Best Lift kit for a '97 Jeep Wrangler
    #113 Apr 2014, 11:12 AM
    We took some friends of ours out to Prairie City in their stock 1997 Jeep Wrangler. This was the first time they have EVER 4 wheeled, They had a blast out there. They both drove on the hills and trails out there. They drug the skid pan a couple times & the rocker. Each time the husband is saying see we need a lift kit. I think we got them a little bit “hooked” [https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_clap.gif] because the wife secretly asked Lori if we could check on a lift kit cost for her to buy as a surprise. What is the most “cost effective” lift kit out there? the most bang for the buck, not top of the line, just a kit to get them about 4″ with out breaking the bank and one that won’t break out there on the trail. Their just getting interested in wheeling so I don’t want to scare them with cost, but also don’t want to recommend junk either.
    #213 Apr 2014, 11:57 AM
    I'll let the TJ owners comment on actual kits but with 4" you'll likely need a SYE kit and CV driveshaft in the rear.
    #313 Apr 2014, 3:13 PM
    Correct Kevin, unless you use a tcase drop kit.
    A super lift short arm kit or pro comp base kit is most economical and not poor quality. I think you can run 3.5" and 33s. Probably the best bang for buck. Good luck.
    #413 Apr 2014, 11:29 PM
    Probably the most budget friendly method to get onto 33" tires is a 2" spacer lift, 1" body lift, and 1" motor mount lift. The 1" body lift is hardly noticeable on a TJ and totally safe, the motor mount lift helps with driveline angles and they may get away without a SYE, and the spacers are a cheap investment. If, or when, he goes bigger, you are only tossing the spacers and the body/motor lift can stay on the Jeep. No expensive parts to toss later when the "Jeep Bug" hits them. Nice cheap way to test the waters.
    #514 Apr 2014, 12:49 AM
    plus the spacers can be re-sold if/when they upgrade.
  6. Specialsoundman started this Member Joined: January 2013
    #615 Apr 2014, 5:00 AM
    I get the body & spring lift. I think I get the motor mount lift, does that raise the front of the motor to let the transfer case down so it is lower and less steeper angle for drivelines?
    #715 Apr 2014, 7:14 AM
    Yes, sort of. It raises the front of the transfer case so the rear drive line angle isn't as severe.
  8. Specialsoundman started this Member Joined: January 2013
    #815 Apr 2014, 8:59 AM
    By doing that won't it make the front driveline have a steeper angle? And that won't be a problem?
    #916 Apr 2014, 1:59 PM
    Front DL is much longer than the rear.
