I am a Radio Station Engineer with a lot of experience with CB radio on the HF and UHF frequencies. I am also a Radio Amateur and I have been involved with radio for most of my life. That amounts to over 50 years.
I am saying this so you understand I have extensive experience with cabling of antennas from low power rigs right up to many kilowatts.
The length of coax to use in =any= installation, if it is done properly, is the minimum practical length.
So, if you need a Metre (3ft to some) length then make it a little longer for practicality and go with that.
Why ?
Simple. If you have a 50 ohm output connected to a 50 ohm cable which is in turn connected to a 50 ohm antenna then you make it as short as is practical because everything is matched and you will get maximum power into the load (antenna).
I'm trying to make this really simple but believe me, the 18' length is a furphy - it was a dream explanation by people who didn't understand how things =really= work. ie. Transmission Theory.
In an installation where something is wrong, the longer cable "hides the problem" - ie. It doesn't fix it, it just makes you think it is better when it is definitely not and all it does is introduce more loss which degrades performance.
And another thing, a low SWR/VSWR does not necessarily mean it works better ! Think about this - a dummy load of the correct impedance has a 1:1 VSWR. You simply cannot do better ! And yet you can't use it except as a test load for your equipment (And it is exceptionally handy for testing coax !)
I can make an antenna that has a near perfect VSWR and it's performance can be dismal (at best). SWR/VSWR means naff-all.
That's it in a nutshell folks.
Make sure your ground at the antenna base is very good (it's the most common error) during vehicle installations. If you hang an antenna off anything and it doesn't have enough metal under it to act as an effective ground plane, the receiving AND transmitting performance will be degraded.
Use the shortest practical length of coax.
Tune the antenna if you need to but honestly, I have extremely rarely ever needed to do this if it is a quality antenna and installed correctly.
At the Radio Station, we don't adjust the coax length, or any transmission cable length except to make it as short as possible .... And we are talking =real= power here, not a few watts or a few hundred watts.
We want the lowest loss and everything as best matched as possible to minimise transmission losses.
ChrisM
Head Radio Station Engineer
Queensland
Australia
Do it right and have fun !
