 2014Jeff_R said
Great sports cage I also have that cage a great safety feature
I know, I liked your cage so much I decided to get one of my own. 👍
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009How was the exhaust re-install? I hope it went back on easier than it was to get off. 🙂
Jeff_R Member Joined: October 2016Jeff_R started this Member Joined: October 2016k-jeep said How was the exhaust re-install? I hope it went back on easier than it was to get off. 🙂
It went good. We put the pipes back on and fired the Jeep up and had a loud exhaust noise so we had to loosen it and then wiggle the exhaust to get the pipes to seat better. We tightened it all up again and it ran fine. Took it for a test drive and there were no oil leaks so it appears that everything is fine!
