Cherokee XJ build: TomD
May 15, 2012
3:00 pm
101sp_Permalink sp_Print
Get this thing done?!?!
Need to show the last fall shot of this thing on Strawberry compared to this spring! 😀
May 15, 2012
4:18 pm
Tom
Elk Grove, CA
Forum Posts: 1465
102sp_Permalink sp_Print
Carl, that's the plan. Here a few shots I took last night ...
73272=3069-IMG_0224.JPGImage Enlarger 73272=3071-IMG_0226.JPGImage Enlarger 73272=3070-IMG_0228.JPGImage Enlarger
May 15, 2012
4:22 pm
Tom
Elk Grove, CA
Forum Posts: 1465
103sp_Permalink sp_Print
Here is a detail shot on the spring shackle and shackle adjuster ...
73274=3072-IMG_0227.JPGImage Enlarger
May 17, 2012
9:11 pm
Tom
Elk Grove, CA
Forum Posts: 1465
104sp_Permalink sp_Print
Pulled the XJ out of the garage last night and drove it a bit before final torquing of all the nuts and bolts. After getting gear loaded, I may need to adjust the angle on the shackle mount. We'll see.
73320=3073-IMG_0229.JPGImage Enlarger 73320=3074-IMG_0231.JPGImage Enlarger 73320=3075-IMG_0232.JPGImage Enlarger
May 17, 2012
10:53 pm
Forum Posts: 3072
105sp_Permalink sp_Print
Looking good.
12:13 am
106sp_Permalink sp_Print
Sweet!
12:45 am
107sp_Permalink sp_Print
Looks good!
May 18, 2012
1:19 am
Josh
Forum Posts: 1630
108sp_Permalink sp_Print
Looking good Tom. It's newbie rubicon ready!
12:39 pm
Tom
Elk Grove, CA
Forum Posts: 1465
109sp_Permalink sp_Print
"Josh" wrote: Looking good Tom. It's newbie rubicon ready!
Joe had given the XJ a "once over" a few weeks ago and pronounced it "ready" ... now it's "readier".
June 29, 2012
1:27 pm
Tom
Elk Grove, CA
Forum Posts: 1465
110sp_Permalink sp_Print
Just a few quick updates:
(1) The creaking and loosening of my track bar was traced back to an installation mis-alignment that only manifested itself at full droop of the passenger side. I've been able to resolve that by just moving some alignment washers. YAY!
(2) With all the effort to box in, reinforce and support the front end of the XJ, the drag link and tie rod were looking really ... flimsy. So I saw our friends at 4 Wheel Parts and picked up the RE dropped pitman arm and Curry Correct Lynk Holy Moses that thing is HEAVY!
(3) Got some $$$ coming in so I'll be able to install my D44 rear axle and re-gear the D30.
The plan is to have all this installed by mid-July. WOOT!!
June 29, 2012
11:54 pm
111sp_Permalink sp_Print
Good things are happening.
2:55 pm
Tom
Elk Grove, CA
Forum Posts: 1465
112sp_Permalink sp_Print
After I removed the rear DS due to a U-joint failure it dawned on me, d'OH, the front and rear DS are the same length now that I have the SYE installed so I now have a rear DS. Too bad the front now needs replacing. But ...
It did clear the way for me to install the D44. What a difference disk brakes and 4.88 gears make! Now instead of being 20% overdrive (Indicated 55 was actually 66 and loosing 1st gear), the XJ is now 20% underdrive (indicated 66 is actually 55 with a 1st gear "granny").
Can hardly wait to get the front end re-geared, but that will need to wait just a bit. With the passing of both Ronie's mom and my mom we are holding onto our $$$ pretty tight for a bit. Need to make arrangements for my dad's care as he needs assistance with all his daily needs.
That said, there is a lot of "stuff" in my garage to keep me busy for the next few months on the XJ, my 10/22 and any other "honey-do"s that come down the pike.
September 5, 2012
4:45 pm
Forum Posts: 7064
113sp_Permalink sp_Print
"TomD" wrote: After I removed the rear DS due to a U-joint failure it dawned on me, d'OH, the front and rear DS are the same length now that I have the SYE installed so I now have a rear DS. Too bad the front now needs replacing. But ...
Sorry about your family challenges Tom. I hope everything gets worked out.
September 5, 2012
4:53 pm
Forum Posts: 3072
114sp_Permalink sp_Print
Sorry for your losses as well Tom. Let me know if I can help out anyway.
4:37 am
Tom
Elk Grove, CA
Forum Posts: 1465
115sp_Permalink sp_Print
Installed the Currie tie rod and drag link tonight then went for a spin. WOW! The is NO slack, wandering or noise from the front end. Talk about solid. I love it!!
September 11, 2012
5:00 am
Josh
Forum Posts: 1630
116sp_Permalink sp_Print
Congrats Tom! More strength up front. Very cool.
6:13 pm
Tom
Elk Grove, CA
Forum Posts: 1465
117sp_Permalink sp_Print
Dropped by 4 Wheel Parts yesterday. Brad had just left but did see Huck (met his son and dad!) who was doing some "white Jeep" purchasing for his family snow run.
Made the final arrangements to regear the D30 and get new shocks (Bilstien) so accommodate all the suspension modifications that have been done.
I'll take it in on 12/31 and get back by 1/5 ... JUST in time for the now run on 1/12. clap
YAY!! party
December 23, 2012
8:42 pm
118sp_Permalink sp_Print
Been a lot of blood sweat tears in this thing Tom! What an awesome job you've taken this build thru. Can't wait to see your beaming grin post regear! Your XJ is definitely one of the coolest ones.
December 23, 2012
9:41 pm
Tom
Elk Grove, CA
Forum Posts: 1465
119sp_Permalink sp_Print
"Wh1t3Nukle" wrote: Been a lot of blood sweat tears in this thing Tom! What an awesome job you've taken this build thru. Can't wait to see your beaming grin post regear! Your XJ is definitely one of the coolest ones.
Nice to get this BIG piece of the puzzle completed so we can go out and play again!
January 17, 2013
3:31 pm
Tom
Elk Grove, CA
Forum Posts: 1465
120sp_Permalink sp_Print
Alrighty ... the XJ is back and re-geared. I'm spending a little time doing short trips to break things in.
Had to get the CV joint on one driveshaft rebuilt as it was wobbled and pretty loose, so it was probably a good idea to have missed the Road Patrol on 1/12. Must have been some reason we were not to go on that run ... ah, well.
Waiting for the rear Bilsteins and all will be done for this round. Now to install the interior, sliders, and underbody protection and we'll be ready for summer.
January 18, 2013
2:20 pm
Specialsoundman
Sacramento, CA
Forum Posts: 901
121sp_Permalink sp_Print
You'll be able to do the Feb 2nd road patrol, yes?
January 18, 2013
2:51 pm
Tom
Elk Grove, CA
Forum Posts: 1465
122sp_Permalink sp_Print
That's the plan ... and the Feb 9th Chili Cookoff.
January 22, 2013
5:10 am
123sp_Permalink sp_Print
Big T,
You mentioned in David's thread about hitting up PC (both of you did) for testing out. If it helps any and you want another set of eyes, then let me know. Even if during the week since I'm located just (literally) down the block. 😀
January 22, 2013
4:07 pm
Tom
Elk Grove, CA
Forum Posts: 1465
124sp_Permalink sp_Print
"Wh1t3Nukle" wrote: Big T,
Down the block ... from me or PC? :dunno:
PM sent last night.
January 22, 2013
5:07 pm
125sp_Permalink sp_Print
Me being at Aerojet and PC is in my backyard. 😀
Roger that PM!
