Differential build
February 8, 2010
7:22 am
troyman
Forum Posts: 404
For that kind of pricing, no way it came from any shop. That would all be the Busted Knuckle Fab Shop rates. I think what you're missing is that these guys are trying to save you a lot of wasted money, but then again - everyone has to learn...... I'd be happy to sell you a nicely built HP D30 for 4K, would give me the opportunity to build up a HP D30 and finish up my current HP D60 build. If you want, I can include the bent tubes, stretched inner C's, shaved ring gear teeth, super smooth axle shaft splines and specially modified U-joints all for the same low price!
February 8, 2010
6:14 pm
"troyman" wrote: I'd be happy to sell you a nicely built HP D30 for 4K, would give me the opportunity to build up a HP D30 and finish up my current HP D60 build. If you want, I can include the bent tubes, stretched inner C's, shaved ring gear teeth, super smooth axle shaft splines and specially modified U-joints all for the same low price!
I know you're trying to help but I'm curious, of those things or others what did you experience first hand with your D30 and what was your driving style when it happened?
My TJ is 10 years old now with 60K odometer miles and probably another 15K being flat towed. I know I don't drive mine like you or Rob drive yours, but the only thing I had happen was I lost a front ujoint on two separate situations and it took out the ears on the axle shafts. I did replace my D30 with a Rubicon D44 because I wanted an ARB locker and alloy axle shafts and it was minimally more expensive to replace the whole axle versus upgrading the D30.
February 8, 2010
11:25 pm
troyman
Forum Posts: 404
Gotta love that response, comes every time someone gives (good) advice to go to stronger components. The pictures and first hand experience never seem to matter. There's always going to be that guy out there who's been running Samurai axles under their 400HP/1000# torque diesel powered Suburban for 20 years pulling a 10 ton sled in competitions.
Tell ya what, I had a long response written out with why it should be upgraded, why I personally did, the benefits and everything. In the end - realized it doesn't matter, you're going to do whatever you decided from the get go, no matter if it's a good idea or not. You're going to get advice both good and bad, take whichever you want πŸ™„
February 9, 2010
12:30 am
Forum Posts: 7064
I think this thread is full of opinions. I ran a LP30 for about three years and never broke anything on rocks with 37" tires. I did break a u-joint and the axle ears on a snow run however.
I now run a fully built HP60, and have never broken anything, running both snow and rocks. I've owned the front axle for over three years.
February 9, 2010
12:55 am
Forum Posts: 3072
So how about maintenance? I have always wondered if a 60 would need less maintenance than a dana 30. Heavy duty axle in a light jeep? Any opinions?
1:12 am
It would depend on what set up you were running on a 60 or 30, but I would say not much maintenance on either one. Unit bearings wear out like wheel bearings. The fluid in both need to be changed, u-joints should be changed every so often due to fatigue....
"finder_87" wrote: So how about maintenance? I have always wondered if a 60 would need less maintenance than a dana 30. Heavy duty axle in a light jeep? Any opinions?
February 9, 2010
2:47 am
"BKGM Jeepers" wrote: I now run a fully built HP60, and have never broken anything, running both snow and rocks.
You sure about that...
lol
57454=2362-Broken001.jpgImage Enlarger
February 9, 2010
2:51 am
"Bender" wrote: [quote="BKGM Jeepers"]I now run a fully built HP60, and have never broken anything, running both snow and rocks.
lol
Inferior hubs.
2:52 am
"RobD" wrote: It would depend on what set up you were running on a 60 or 30, but I would say not much maintenance on either one. Unit bearings wear out like wheel bearings. The fluid in both need to be changed, u-joints should be changed every so often due to fatigue....
[quote="finder_87"]So how about maintenance? I have always wondered if a 60 would need less maintenance than a dana 30. Heavy duty axle in a light jeep? Any opinions?
I disagree. One of the main reasons I want to upgrade is maintenance. Strength wise I think the Toy front I've built is pretty solid, but, I'm freaking tired of rebuilding the thing. I drop $100+ and hours of labor a year into the darn thing in bearings, seals, knuckles, etc. I realize that a 60 would need to be rebuilt, but I think it would last longer than the few thousand miles a year that I drive.
