5.7 VVT Hemi Conversion for my JK|Page 2|General 4x4 Discussion|Forum|Gold Hills Posse 4x4
March 14, 2012
5:07 am
huck271
Granite Bay, CA
Forum Posts: 497
Tomorrow out with the old in with the new. The front bumper is off tomorrow we start taking the front apart and pull that V6!! I'me taking pictures as we go. Here is the new hood for a teaser.
72032=2950-Small_Hood.jpgImage Enlarger
March 14, 2012
6:08 am
Forum Posts: 3113
Nice!! beer
4:10 pm
Forum Posts: 7431
I've seen that hood before. What made you choose it over the AEV option?
7:53 pm
huck271
Granite Bay, CA
Forum Posts: 497
Couple of reasons..
1) In talking with others that own the two various hoods and BOR who has installed both with thier kit, the TMD hood actually draws air in to the engine via the working induction and funnels it to the air intake keeping it noticably cooler than the AEV hood which has vents that only allows hot air to rise out of the hood. The TMD hood allows hot air to rise out the side vents. BOR has done 500+ hemi installs and they said they won't even sale the AEV hood anymore. So i ordered it from them when I ordered the kit.
2) The AEV hood tends to gather water in the dip in the hood (several commented on frustration with this) and via the mesh in wet weather drips water all over the engine and in the engine compartments. If water comes up over the hood it is going into the engine compartment.
3) It is made of an extremely durable composite (not fiberglass) which resists dents & dings unlike the metal hood of the AEV. I plan to use the Jeep and wanted something strong.
4) It just looks cool and with the functional induction should push cold air toward my intake and provide more power...
the plan is for the hood to be black and the side vents and hood scoop to have a carbon fiber look it should look pretty sick!
4:58 am
huck271
Granite Bay, CA
Forum Posts: 497
Some more pics of the kit.
New Radiator
New Motor Mount
New ECU
72038=2951-IMAG0314.jpgImage Enlarger 72038=2952-IMAG0315.jpgImage Enlarger 72038=2953-IMAG0320.jpgImage Enlarger
March 15, 2012
5:03 am
huck271
Granite Bay, CA
Forum Posts: 497
Wiring Harness
Exhaust System
72039=2955-IMAG0317.jpgImage Enlarger 72039=2954-IMAG0318.jpgImage Enlarger
March 15, 2012
4:33 pm
Forum Posts: 7431
Where are the pics of your jeep? Isn't it apart now? Has the motor been removed?
When is the "delivery date" for this project? Isn't it a week or so?
GREAT Project!!!
6:17 pm
huck271
Granite Bay, CA
Forum Posts: 497
"BKGM Jeepers" wrote: Where are the pics of your jeep? Isn't it apart now? Has the motor been removed?
GREAT Project!!!
The front bumper is off it is coming apart today. Laid out the kit yesterday to see if we were missing anything. Had to order some new motor mounts the motor came with truck mounts but the kit needs the Cherokee version. I will do a complete write up of things needed outside the kit to detail " total" expense, so far little stuff ( like motor mounts, when the engine came with mounts) is adding up to a delay and a few hundred bucks..
Target completion is still early next week. Getting a little nervous with MOAB a little over two weeks away. I think we will be fine, but it's cutting it closer than I would like. So far all of Scott's estimates are on its the unforeseen that has caused delays.
7:02 pm
Forum Posts: 7431
I'm very interested in your final list of what's needed and the cost. I may be piece mealing something together.
I'm still trying to confirm I can buy just a motor and configure it to bolt to my 6-speed and rubi case.
Post more pics!!!
7:09 pm
Jason,
The most important detail you have left out is what the visiting hours are. Max number of persons per visit and duration.
I'm cereal, post up! grin
March 15, 2012
9:01 pm
huck271
Granite Bay, CA
Forum Posts: 497
"Wh1t3Nukle" wrote: Jason,
M-F 8-5:30p at Extreme Gear in Rancho Cordova
Should be ready early next week, provided there are no more hiccups.
2:27 am
huck271
Granite Bay, CA
Forum Posts: 497
What a day. I just came from the shop where lots is going on. With a little luck by the end of tomorrow there will be a hemi in that Jeep. Not done but a hemi sitting on the motor mounts with the transmission and transfercase all in place.
