3:39 pm
January 20, 2009
Offline4:54 pm
January 20, 2009
Offline4:57 pm
May 4, 2004
Offline"kevheb" wrote: [quote="JohnDF"][quote="kevheb"]Fun run. A few scars but made it out in one piece.
Here's my write-up...
"Wicked awesome!"
I'll post pics soon.
Nice write-up...you're fired 👿
Never be good at anything you don't want to do. 😈
If you're not careful, we'll vote you in as the next Trail Master so you can get more practice
6:11 pm
OfflineThere are some photos in my gallery of the trip. Under Rubicon 2010
http://gallery.me.com/robertdellinger
Fun trip. You will see a lot of straps and winches in the photos ![]()
9:17 pm
January 20, 2009
Offline10:58 pm
January 20, 2009
Offline2:56 am
OfflineIf your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
"lj4x4" wrote: Made it home with out a problem. Had a great time! Thanks for everyone's help. I hope goodyear will warranty the tire. We will see.
P.S. Rob and Kevin the pics are great!
3:37 am
"RobD" wrote: If your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
[quote="lj4x4"]Made it home with out a problem. Had a great time! Thanks for everyone's help. I hope goodyear will warranty the tire. We will see.
Great info. I originally got the tires in Rocklin so that is where I will go. Thanks again for all your help. I think rock tossing should be an olympic sport......
2:08 pm
OfflineThat is probably the one I use if t is the one on Taylor rd.
"lj4x4" wrote: [quote="RobD"]If your Goodyear won't warranty the tire, I know the one I use in Rocklin will. I used to warranty 4 or 5 tires a year with them and some of the side wall cuts were way worse than yours. My Kevlars are holding up really well with no side wall cuts, and I have been in some spots where I know the old ones would have slit wide open.
2:38 pm
now you really mad eme jealous.. 🙁 rock tossing and new tires.... 😥 😥 😥
7:48 pm
OfflineThe Rocklin GoodYear has really went downhill. I just got back from that store. Yesterday I dropped off my beadlock (ring removed), slashed tire, and replacement tire. They were just supposed to pull the bad tire off and put the replacement tire on (inner bead only) and call me when it was done. No call, so I drove down there today. They had both beads set on the tire and it was inflated (no beadlock ring). I tried to explain to them that the outside bead could not be set. Anyway, a half hour later, and watching them like a hawk, they got it right. That place is useless. They didn't even pull off the bent and mangles balance weights.
8:20 pm
January 12, 2007
OfflineSwimming in Spider Lake at night was AWESOME!!! The water was the perfect temperature after a long day on the trail. We all went for one more swim Monday morning before wheeling out.
Thanks again to everybody for stacking rocks and running winch line for me. I must have lost my wheeling mojo. 😥 I had to get strapped once and winch once.
oh yeah........Good Year in Rocklin sucks!
8:25 pm
May 4, 2004
Offline"JohnDF" wrote: The Rocklin GoodYear has really went downhill. I just got back from that store. Yesterday I dropped off my beadlock (ring removed), slashed tire, and replacement tire. They were just supposed to pull the bad tire off and put the replacement tire on (inner bead only) and call me when it was done. No call, so I drove down there today. They had both beads set on the tire and it was inflated (no beadlock ring). I tried to explain to them that the outside bead could not be set. Anyway, a half hour later, and watching them like a hawk, they got it right. That place is useless. They didn't even pull off the bent and mangles balance weights.
I can kind of see why they didn't do it right. You didn't take them all the necessary parts. Generally speaking, tire guys seat the beads by inflating the tire. Without the beadlock ring there was no way to do what you wanted.
