8:29 pm
The truck has a vibration that steadily seems to be getting worse. It happens consistently between 40 and 45 mph (41.2387 to be exact). It's in the actual body of the truck meaning I don't really feel it in the steering wheel but the body of the truck vibrates. I'm pretty well convinced that it's not the tires since it was there with the old tires but it is worse now. I'm pretty well convinced that it's not the lift since it was there before the lift - again, it's worse now.
Are the drivelines the next place to look? Worn out U-joints? When I crawl under there and wiggle the drivelines I don't really see any play in the u-joints. Should I just replace the u joints? I don't see anywhere on the drivelines that looks like a weight may be missing. I hate spending money to replace parts without something more than a hunch. I've though about setting up a camera under there so I can watch them to see if they vibrate but I'm not really sure how well that would work.
I know my brake rotors are warped since I feel that when I brake, is it possible that they are so warped they they act like an unbalanced tire? Seems like they would have to be in terrible shape for something like that.
What's next? Drive it until I can't bear it anymore and by then I should see something that obviously needs to be fixed? Don't drive at 41.2387 mph? Buy a new truck?
8:42 pm
9:28 pm
"finder_87" wrote: How about wheel bearings? Rear wheel bearings. How do you feel the vibration? Or do you here the vibration? Side note- can you here vibration or is that a rattle?
How do you test the bearings aside from pulling things apart? I don't think I really hear a vibration other than things rattling around in the cab but I'll listen more closely on the way home.
"FAM" wrote: Steering box play maybe? Years ago my Dad had a '76 Datsun pickup. It would get a vibration pretty regularly that felt like it came from the body. I'm pretty sure we adjusted the steering box when it would start up again.
Weird. I don't feel any play during normal steering but I'll see what I can wiggle around in that area.
11:27 pm
1:18 am
Try this site http://www.clubfrontier.org/forums/f8/v ... ndex2.html
Souded like your problem, maybe.
2:00 am
"rick-rock" wrote: Try this site http://www.clubfrontier.org/forums/f8/v ... ndex2.html
That's one of the reasons I was leaning toward u-joints. Just don't want to spend money on them when I can't feel anything wrong with them when I wiggle them. Maybe I'll pull the front driveline and see if it still vibrates.
2:43 am
4:05 am
5:45 am
5:42 pm
August 28, 2011
6:25 pm
"JohnDF" wrote: Gremlins
I'm pretty sure I've never fed them after midnight so I should be cool.
"kevheb" wrote: I hope it's not related to those weights we removed from the frame (per instructions) when installing the rocker rails. 😯
It was definitely there before the lift/sliders/bumper. Just not as bad. I had assumed it was the tires and didn't worry about it since I was getting new tires. Then it didn't get better. 🙁
"Rayzor" wrote:
make sure you undue one end before you check it
I tried to move it up and down but didn't undo one end. I figured I'd be able to feel it still attached...not true???
6:35 pm
August 28, 2011
if one end is going it will vibrate under load
you said it does it around 40 mph can u put that much torque with just your hands on it
i seperate at one end that way i can check each end unless its really bad the good end will hold it solid if its attached
and if its seperated you can usually tell which cups have lost the needle bearings
7:48 pm
8:56 pm
August 28, 2011
9:00 pm
"Rayzor" wrote: [quote="BKGM Jeepers"]I know what you're problem is, and the solution is simple! TOYOTA!!!
thats just mean
Thought about that. They're just so dang expensive. Even with this plus the money I've spent on the pile of other issues I couldn't have bought a similarly equipped Toyota. At some point it has got to stop though...
11:48 pm
5:58 am
6:07 pm
Anybody got an opinion on u joint brands? I doubt CTM makes one for my application and I can't imagine them being necessary. I just want something that will last. Spicer? Napa? Does it really matter? I've read the Nissan joints fail because they aren't greaseable and dry out so I figured I'd get some that are. Anything else matter?
Also...Fred...steering seems tight.
7:08 pm
3:47 am
So I swapped out all 4 joints today. I'd say it's 90% better but I also found a spot on the front driveline that clearly had a weight on it at one point. I figure I'll have it rebalanced and at that point I should be good.
I also dropped the gas tank and fixed the "fuel level sensor." Been a while since I had a gas gauge. 😀
