7:57 pm
So I have a unlimite rubicon and I came across a hp44 and a 9 inch rear in a trade and I can't figure out what to do with them. I really want to put them in my jeep. What would you guys do? I'm at the point where I buy cromo shafts for my rubi axles or do I put money in these axles? I only plan to stay around 37-39 inch tires and I don't think I need a 60 but I would love a true hp44 with cromo shafts instead of my rubi axles.
I know a couple of you have swaped axles. Did you do it yourself? I was thinking of getting the brackets professionally welded and then just bolt them in myself. I can rebuild the axles no problem. I got a quote from a shop and they said to burn the brackets on and bolt them in it would be 3k. Thats with 20 hours of labor at $90 bucks and hour.
What would you guys do? Thanks
9:06 pm
January 12, 2007
9:18 pm
"finder_87" wrote: ...I don't think I need a 60...
Famous last words... 😈
"JohnDF" wrote: Swap...but shop around, that price seems pretty high.
x3. That price seems way out there, but maybe there's more work in the brackets than I realize.
Are you trading for a 9-inch or a 60? Either will treat you fine, I'm just confused.
9:23 pm
"finder_87" wrote: So I have a unlimite rubicon and I came across a hp44 and a 9 inch rear in a trade and I can't figure out what to do with them. I really want to put them in my jeep. What would you guys do? I'm at the point where I buy cromo shafts for my rubi axles or do I put money in these axles? I only plan to stay around 37-39 inch tires and I don't think I need a 60 but I would love a true hp44 with cromo shafts instead of my rubi axles.
SWAP axles and get a 60 in the rear. I thought the ratios for a 9" and a 44 can't be exactly matched?
I recall you could buy a new HP60 built , shipped to your door for less than 4K. Why the high work price?
4:28 am
I got the axles out of a trade. I'm not trading my axles for them. The shop said it would be $700 for brackets but then it was $400 to burn the brackets on and $1500 to bolt them in, and $300 for steering. I figured the price for brackets and steering but almost $2000 for labor!! I thought that was alot. I don't know it looks like I have to get dirty now.
So you guys wouldn't cut down the front d44 and run it with the rear d44? Even if I got 35 spline shafts for the rear? Is it housing thickness that is the concern?
Thanks for the help guys.
1:18 pm
January 12, 2007
"finder_87" wrote: I got the axles out of a trade. I'm not trading my axles for them. The shop said it would be $700 for brackets but then it was $400 to burn the brackets on and $1500 to bolt them in, and $300 for steering. I figured the price for brackets and steering but almost $2000 for labor!! I thought that was allot. I don't know it looks like I have to get dirty now.
Those prices are way too high! The brackets should be around $300 to $400 if you buy a kit, allot less if you piece one together. (I found I didn't use half the brackets in the kits).
I could see spending $300 on steering if that includes drilling and tapping the steering arms if you have flat top knuckles. And $400 to glue the brackets on! And $1500 to bolt them in! 😯 I would look for another shop.
"finder_87" wrote:
So you guys wouldn't cut down the front d44 and run it with the rear d44? Even if I got 35 spline shafts for the rear? Is it housing thickness that is the concern?Thanks for the help guys.
I am pretty happy with my cut down HP44 in the front, but I would recommend trussing the rear "Jeep" D44, if you are going to put any money into it. I dumped $1500 into mine (gears, ARB, Dutchman shafts) and ended up bending the housing, junking the whole thing, and building a D60 anyway.
1:38 pm
January 12, 2007
2:10 pm
"finder_87" wrote: The shop said it would be $700 for brackets but then it was $400 to burn the brackets on and $1500 to bolt them in, and $300 for steering. I figured the price for brackets and steering but almost $2000 for labor!!
Just out of curiosity, what shop are you talking to? I have a guess. 😀 It must be an extremely good shop to charge that much. Remember though extreme costs don't always equal extreme results when you get the gear offroad.
"finder_87" wrote: So you guys wouldn't cut down the front d44 and run it with the rear d44? Even if I got 35 spline shafts for the rear? Is it housing thickness that is the concern?
You could run it for a while and save some cash to do the rear. Just don't do what we all did and spend money getting by then realize that it's not where you want to be. Then you spend twice as much. Which brings me to another point. If you're going to run 39s you'll probably want to start thinking 60 front.
