What is funny is how they came up with the code.
LT is the type of tire ie LT Light Truck, P Passenger
285 is the width in millimeters from sidewall to sidewall
70 is the aspect ratio of ground to rim height of tire to width.
R is for the construction of the tire R Radial B Bias Ply
17 is the rim size
So to find the actual tire height you need to find out the tire height to the rim and double it, convert it to inches then add the rim size
(2 * (285 * .70))/25.4 + 17 = 32.7ish
Who said you wouldn't use algebra after high school. Only an engineer with too much time on his hands would use metric, inches and percentages in the code.
Luckily when you get larger tires most manufacturers know we aren't that smart so they put the rough size right on the tire. 🙂