Here is what was done today pictures to follow. Front of the Jeep taken apart, removed PSC steering pump from 3.8 and installed on Hemi, removed air lines to make way for new Stainless Steel air lines for lockers, replaced valve body in transmission replaced exhaust manifolds, replaced wiring harness on Hemi with Kit Harness, removed skid plates, drive shafts, transfer case, & exhaust. I know I left some stuff out it a lot to see.
Plan for tomorrow pull v6, cut motor mounts, weld new mounts drop hemi. We will see how it goes.
Front Being Torn Apart- Air Conditioning Cooler Still in Place
Front After everything removed
On the lift, removing Rock Hard skid plates, Drive Shafts, Exhaust, Transfer Case and unbolting Trans from Crossmember and Loosing Motor Mount Bolts
72059=2958-Front_Gone.jpgImage Enlarger 72059=2957-Front_Gone_Radiator.jpgImage Enlarger 72059=2959-ON_THE_LIFT.jpgImage Enlarger
March 16, 2012
2:38 am
huck271
Granite Bay, CA
Forum Posts: 497
The transmission I picked up was a 2011 545RFE, aparently the transmission to have is a 2010 545RFE. The original transmission that was bolted to the motor was a 6 speed and none of the kits work with a 6 speed yet. The place I picked up the motor had a 545RFE from a 2011 with 20 miles on it so that is what they swapped my 2012 6 speed for. In order to get the 2011 to work like the 2010 the valve body needs to be replace. I saw this happen and it took about an hour start to finish was pretty straight forward, but I was glad the person doing it was a mopar mechanic who had done this before.
Original Transmission
Transmission Open with New Valve Body sitting on the counter
Transmission on Bench with Valve Body Removed
*** Big Tip Here - Order Valve Body and Mopar Parts from http://www.factorymoparparts.com The Valve Body was almost $200 cheaper than the dealer, every part we ordered was cheaper and they are factory OEM. *** Complete List of what I had to get on top of the complete motor to come once we quit buying stuff...:)
72061=2965-Trans_VB_Gone.jpgImage Enlarger 72061=2962-Transmission_Valve_Body.jpgImage Enlarger 72061=2960-Transmission_side.jpgImage Enlarger
March 16, 2012
2:52 am
Forum Posts: 7431
Looks great! Thanks for the update and pics!
3:16 am
huck271
Granite Bay, CA
Forum Posts: 497
To make the Truck motor ready for install we had to prep it and this is where having a 5.7L out of a cherokee would have been an advantage. Had to replace the wiring harness with the BOR wiring harness. Everything plugged in nicely and was labeled extremely well only one plug didn't match. So we had to cut one plug off the Truck harness to finish out the BOR harness. Next it was on to the steering pump. Have a PSC Hydralic steering system I have a PSC steering pump on my 3.8L motor that was removed and placed on the truck motor. It was not an exact match and we had to drill out the threads as the truck mount had bolts that went through the pump and screwed into the mounting plate and Jeep motor had a hollowed mounting plate and the bolts screwed into the pump. In any event a drill, drill bit and about 5 min and we had the PSC steering pump mounted like it was made for that Hemi. The truck exhaust manifolds shoot straight back and on the Jeep would point right at the fire wall. The cherokee manifolds angle down and therefore the truck ones had to go and the new cherokee version was installed. The throttle body points straight up on the truck motor and BOR kit comes with an adapter to point it toward the Jeep air box location. Lastly, the fuel filter on the truck points straight down and on lower lifter vehicles can come into contact with the control arms. A fuel filter adapter (cherokee) was used to angle this up and out of the way of harm. I guess its worth mentioning the motor mounts for the truck don't fit the BOR kit and Cherokee mounts had to be ordered. (I see why AEV recommends the Cherokee motor, sure hope those extra ponys are worth all this trouble)
PSC steering Pump vs. Hemi Steering Pump
Cherokee manifold vs. Truck manifold
Cherokee manifolds installed.
72065=2971-NEW_MANIFOLDS.jpgImage Enlarger 72065=2970-OLD_VS_NEW_Manifolds.jpgImage Enlarger 72065=2968-PSC_VS_Hemi_Steering.jpgImage Enlarger
March 16, 2012
5:25 am
Forum Posts: 3113
Very nice!! That's a lot of work. Are you working with Scott all week on it? So if I sneak down there, I'll see Huck in action? And what beverage do I bring Scott so he's okay with me standing around watching?
4:33 pm
huck271
Granite Bay, CA
Forum Posts: 497
I am up there till close today helping, no beverage needed, but call before come I may be hungry.. 🙂
March 16, 2012
6:20 pm
Forum Posts: 7431
This is a great thread.
If you had purchased an 11 motor/tranny/tcase, would the tranny be the correct one you ended up with?
I see that a GC was the ideal motor to get, but what about the Jeep Camander 5.7? Is that one ok as well?
What are you doing with your T-case? Your new one is a 2.72 to one kit and your Rubicon has a 4-1. What are you doing about your crawl ratio? are you re-using the Rubicon case?
Also, what company was your install kit again?
5:44 am
huck271
Granite Bay, CA
Forum Posts: 497
The tranny valve body would have to be replace on any 11 or 12 transmission only a 10 down works with the kits BOR, AEV, or JSS make. I reference the Cherokee but the Commander and the Charger use the same exhaust, fuel filter relocation and cherokee motor mounts
We are using the rubicon 4:1 transfer case it bolts right up to the truck transmission.
5:58 am
Forum Posts: 7431
Good news on the t-case. If I got a 10 motor, will it be vvt? Or is that 11 and up?
5:59 am
huck271
Granite Bay, CA
Forum Posts: 497
Today was a very productive day. We started the day with the V6 motor removed and hoped by the end of the day to have the Hemi sitting on the motor mounts. I spent the day at the shop helping out as I could and learning about the process. It was immensly beneficial to be there to see all the details that had to be tended to to make a hemi swap come together. We started the day by attaching the transmission to the motor so they could be dropped as a single unit. We also test fit the Rubicon transfer case to see if the wires from the harness would fit and working out where the fuel lines would run as the Jk motor has them on the passenger side and the Truck Hemi has them on the right. We installed the new Oil Dip Stick (not included with the transmission) and neatly zip-tied all the wires along the transmission and transfer case so they would be neat when in the vehicle. You want to do this before they are in as you have access when out. To prepare for the motor we had to cut off the factory motor mounts, install the BOR motor mounts (which required trimming because of my coil over shock towers) this includes welding. They were indexed to only fit one way. We had to install the new steering adapter that moves the steering shaft down and to the driver side more to allow more room for the motor to fit. We also had to take a BFH and beat the firewall back in specific areas to allow for better fitment of the hemi engine. While everything is apart it was a good time to rewire some of my switches to go through the firewall so when I install a cage down the road no wires are in the way. I know there is something I am forgetting as I upload pictures and video I will be sure to add more detail.
This is what we started with
This is the old exhaust (for sale in case your interested)
I also wanted to show a picture of the BOR air intake that points to the passenger side.
72090=2974-Air_intake.jpgImage Enlarger 72090=2972-No_motor.jpgImage Enlarger 72090=2973-old_exhaust_system.jpgImage Enlarger
March 17, 2012
6:07 am
Forum Posts: 7431
Exciting! And awesome pics too! Keep 'em coming.
I'm installing a long arm kit on a 2012 JKU tomorrow.
6:12 am
huck271
Granite Bay, CA
Forum Posts: 497
Burnsville Offroad had been very helpful everytime I have called. They need to improve thier Truck VVT Hemi instructions and they recognize that. I was told today that at Easter Jeep Safari Mopar is going to announce that this kit is available for sale through Mopar Performance at all Mopar Dealerships. I think that is saying something.
Here is a picture of the motor mated to the transmission.
Here is a picture of the wires to the transmission tied down to the transmission. There are ends that are not plugged in that go to O2 sensors. BTW You have to order 6-8 O2 sensors for install into the exhaust system unless you have the truck exhaust system to take the O2 sensors from ($35 a piece)
We had the battery tray powdercoated. I ordered a dual battery tray, the single was the only in stock. BOR sent me the single to get me to MOAB with a Double on the way at no additional charge. I will have to do another writeup on the dual battery setup when it comes in.