2:57 pm
"Bender" wrote: [quote="finder_87"]The shop said it would be $700 for brackets but then it was $400 to burn the brackets on and $1500 to bolt them in, and $300 for steering. I figured the price for brackets and steering but almost $2000 for labor!!
I was thinking he was making a mountain out of a foothill, but that's an extreme example. I'd call Grady's Hangtown Extreme on Placerville to get a second estimate. Seriously, I wonder who is coming up with that price.
3:05 pm
"BKGM Jeepers" wrote: I was thinking he was making a mountain out of a foothill, but that's an extreme example. I'd call Grady's Hangtown Extreme on Placerville to get a second estimate. Seriously, I wonder who is coming up with that price.
Finder, I'm not sure where you are, but WFO in Auburn did good axle work at a reasonable price for Larry and Predator Offroad in Auburn got my gears done on time at a good price. I'm not sure how complete their shop is though.
...or...
you could sell the Jeep and buy a Toyota and take it to Marlin Cralwer, the only shop that has gone above and beyond evertime I've dealt with them. 😀
3:44 pm
January 12, 2007
4:10 pm
"Bender" wrote: [quote="BKGM Jeepers"]I was thinking he was making a mountain out of a foothill, but that's an extreme example. I'd call Grady's Hangtown Extreme on Placerville to get a second estimate. Seriously, I wonder who is coming up with that price.
...or...
😀 x2
5:39 pm
"FAM" wrote: [quote="JohnDF"]W T Heck...my post dissapeared 👿
I haven't deleted any posts. It's possible you may have hit the "preview" button rather than the "submit" button. I've done that a couple times since we upgraded the forum software.
Wasn't me either. I randomly discovered the log this morning and just checked it. It doesn't show that any moderator deleted any posts.
7:30 pm
To suprise you all the quote was from WFO. I agree, I like that shop and i've had work done there before but I don't know if this was a miss quote or what. They gave me a print out. I'll see if I can post it. Extreme gear told me $700 to burn brackets on just the front axle. 😯 WFO was $185.
I don't think I need a 60 as I'm not super extreme but I want to run 38.5sx soon and thats what I had on my toyota before I turned to the dark (expensive) side. 😈
7:41 pm
Ok here is a copy and past. This is with me bringing in the axles rebuilt and ready to go. I guess swapping is just expensive for jeeps.
RE9968 TJ Front Axle Bracket Kit 1 409.99 409.99T
DISCOUNTS GI... DISCOUNT -15.00 -15.00
RE9969 TJ Axle Bracket KIt, Rear 1 367.99 367.99T
LABOR LABOR to weld front bracket kit on axle 1 185.00 185.00
LABOR LABOR to weld rear bracket kit on axle 1 185.00 185.00
ES2233LM 7/8-18L Tierod End (Tapered) 1 34.99 34.99T
ES2234R 7/8-18R Tierod End 2 33.99 67.98T
ES2027L 7/8-18L Double pivot Draglink End 1 30.99 30.99T
ES7818L 7/8-18 Lefthand Jam Nut 1 5.00 5.00T
PARTS New track-bar bracket to match flat draglink with
steering flip
1 19.99 19.99T
EXML10-12 3/4" x 5/8" Bore Male Heim Joint, LH, Radial Static
Load 16,565 lbs.
1 16.99 16.99T
WFO 1750-L 1 1/16" I.D. Tube Insert, 3/4-16 Left Hand Thread, 1.25"
Hex
1 11.99 11.99T
WFO 3416-L 3/4"-16 Jam Nut, Left Hand 1 2.00 2.00T
SG108 5/8 X .500 rod end spacer 2 4.99 9.98T
LABOR LABOR to shorten track bar to fit new bracket 90.00 90.00
WFO 1100 TJ/YJ Stock TJ/YJ pitman arm, Reamed for Large Chevy,
ES2026R/ES2027L (If you still have your stock one, we
can use that)
1 65.99 65.99T
EXP 220230 Steering stabilizer, 8", stem to stem, Pro-comp 1 39.99 39.99T
EXP 2525 Bracket for steering stabilizer with u-bolts 1 11.99 11.99T
WFO 5302 Mount Tab, Axle 1 3.50 3.50T
DAN2-94-28X 1310 1330 U-bolt kit 2 9.00 18.00T
LABOR LABOR to install front and rear axle, hook up steering,
modify front bracket kit to fit heavy duty steering in
stock knuckle location, tapered from top down. Try to
hook up e-brake cables
16 hours 90.00hr 1,440.00
total: $3,067.55
