Another advantage to higher-offset beadlocks
    #13 Sep 2013, 12:52 PM
    So I have some fairly large offset beadlocks. This means they stick out further than other wheels. I bought them for some obvious advantages like protecting my manual hubs, protecting my valve stems from rocks, widening my track to allow better stability with my lift, and offering greater steering before contacting my frame.
    Here is something I didn't know but did learn. With the wider offset on my raceline beadlocks, the gap between the inside of the beadlock threads and the rim spokes is about 1". This doesn't seem like much, but when you have a broken beadlock bolt, it makes a big difference. It used to take a bunch of time to easy out any broken ring bolts. But with these wheels, you just put a drillbit in to your drill and push the bit against the broken off bolt. It spins the bolt right through the face and out the back. literally 10 seconds per bolt! Plus no damage to any threads so the new bolt just threads right in.
    Super cool!
    #23 Sep 2013, 4:17 PM
  3. huck271 Subscriber
    #33 Sep 2013, 11:45 PM
    Have you broken many beadlock bolts?
    I've had my spyderlock beadlocks for over two years and have never broken a bolt. All my bolts are counter sunk into the ring. Do you have a pick of what you are talking about?
    #44 Sep 2013, 7:30 AM
    Broken 3 bolts. All my bolts are countersunk below the ring as well. I don't have any pictures. Two bolts were snapped off, so I re-torqued all all my bolts. I found another one broken when re-torquing all the rest. My Walker Evans beadlocks had the bolt head exposed on the lock rings, but I never broke any of those bolts, so I kind of expected all beadlocks to use similar quality bolts...
    #54 Sep 2013, 8:41 AM
    I have had mine about a year with no breaks either. Are you sure they are grade 8?
    #64 Sep 2013, 12:32 PM
    "Path 88" wrote: I have had mine about a year with no breaks either. Are you sure they are grade 8?
    Do they carry the markings of grade 8? Yes.
    Are they gold, rather than silver? Yes.
    Am I sure they are grade 8? No...
    #74 Sep 2013, 1:25 PM
    You're hardcore Brad. I've never broke a beadlock bolt in the 3 sets I've owned.
    #84 Sep 2013, 2:16 PM
    9 years on Walker Evans Beadlocks and I never broke a bolt. I had one fall out, and a couple heads strip, but they all replaced just fine.
    #94 Sep 2013, 6:50 PM
    Brad is not gentle on equipment!!! πŸ˜€
    #104 Sep 2013, 7:38 PM
    "Bender" wrote: Brad is not gentle on equipment!!! πŸ˜€
    Hi Keane! Long time no hear. How is your family? Work?
    #114 Sep 2013, 10:46 PM
    I've been looking at these. They have internal locks and a separate deflator valve. I'm not sure if the 3.5" backspacing will have them sticking out too far. Thoughts?
    http://www.badwheelsinc.com/Products_Wheels.htm
  12. BKGM Jeepers started this President Joined: June 2003
    #125 Sep 2013, 9:50 PM
    I run 3.5" backspacing with a 60 front end if you were wondering about width...
