Dodge Ram Question
July 17, 2012
4:24 am
BLTJeep
Forum Posts: 242
I know a couple of you have them, so I got a question about my wifey's truck...
98 Dodge Ram 1500 Quad Cab,
When under a light to heavy load, the AC flapper diverts air to the defroster vents, take foot off gas, hear flapper flap and air returns to blow out the proper vents. I googled this and found it may be a check valve under the hood. I found a tested it (blew through one way, but not the other). I am thinking a bad vac hose along that path. Just wondering if anyone had a similar issue and if you had a bad hose, which one???
Thanks,
Brian
July 17, 2012
4:44 am
I've not had this situation occur. I've only had the blend door broken fitting issue. It's where running AC its cold, then vacuum or momentum shifts the blend door and you get that lovely hot air.
Here are some links to topics that may be more related to yours, which sounds like the "wild vents" issue.
http://dodgeforum.com/forum/2nd-gen-ram ... ation.html
http://dodgeforum.com/forum/2nd-gen-ram ... issue.html
http://dodgeforum.com/forum/2nd-gen-ram ... vents.html
July 17, 2012
8:02 pm
BLTJeep
Forum Posts: 242
Thanks, The 3rd link had pics a few pages in and I think I found the 2nd Check Valve to test right off the Intake manifold... I hope it is bad, then I know it will fix it...
July 17, 2012
11:54 pm
On Carl's dash there was a build up of too much airconditioning and it blew-up. Which caused the big hole and all the cracks in the dash. wink
To much airconditioning in those dodges if you ask me. mr-green
July 18, 2012
2:25 pm
You can never have too much. Maybe I'll patch it up with your fender. Or Bill should. wink
July 18, 2012
8:59 pm
BLTJeep
Forum Posts: 242
Pulled the Check Valve right along the Intake Manifold and it IS BAD!!! Went to local Kragen / O'Really and they could not find it... Really??? Funny, I opened that same store 6 years ago, managed it for 2 years, and could find almost anything in the books. Went across the street to Reibies / Napa and talked to a Manager that has been there for the past 10+ years, she knew to just grab the book... don't even try the computer. Found something pretty darn close, 3/16" instead of 1/4". Hooked it up and it is much better, but I still have a slight leak with the 1/16" differance. I am going to wrap some black tape around the barb to build it up and clamp it down with a hose clamp to seal that bugger off. Just waiting for it to cool down a bit...