72092=2978-motor_mated_to_trans.jpgImage Enlarger 72092=2976-powdercoated_battery_Tray.jpgImage Enlarger 72092=2977-wires_tied_down.jpgImage Enlarger
March 17, 2012
6:19 am
huck271
Granite Bay, CA
Forum Posts: 497
To make room for that big Hemi we had to beat the firewall back about an inch on both sides. The instructions call for cutting the heat shield beating it back and placing a new heat shield on the body. We removed the heat shield beat the fire wall back and replace the heat shield intack. This made more sense to us. Also to make room we had to uninstall the steering rod and cut the opening wider than it is currently. Then use an adapter plate from the kit to shift that steering rod toward the tire and down away from the new Hemi.
Passenger Side Firewall Beat Back about an inch
Passenger Side Firewall Beat Back about an inch with the BFH that did it.
Pic of the Steering Rod Adapter. It barely clears the ARB air compressor mount I have but it does clear.
72093=2979-firewall_bent_back_left.jpgImage Enlarger 72093=2980-firewall_bent_back_left_hammer.jpgImage Enlarger 72093=2981-steering_relocation.jpgImage Enlarger
March 17, 2012
6:33 am
huck271
Granite Bay, CA
Forum Posts: 497
To install the motor mounts we had to cut out the factory motor mounts. We then had to prep the frame rail for a good weld. The BOR Motor Mounts are much larger than the JK mounts. They index off a hold cut in the frame and a tab on the mount that rests on top of the frame. We had to shave the tab down as it came in contact with my coilover towers. It was nice to weld these in as they had much more edge to weld to than the JK mounts. We cleaned everything for grease and then painted both the back of the coilover tower and the motor mounts with Black paint.
Here is the motor mounts welded in place
Here are the motor mounts painted black
Here is a picture of the Hemi Sitting on the motor mounts.
Challenges for today: When installing the motor mounts we called and were told the yellow stickers(UPS) go up and the "long" side is obvious. (one of the motor mounts is longer than the other) The issue is both motor mounts use the same bolt configuration so we actually put the mounts on the wrong sides and had to take them off and switch them with the motor simi-inplace. Also we found that the ARB compressor was in the way and uninstalled it to get the motor in place. The Alternator plug didn't match the harness so we had to cut off the Truck Harness plug and put it on the BOR harness to complete the harness install. Additionally the fuel lines on the JK are Passenger while the Truck connections are Driver and therefore we had to cut the JK lines and adapt them to fit the Driver side. The JK Transmission connection isn't a match for the Truck transmission shifter so it looks like that will be another misc part to be picked up. When picking up the motor we had to remove the air intake to find bolts to attach to. We will have to reinstall after it is in the truck.
What is left: Finish plumbing all hoses and fittings. Put front end together and install new radiator, new trans cooler, new pusher fan, and motor fan shroud (also powder coated) install battery box, connect transfer case, drive lines, weld transmission mount to cross member and install cross member, skid plates, fill all fluids, finish all wiring and take a test drive.
Our goal is Tuesday or Wednesday. That should give me a little over a week to drive the Jeep before going to MOAB.
Here is a 10 min video of when we were putting the motor in. Don't read much into it. The camera shut off before we were done. You don't get to see up remove the motor mounts and swich sides, or remove the ARB compressor. All you really see is us lower the motor and trying to get it to fit. Be warned there is strong language in this video it had been a long day.. 🙂 I think it would have gone smoother had we had the right motor mounts on the right side to begin with.
http://www.youtube.com/watch?v=VDzAzd0B ... tube_gdata
72094=2982-BOR_Motor_Mounts.jpgImage Enlarger 72094=2983-BOR_Motor_Mounts_painted.jpgImage Enlarger 72094=2984-Hemi_In.jpgImage Enlarger
Most Users Ever Online: 582
Guest(s) 11
Gregulator: 3113
Jeff_R: 2013
Gilbert & Betty: 1446
Members: 143
Topics: 4471
Upcoming: Guy and Lynda, Mike G, Robert & Amber
