in anticipation of 35s
i redid front ent
new upper and lower ball joints
new u joints
new tie rod end
installed a limited slip in the front
put the 35s on and got the wobble
did i miss something
going to get a trak bar bushing this morning (i think its the only thing not done)
all unit bearings checked and this jeep has spent the better part of the last 5 years sitting)
but has not had an issue running 31s or 33s
its a 2000 TJ
any ideas?
death wobble
JohnDF Member Joined: July 2003
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003As John suggests, or:
Bad track bar bushing.
Play in either the upper or lower track bar mounts
Play in the lower drag link bushing.
Improper drag link/track bar angle (both need to be close to parallel).Kathleen and Brad
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Also, control arm bushings/joints, pitman arm, tire balance, etc. But it is NEVER a steering stabilizer issue.
Did you balance the 35s?
Shocks are also a contributor if they have some healthy mileage on them.
Alignment? Toe-in can also be contributor seeing as how you replaced balljoints and tierods.
If there was no lift, then caster should not have changed, right?
Fred SubscriberFred SubscriberIt's all been said already, but I'd look at the track bar, toe-in and caster, in that order.
Tom SubscriberTom SubscriberAs we both have the same front end, remove the front DL at some point as well just to eliminate the possibility.
Also, as you might expect, DW is cumulative so any little bit in any or all of the afore mentioned possibilities can add up.
ordered trak bar bushing this morning
the lift is maybe 2 years old (3max)
this vehicle has been off road a handful of times
how do i check caster(is that the after market kit they installed to do allignment)
also this vehicle was pretty much a spare til last year so it did alot of just sitting
dont even think the kid started it til i went to get it
no issues with 31s or 33s
if i cant figure this out 4wheel said they go over for 95$(im thinkin this mite be worth while to do anyway)
they seem pretty good any down falls with using them has anybody had
Tom SubscriberTom SubscriberCheck this out. To adjust you lengthen or shorten the control arms.
https://www.google.com/search?hl=en&saf ... 417#miuv=0
Hope this helps.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 20124 wheel parts is great and a lot of guys use them. They practically built brads jeep. An alignment will help adjust the caster. Caster is hard to explain. I recommend googling it.
Fred SubscriberFred Subscriber"finder_87" wrote: 4 wheel parts is great and a lot of guys use them. They practically built brads jeep. An alignment will help adjust the caster. Caster is hard to explain. I recommend googling it.
You might check http://www.jeepforum.com/forum/f9/. Caster has been discussed quite a bit over there.- Guest former userGuest former user
im thinkin casrer now
read those and did some research
stuck my head out and watched driverside does the bad grocery cat wheel thing
is this fixed at an alignment shop?
does 4 wheel deal with alignment (ill ask wen i pick up trak bar bushing)
thanks guys something i wouldve never thought of
Fred SubscriberFred Subscriber"Rayzor" wrote: is this fixed at an alignment shop?
If you have adjustable control arms an alignment shop may make the adjustments. Best bet would be an alignment shop that has experience with lifted 4x4's though. I don't know if 4 Wheel Parts does alignments but if not they may be able to recommend a shop.- Guest former userGuest former user
I realize your going to hear just about everything that causes death wobble but positive caster has to be excessive like in the 9 to 10 degree range to even come close to causing death wobbles. That would mean the pinion would be probably pointing down hill. It is changed either with eccentric ball joints or if your control arms are adjustable it can be done with them. I would seriously look at tire balance and make sure everything on the front end is tight. Worst case you can add a steering stabilizer, it is a bit of a bandaid but quite a few 4x4's come with them stock. Mark
- RobD SubscriberRobD Subscriber
Have someone sit in the driver seat and turn the wheel back and forth with the engine off. You need to get under the front and look at every component of the steering, pitman arm, drag link, tie rod, track bar, etc. look for any movement at all. The slightest movement in any of these components can cause death.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"RobD" wrote: Have someone sit in the driver seat and turn the wheel back and forth with the engine off. You need to get under the front and look at every component of the steering, pitman arm, drag link, tie rod, track bar, etc. look for any movement at all. The slightest movement in any of these components can cause death.
This is how I figured out my last case of death wobble...Kathleen and Brad- Guest former userGuest former user
I have been fighting death wobble issues for a while and I believe this is absolutely the first step. I am not an expert but have learned a bunch in the process. The planman video below on this subject is a must see. I would comment that some times people mix death wobble with shimmies. Death wobble occurs when you are driving and hit a bump or pothole that induces the steering wheel to go back and forth, some times violently. If you get a "wobble" that occurs at various speeds, regardless of the road surface, this is likely a problem with tires or wheels.
My JK is doing much better with a better track bar and tie rod. I believe the last issue to address is a bad ball joint on the driver side.
http://www.youtube.com/watch?feature=pl ... QwlmlhiF4#! - Guest former userGuest former user
every thing is tight and most of it is replaced for 35s
however i toed out the drivers side tire about 1/2 inch and no wobble
i cant drive like that as i dont want to waste my tires
ill be picking up trak bar bushing after 10am
i dont know if its both tires as i dont want to take a chance of losing Kayla out the side (although somedays 🙄 )
but the driver side is like the grocery cart wobble big time
think wen i get a chance ill see how 4wheel is 1st hand
they said theyd inspect for 95$
