January 25 - Iron Mountain Snow Patrol
    #117 Jan 2009, 5:55 PM
    My name is Chris - Blue 02 TJ (RE lift - 33's w/ 4.56 and rear ARB) - I have been to a few meeting over the last year, but I haven't made it out on a run with you guys yet. I would like to do the Iron Mtn run. What can I expect?
    #217 Jan 2009, 10:09 PM
    You will have a lot of fun. Your rig won't have any trouble. Read the trip description on the calender. We will have a camp set up and have a bbq. Bring you and your family. This was my first run and I enjoyed it. Hope to see you there.
    #317 Jan 2009, 10:11 PM
    Not much if it doesn't snow. 🙁
    Just kidding. It'll be a good time. Here are links to a couple of old writeups that give you a pretty good idea.
    https://posse4x4.org/events/2006-02_iron ... atrol.html
    https://posse4x4.org/events/2006-03_iron ... ol_II.html
    It's a good way to meet people because you're pretty much stuck hanging around all day. Your rig is fine. I'm contemplating bringing my old F350 to see how it does in the snow and I know Larry is bringing his 3/4 ton Dodge. We usually just go up far enough to watch people get stuck.
    #418 Jan 2009, 11:59 AM
    Thanks for the links - sounds like a fun time. See you Sunday morning.
  5. Dan-H Subscriber
    #518 Jan 2009, 9:18 PM
    "Bender" wrote: Not much if it doesn't snow. 🙁
    Cross your fingers for a little snow Thursday or Friday.
    #618 Jan 2009, 9:22 PM
    "Dan-H" wrote: [quote="Bender"]Not much if it doesn't snow. 🙁
    I drove up there today. It was 7 miles before I hit snow on the road. It was mostly frozen snow packed into ice. I think I saw only two or three vehicles the whole 7 miles. One of them was a rig towing a snowmobile up the hill.
    #719 Jan 2009, 7:59 AM
    We should get some fresh snow up there starting Wednesday through Sunday
    #819 Jan 2009, 8:02 AM
    "gamfam" wrote: We should get some fresh snow up there starting Wednesday through Sunday
    WoooooHoooooo! 😀
    #919 Jan 2009, 8:23 AM
    I split this thread off of the meeting thread so I could find it. 😀 This is going to be a good run for new folks to join in on. We have a prospect that is going to make member so come join the fun.
    From the calendar
    Meeting at the subway off of Sly Park Road and Hwy 50 at 9AM. Leaving for the road patrol from there at 930.
    This should run most of the day (until at least 3PM), but people can come and go as their schedule permits. Also, we will be setting up a check point where the snow gets deep so anyone can just drive up the road (in a real 4wd) and find us!
    There's a lot of sitting around for this event so bring chairs and a lunch. We'll have at least one heater and the canopy. Go Mr. Heater!
    People are welcome to take off for side runs during the day too.
    #1022 Jan 2009, 7:36 AM
    Anyone know what the current snow level for this storm is? It's pouring up here, but it's 50ish degrees outside. 🙁
    #1122 Jan 2009, 8:05 AM
    "Bender" wrote: Anyone know what the current snow level for this storm is? It's pouring up here, but it's 50ish degrees outside. 🙁
    It's currently about 7000' We should have some nice fresh snow for the run. If this keeps up, we may set up camp very low!
    We whould have TWO prospects making member status with this run!
    #1222 Jan 2009, 8:29 AM
    "BKGM Jeepers" wrote: We whould have TWO prospects making member status with this run!
    And two new people joining us for a first run!! 😎
    #1322 Jan 2009, 8:32 AM
    "Bender" wrote: [quote="BKGM Jeepers"]We whould have TWO prospects making member status with this run!
    Should be a lot of fun!
    Should I bring the canopy? if the weathers bad? What about my propane heater? I know we'll have a bbq and bondfire. Will that be enough?
    Also, when the weather is bad, we usually set up camp just above the snowline since snow is nicer than rain...
    #1422 Jan 2009, 10:28 AM
    WEATHER ALERT
    BURNEY BASIN / EASTERN SHASTA COUNTY-
    NORTHEAST FOOTHILLS/SACRAMENTO VALLEY-MOTHERLODE-
    WESTERN PLUMAS COUNTY/LASSEN PARK-
    WEST SLOPE NORTHERN SIERRA NEVADA-
    500 AM PST THU JAN 22 2009
    ...WINTER WEATHER RETURNS TO THE MOUNTAINS AND FOOTHILLS THIS
    WEEKEND...
