I am planning an on board air system and wanted to know what some of your guys recommendations were, especially with the number of legit systems some of you guys had at the last couple of runs. I am currently running a portable Superflow MV50 (chinese? knockoff of previous gen Viair stuff) which appears to share cylinder and head designs/parts with the current 150psi harbor freight portable unit. Lasted for years (most in storage) but it is time for something a little more substantial. I am currently eyeing the Viair 450C with 100% duty cycle and lower flow rate with the 2.5 gallon tank and maybe another 1.5 gallons if I seal my bumpers. So...
-Describe your system
-What compressor (or compressors in at least one case)
-How may gallon tank
-How well does it work
-If you had to start over what would you do differently
-Any recommendations
I will go first:
-Describe your system Portable Compressor
-What compressor Superflow MV50
-How may gallon tank N/A
-How well does it work Good for what it is and damn good for a $50 compressor
-If you had to start over what would you do differently Worked fine with my 33s, skip if larger
-Any recommendations Don't let the thing get too hot, take a few minute break between tires