February 9, 2010
2:53 am
"JohnDF" wrote: [quote="Bender"][quote="BKGM Jeepers"]I now run a fully built HP60, and have never broken anything, running both snow and rocks.
lol
Inferior hubs.
Come on...you're no fun...let me give him a hard time. πŸ˜€
February 9, 2010
3:05 am
I appreciate all the input and advise on my 30. With that said I give no argument that a 60 is stonger than a 30 and one can biuld the 60 for about the same price. I'm going to stick with my 30 ❗ Next ❓ Why? Because I want to see what I can do with it. Learning somethings for yourself is more fun than allways being led every step of the way. As far as money is concerned, I OWN a jeep not a geo metro. πŸ™„ Now for the next post: Pitman arm
February 9, 2010
7:30 am
Forum Posts: 7064
lol
OUCH!
CRAPPY Milemarker stuff! Changed to Warn and problem solved. Also, the guy I bought the axle from not only took the old hubs back, but gave me two sets of Warn hubs for free. Good customer service - from Ohio...
February 9, 2010
4:38 pm
troyman
Forum Posts: 404
So the moral of the post is:
"I'm going to spend a bunch of money on my D30 and looking for someone to agree with me in it being the right approach."
Just curious, you asked about whether or not to go to Extreme Gear and were told you'd get ripped off, and you went anyway. You asked if you should spend money on the D30 and were told it's a bad idea, but you're doing it anyway. Going to take a wild guess on the result of your Pitman Arm question.......
February 9, 2010
5:10 pm
Somebody pissed in Troy's Cheerio's lol
But seriously...I know Troy is just trying to help you save time, money, and frustration. We've all been down the same road, except for Lee who actually listened to us.
5:52 pm
Forum Posts: 7064
Whoa! Just becuase Rob is continually complaining about Extreme Gear, doesn't mean you get ripped off!
I have spent money there as well, and it IS expensive. However, his work is done correctly and there ARE things I am willing to pay for. Example: I went to a guy Rob suggested in forest hill to have my shocks outboarded. The work was under $200. The results were poor. All the geometry was screwed up, proper compression was not compensated for, one side bound under extension, etc. THEN, I went to exteme gear and had Scott fix the work I had paid for previously. I paid $600 for Scott's work. But low and behold, everything works correctly! The "non-rip off" work cost me $800 total, when I could have paid $600 and been only "ripped off".
Building a D30 is an experience many of us have gone through. If you choose to do it, good for you. the one downside is not having manual hubs. If you break, you're in a tough position. Also, the tallest gears you can run are 4.88's and they are cut thin to fit the housing, making them weaker than with a D44.
I have opinions as well, but understand that you chose your route and respect your decision. Most of this club ran a D30 for some period of time, including most trails around here. At least your work will be built correctly, regardless of price.
I look forward to seeing what you have had done.
February 9, 2010
7:18 pm
troyman
Forum Posts: 404
Sorry... back to minding my own business.... unsubscribed
February 9, 2010
7:25 pm
"troyman" wrote: Sorry... back to minding my own business.... unsubscribed
Now what fun would that be?
7:54 pm
Wow πŸ™„ So just because Scott told you the geometry was wrong you believe him 😯 He charged you $600.00 to use someone else’s product that cost him around $100.00 and $500 to install/weld it in, which took him probably less than 1 1/2 hours of time and labor!! That is about $200 an hour labor rate. No, he doesn't rip people off πŸ™„ Please explain to me how a shock binds under extension. This should be interesting!!!!
The non rip off work, Please!!! I run the same rip off out board shock set up on my jeep which works flawlessly, but I don't care if it looks pretty and doesn't have Scott's all mighty approval 😯
Since Scott is an experts on shock geometry, please fill everyone in on it so no one makes the same mistake that works for me!!!!
