Got a line on a D44 Cherokee XJ rear axle ...
  1. Tom Subscriber
    #115 Dec 2011, 12:27 PM
    Gearing: 4.88
    Crown Vic rear disc brakes
    stock LSD
    raised shock mounts
    Ruffstuff Heavy duty 3/8" thick welded diff cover
    Re-built 4 years ago.
    $650 in Reno. Sounds like a no-brainer but want some input.
  2. Tom started this Subscriber
    #215 Dec 2011, 12:28 PM
    "TomD" wrote: Gearing: 4.88
    stock LSD
    raised shock mounts
    Oh, and being out of an XJ, all should bolt-in save the brake lines and cables. Might need to do something about the pinion yoke as well.
    #316 Dec 2011, 11:11 PM
    Do it Tom!! Like I said, I could probably pick it up for you.
  4. Tom started this Subscriber
    #417 Dec 2011, 8:22 AM
    I sent the seller a PM and am waiting for a response.
    #517 Dec 2011, 11:16 AM
    "TomD" wrote: [quote="TomD"]Gearing: 4.88
    stock LSD
    raised shock mounts
    Why would you have to change the yolk? Wouldn't it bolt right in? Just curious...
    That would be a great axle for your rig. Good Luck.
  6. Tom started this Subscriber
    #621 Dec 2011, 9:36 AM
    Spoke to the seller, really nice guy. Looks like we've struck the deal. As it is still in his XJ (he has the replacement) and the holidays are upon us, it'll likely be after the first of the year before the exchange actually takes place. So that will take care of one end! πŸ‘
    Now, about that HP30 in front ..... 🀷
    #721 Dec 2011, 9:39 AM
    "TomD" wrote: Spoke to the seller, really nice guy. Looks like we've struck the deal. As it is still in his XJ (he has the replacement) and the holidays are upon us, it'll likely be after the first of the year before the exchange actually takes place. So that will take care of one end! πŸ‘
    HP30's a readily available. You can grab one from a wrecker for about $150. Then, just build it to match the rear's ratio. I suggest selectable lockers. Saving for them is worth it!
  8. Tom started this Subscriber
    #821 Dec 2011, 9:52 AM
    "BKGM Jeepers" wrote: [quote="TomD"]Spoke to the seller, really nice guy. Looks like we've struck the deal. As it is still in his XJ (he has the replacement) and the holidays are upon us, it'll likely be after the first of the year before the exchange actually takes place. So that will take care of one end! πŸ‘
    Oh ... I have an HP30 in front! Just need to start planning what to do to it. Gearing as soon as the 44 goes in.
    Selectable locker for sure on both ends at some point. Would like to get something up front at the same time I re-gear.
    #921 Dec 2011, 11:40 AM
    Oh, you're right I forgot that XJ's came with the better D30.
    See what happens when I read while working?
  10. Tom started this Subscriber
    #1021 Dec 2011, 11:56 AM
    "BKGM Jeepers" wrote: Oh, you're right I forgot that XJ's came with the better D30.
    Well they did until 98 or 99 when they started getting the same LP30 as the TJs. Very popular swap is the HP30 into TJs.
    #1121 Dec 2011, 2:56 PM
    Dana 44's front and rear with crom-mo's and your ready to run up to 37" tires no prob.... My 2cents
  12. Tom started this Subscriber
    #1221 Dec 2011, 6:39 PM
    Well, I just sorta fell into the rear 44 ... maybe lightening will strike twice.
  13. Tom started this Subscriber
    #132 Jan 2012, 9:42 AM
    Will be "taking ownership" of the D44 sometime after January 7th. Thought I'd hold off on the install for a few weeks while I keep up my search for a front D44 so I don't run the risk of re-gearing and spending the money twice.
  14. Tom started this Subscriber
    #1411 Jan 2012, 6:40 AM
    Thought I'd close this thread with a quick note that the owner and I are meeting on Tuesday (1/17) to complete the deal. πŸ‘
    Now, if anyone knows of a D44 front that is available, keep me in mind.
    I won't be swapping the rear for a bit just to see what might shake out in the next month or 2.
    #1511 Jan 2012, 7:19 AM
    It's such a trick to get things timed right isn't it. The whole contortion act in order to streamline things. We can't close this thread! Not yet. πŸ˜€
  16. Tom started this Subscriber
    #1611 Jan 2012, 8:16 AM
    "Wh1t3Nukle" wrote: It's such a trick to get things timed right isn't it. The whole contortion act in order to streamline things. We can't close this thread! Not yet. πŸ˜€
    When it comes time to install the D44, I'll put it on my build thread though it should be pretty much a "bolt-in deal".
    The only questions might be (1) D44 yoke and (2) E-brake cable ... though it came out of an XJ so all might jut be a cake walk in those areas as well.
  17. Tom started this Subscriber
    #1717 Jan 2012, 10:01 AM
    Picked up the D44 this morning! 😁
    The guy did GREAT work and even threw in the E-brake cables, shims and axle brackets. Depending on finances, will install then re-gear front in February or March. πŸŽ‰
    #1817 Jan 2012, 10:19 AM
    Congrats on the new axle!!!!!
    #1917 Jan 2012, 1:08 PM
    Pics or it didn't happen 😁
    #2019 Jan 2012, 8:02 AM
    "TomD" wrote: Picked up the D44 this morning! 😁
    So you're also on the lookout for D44 front. Timeframe on that? Why, b/c who knows if there is some fortunate alignment of the moon, stars, comets for when my d44 front w/ 4.10s becomes available....
  21. Tom started this Subscriber
    #2119 Jan 2012, 12:40 PM
    "Wh1t3Nukle" wrote: [quote="TomD"]Picked up the D44 this morning! 😁
    If i'm not mistaken, the D44 on your rig has the pumpkin on the passenger side. Can you confirm this for me?
    For my XJ, the pumpkin needs to be on the driver side.
    #2219 Jan 2012, 12:53 PM
    Driver's side. Only thing I'm not sure if you'd need to be sensitive to is the unit hub bearing assembly. XJ being much lighter may not be an issue. I have no clue and I'm sure you veterans would know for this application. This D44 has extra flanging around the pumpkin, a feature of the Off Road Edition Ram. That's about it, but thought to mention it.
  23. Tom started this Subscriber
    #2319 Jan 2012, 1:26 PM
    "Wh1t3Nukle" wrote: Driver's side. Only thing I'm not sure if you'd need to be sensitive to is the unit hub bearing assembly. XJ being much lighter may not be an issue. I have no clue and I'm sure you veterans would know for this application. This D44 has extra flanging around the pumpkin, a feature of the Off Road Edition Ram. That's about it, but thought to mention it.
    Huh. I'll do a little more research to check this out. In the meantime, maybe someone will chime in who knows for sure.
    The only thing that comes to mind now is axle width and I'll see how that is dealt with. Maybe I'll just start a new thread so we don't get front and rear D44s mixed up.