    A COLD LOW PRESSURE SYSTEM WILL DROP DOWN THE CALIFORNIA COAST
    THIS WEEKEND. IT WILL TAP INTO MOISTURE CURRENTLY OVER THE REGION
    AND COULD BRING GOOD SNOWFALL TO THE MOUNTAINS SATURDAY AND SUNDAY.
    THERE IS STILL SOME UNCERTAINTY AS TO THE EXACT PATH THIS LOW
    PRESSURE SYSTEM WILL TAKE. HOWEVER...THERE IS INCREASING
    CONFIDENCE THAT WINTER WEATHER WILL IMPACT TRAVEL OVER THE SIERRA
    AND THE LASSEN PARK AREA BY SATURDAY MORNING. A COLD FRONT MAY
    PUSH INTO THE REGION SUNDAY...LOWERING SNOW LEVELS TO 2500 FEET.
    CONTINUE TO MONITOR THE LATEST WEATHER SERVICE FORECASTS FOR
    UPDATES ON THIS DEVELOPMENT. REMEMBER TO ALWAYS BE PREPARED FOR WINTER
    DRIVING CONDITIONS WHEN HEADING INTO THE MOUNTAINS THIS TIME OF YEAR.
    #1522 Jan 2009, 10:37 AM
    Linda and I plan on being there. It's raining here at Kelsey pretty good, so there should be a lot of snow up higher. What air pressure do you guy's reccomend. Ill be at the subway on time (i hope) What things do i need to bring besides a lunch, chairs, shovel, ?
    Tire pressure for snow is usually based on your vehicle's ratio of tire and rim width, and the flexibility of your tire's sidewall. A wider rim will lose it's bead at a higher PSI. I more flexible sidewall will also require higher pressure to avoid losing the bead.
    Are you running an 8" rim, or a 10" rim?
    Generally, 12 is save for either size. I have run 8 with the 8" rim and not had problems.
    Just my opinion however.
    #1622 Jan 2009, 11:45 AM
    "bobf777" wrote: Linda and I plan on being there. It's raining here at Kelsey pretty good, so there should be a lot of snow up higher. What air pressure do you guy's reccomend. Ill be at the subway on time (i hope) What things do i need to bring besides a lunch, chairs, shovel, ?
    Plenty of warm clothes and the normal stuff you would take wheeling. Looks like you'll be coming across 49 so I may see you on the way over. If I'm in the 4Runner I'll be on CB channel 10.
    In the snow I go pretty low on tire pressure. I'll go 6-8 psi with a 37"x12.50" MTR on an 8" rim. I have gone lower, but it makes me nervous. I don't think I have much CO2 though so I may not air down much at all. You probably won't need to air down to get to the setup spot. Only if you want to go have some fun during the day.
    #1723 Jan 2009, 9:00 PM
    Does anyone know if the subway will be open Sunday morming? Also, my daughter (15) is thinking of going - any teenagers going?
    #1824 Jan 2009, 8:33 AM
    The subway is usually open. If not there's a Safeway across the street for backup.
  19. Dan-H Subscriber
    #1924 Jan 2009, 11:28 AM
    I'm out. 🙁
    I picked up the cold and sore throat my Kids had earlier this week.
    #2024 Jan 2009, 4:30 PM
    "pothole" wrote: Does anyone know if the subway will be open Sunday morming? Also, my daughter (15) is thinking of going - any teenagers going?
    My son is going. he's 11. Cole is also going. He's a teenager.
  21. Sfisher Subscriber
    #2124 Jan 2009, 7:06 PM
    I'm going to tag along also if you guys don't mind. Will be taking my four year old daughter and twin two year old boys too. They did great at Winter Fun Fest last week so looking forward to it. Of course I will have an army's worth of clothes for them to wear. Anyone else bringing young one's?
    #2224 Jan 2009, 9:42 PM
    "Sfisher" wrote: I'm going to tag along also if you guys don't mind.
    Sounds good.
    #2325 Jan 2009, 6:37 AM
    Since John's not going 🙁 someone has to say it.
    Truck's packed...coffee's brewing... 😀
    #2425 Jan 2009, 7:39 AM
    "Bender" wrote: Since John's not going 🙁 someone has to say it.
    Us too! (minus thge coffee...)
    We have a 3 year old going as well.
  25. Guest former user
    #2525 Jan 2009, 5:37 PM
    Great turn out!!! Anybody get an official count of the rigs with us? 15+? Must have been 30+ people counting kids! I'll get a picture of "Camp Posse" up tonight! I think we've finally figured out how to do this snow patrol thing. Easy ups. BBQs. NICE!