If you or anyone else wants to spend money at Extreme gear I really don’t care. It is your money and you need to do what you are comfortable with. I have my own opinion about them due to past history and seeing them rip off friends of mine.
Don’t just target me and my opinion of extreme gear. I was not the only one in this thread to warm against the use of them. You like them and are happy with them. That is fine, but you act as if your opinion about Extreme gear is the only one and those of us who were not happy with them don’t matter.
"BKGM Jeepers" wrote: Whoa! Just becuase Rob is continually complaining about Extreme Gear, doesn't mean you get ripped off!
February 9, 2010
8:16 pm
I want to throw my two cents in about Scott at Extreme Gear. Haven't had any work done there but I have bought a few parts from him. I looked up internet pricing prior to going over there. He gave me fair prices without shipping. I could have saved a little cash but I felt that in these poor economic times it would be better buy locally and help our neighbors. He's treated me fairly and hasn't steered me wrong.
I run a d30 and haven't had any problems with it. I would be lying if I said I prefer the 30 over a 60. When I grow up I will have 60s. I am tired of sitting at the kiddie table. πŸ˜› πŸ˜› πŸ˜›
February 9, 2010
10:04 pm
C'mon wheelin' season...we are getting stir crazy in here :soapbox:
11:25 pm
Sounds to me like he thinks he got ripped off...
"rick-rock" wrote: Update: I bow to you oh Masters of Wisdom. :badidea: The 30 biuld is done but not without estimate arguements,poor customer service and waaaay slow. rant
"JohnDF" wrote: C'mon wheelin' season...we are getting stir crazy in here :soapbox:
Nah...just a healthy discussion with some differences of opinion. Nothing wrong with that! Problem seems to come when folks get butt-hurt when their advice isn't taken as Gospel. πŸ˜€ You wheel a Toyota and you get over that quick. lol
February 10, 2010
12:26 am
Don't let mine and Brad's bantering discourage you. He and I are like and old married couple. We will never agree on everything, but we do on some things. If you are happy with building a HP Dana 30, then do it!!! Sometimes I forget that not everyone plans on doing the things I do with my Jeep. This thread got away from your post and seeking of advice on building your axle. This is a good club with good people and you can learn a lot from them, and there are a lot of guys here who have good mechanical knowledge that can help you do stuff to your Jeep to cut costs. "John being the exception mr-green "
I think back to building mine and it was a lot of fun and a headache at times too. Building, finding week links and upgrading is all part of the fun. Had I gone right to 60's and all the custom stuff I have now, I would not have learned half the things I know how to do today.
Build your axle, wheel the heck out of your Jeep and have fun!!! That is what it is all about..
No more bickering in this thread, I am calling a truce beer
"rick-rock" wrote: I appreciate all the input and advise on my 30. With that said I give no argument that a 60 is stonger than a 30 and one can biuld the 60 for about the same price. I'm going to stick with my 30 ❗ Next ❓ Why? Because I want to see what I can do with it. Learning somethings for yourself is more fun than allways being led every step of the way. As far as money is concerned, I OWN a jeep not a geo metro. πŸ™„ Now for the next post: Pitman arm
February 10, 2010
12:29 am
"RobD" wrote: there are a lot of guys here who have good mechanical knowledge that can help you do stuff to your Jeep to cut costs. "John being the exception mr-green "
Don't you start with me mister, you are just having Hammers withdrawls...I know I am 😑
1:30 am
Forum Posts: 7064
"RobD" wrote: Don't let mine and Brad's bantering discourage you. He and I are like and old married couple. We will never agree on everything, but we do on some things. If you are happy with building a HP Dana 30, then do it!!! Sometimes I forget that not everyone plans on doing the things I do with my Jeep. This thread got away from your post and seeking of advice on building your axle. This is a good club with good people and you can learn a lot from them, and there are a lot of guys here who have good mechanical knowledge that can help you do stuff to your Jeep to cut costs. "John being the exception mr-green "
I would have to agree here. Just because Rob and I disagree doesn't mean we don't care about the discussion going on. I don't hold a grudge.
February 10, 2010
4:58 am
:beer:
