5:30 pm
I HAVE A FRONT AND REAR DANA AXLES THAT I PULLED OFF OF A FORD TRUCK. THE QUESTION IS I WANT THEM SHORTENED TO FIT UNDER A CJ7 JEEP I KNOW THE HOUSING CAN BE SHORTENED, CAN THE AXLES BE SHORTENED TO OR DO I HAVE TO BUY NEW AXELES. COULD YOU SEND ME SOME ADVICE ON THIS PROJECT TO [email protected]
6:14 pm
6:52 pm
"wormdriller" wrote: I HAVE A FRONT AND REAR DANA AXLES THAT I PULLED OFF OF A FORD TRUCK. THE QUESTION IS I WANT THEM SHORTENED TO FIT UNDER A CJ7 JEEP I KNOW THE HOUSING CAN BE SHORTENED, CAN THE AXLES BE SHORTENED TO OR DO I HAVE TO BUY NEW AXELES. COULD YOU SEND ME SOME ADVICE ON THIS PROJECT TO [email protected]
I GUESS IT DEPENDS WHERE I GET THIS DONE AT CAN YOU GIVE ME SOME KIND OF IDEA HOW MUCH THIS WILL COST TO HAVE THE TUBES SHORTENED AND THE AXLES. I AM NEW TO THIS. ANY ADVICE WILL HELP ME
7:03 pm
8:09 pm
You are looking at about $200 to shorten the long side tube and have the C put back on. Axle shafts will be around $75.00 each to shorten and re-spline depending on material...These prices are on a bare housing and axles removed..If you bring them a complete axle and they have to take it apart to do the work, you can triple the prices.
"JohnDF" wrote: Rob has a pretty good idea of the prices on shortening an axle. I'll talk to him this afternoon.
Also, typing with all capitals on the internet is considered YELLING...
1:18 am
December 18, 2002
2:49 am
2:35 pm
January 12, 2007
I use http://www.kickassoffroad.com/ in Lincoln to re-spline axles. He charges about $100 a pair. Great service and turn around time but, it's a long drive to the boonies to get there.
4:32 pm
December 18, 2002
Is that 66cjdean off of pirate4x4? I had seen performancecryogenics.com before, but didn't know he did axle work too! Good to know, I'm looking at a D60 for my front end on my next project, but I'm probably going to need to have it retubed for a driver's side pumpkin 😉
5:12 pm
January 12, 2007
8:18 pm
You planning on staying with the 8 lug pattern? I would or you can factor in a lot more money for the conversion..I think 8 lug is the way to go, and if I hadn't had a ton of money into beadlocks I would have switched to 8 lug in a heart beat.
9:48 pm
December 18, 2002
"RobD" wrote: You planning on staying with the 8 lug pattern? I would or you can factor in a lot more money for the conversion..I think 8 lug is the way to go, and if I hadn't had a ton of money into beadlocks I would have switched to 8 lug in a heart beat.
Oh yeah, 8-lug for sure. My 5x5.5 stuff is all pretty much sold at this point. I've got 8 lug outters on the way for my D44 if I need to run it for a while. I've got a full float 8-lug 14 bolt that will be in the back and looking for a D60 for the front now. May end up ultimately switching to a 60 in the rear as well just for future gearing options, but the 14-bolt is hard to beat in terms of off the shelf strength and just cost.
