here we go again balljoints 3.0 hubs 4.0
March 6, 2015
7:43 pm
scoped
Forum Posts: 628
Ball joints and hubs again along with some evo c gussets.
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150306_193934.jpgImage Enlarger
March 6, 2015
8:27 pm
scoped
Forum Posts: 628
Add an axle u joint to the list
March 6, 2015
9:25 pm
Forum Posts: 7064
Wow! Good luck John! Hopefully the work goes smoothly.
I need to replace my ball joints as well.
March 7, 2015
12:18 am
k-jeep
Parts Unknown
Forum Posts: 2240
Cool! Lots of winter projects going on right now!
March 7, 2015
6:25 am
Good list of projects. You'll be ready for Spring.
9:47 pm
Forum Posts: 3072
What ball joints are you using this time?
11:06 pm
scoped
Forum Posts: 628
Because I'm poor the same alloy usa ones that I have for warranty because they started to have play after 3 months. I know it's just wishful thinking but maybe I just got a bad set
Next go around I'll probably try synergy if that doesn't work I'll have to spend 4-800 on some super "legit" ones and if those don't work I guess the only option is a 8k front axel
March 8, 2015
12:37 pm
scoped
Forum Posts: 628
Making progress
just have to fill in the back of the top gussets let it cool again and then press in the new joints.
My axel doesn't fit in my vice with spacers to pop out the u joint so I'm hoping I can use a floor jack and the frame of the Jeep to pop out and in the new u joint. We shall see how that goes
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150308_113119.jpgImage Enlarger
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150308_114048.jpgImage Enlarger
March 8, 2015
4:38 pm
Forum Posts: 3072
http://www.jkowners.com/forum/.....38;page=10
^ Checkout that build. Compares the dynatrac pro steers to the rare parts ball joints. Rare Parts are looking like a solid option.
4:54 pm
Forum Posts: 3072
Alloys and Synergy ball joints appear to come form the same manufacturer...at least, that's what my web wheeling skills tell me.
More on the rare parts ball joints: http://www.jkowners.com/forum/.....p?t=250361
7:14 pm
Forum Posts: 7064
So, how does this ball joint thing work?
Pop em out and pop in new ones?
I guess I need to learn!
March 8, 2015
10:04 pm
k-jeep
Parts Unknown
Forum Posts: 2240
I have a universal ball joint tool if either of you need to borrow it. Looks like a giant C-clamp.
March 9, 2015
12:08 pm
scoped
Forum Posts: 628
In simple yes pop in pop out but they can be pretty tuff. And on the jk 30/44s the upper C has a slight angle to it. Sometimes the tool lines up right and they pop right in and sometimes, 3 out of the 4 times I've done the tops, it takes 30 min to 1.5 hour and two people just to pop in the top with some washers or metal spacers to get it to line up strait. Luckily this time one popped in in 5 mins and the other only took about 30. I'm assuming axels with flatter shaped "[" type ends would be much easier
here's to hoping these don't show signs of failure in 3 months
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150309_115852.jpgImage Enlarger
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150309_115905.jpgImage Enlarger
If anyone wants to do balljoints I won't be happy about it but I will most certainly help - I could probably be classified ad a pro the amount of times I've done then on this platform.
March 9, 2015
12:38 pm
Forum Posts: 7064
I need to find out what ball joints I actually own, and then post here asking for suggested "premium" options. I am not concerned about price, so long as I don't need to do it again.
Thanks. I'll do some research and post back.
March 9, 2015
12:53 pm
Forum Posts: 3072
Glad you got them done.
Brad, how come you need ball joints already? I thought 60 ball joints where beefy!
2:42 pm
Forum Posts: 7064
Not sure. I'm following the alignment shops "to do" list. They said, basically, one joint needs replacement and one is loose but that 2 are fine. I questioned why I'd replace half and do the other half later. I'd rather fix everything right now, in one shot.
A complete set of splicer joints can be had for about 120 for my axle. A complete set of lifetime joints are 165. Both are cheap in my mind. However, the replacement is my concern. Is anyone using an air powered tool? Or, are both John and Kevin's the manual "screw" c-clamp type?
I think, a quality neumatic tool would make the process pretty easy. What are eveyone thoughts?
I think all I'd have to do is:
remove wheels
remove rotors and calipers
remove axle nut
remove unit bearing
remove outer C
do I need to even remove the shafts?
then press out ball joints, press in new ball joints, and reverse the process?
Does this sound correct?
March 9, 2015
3:21 pm
I've only replaced ball joints on my TJ Dana 30 / Rubi 44 axle so I'm not 100% sure about your axle. Based on my limited experience though, I don't see how you'd replace ball joints without pulling the axle shafts. The outer knuckle has to come off to do it.
March 9, 2015
4:52 pm
Forum Posts: 7064
Ok, thanks Fred. I guess it really doesn't matter. I'd just slide them out at that point.
March 9, 2015
9:57 pm
k-jeep
Parts Unknown
Forum Posts: 2240
Mine is the manual c-clamp style. I used it on my old YJ Dana 30. Don't remember if I used a breaker bar or impact wrench with it. think
March 9, 2015
10:13 pm
scoped
Forum Posts: 628
It's a manual big c clamp with a big screw you can use air impact on it just got to make sure everything is lined up and going in evenly ( if you screw up on install there is a good change you have ruined the balljoint or may have to ruin it to get it out to properly install it) - this is a job you would be able to do Brad its just kinda a P.I.T.A.
Well I got my project all done today. I ran into all sorts of stupid little issues that just multiplied the amount of time it took. Some threads were screwed up and I didn't have a big enough die so out came the diamond files and Castel nut to recut them, I was having a hell of a time with the brake calipers, and I finally decided to replace the abs sensors and that's way more of a pain than it needs to be.
Nice new u joint wish I had two and that they weren't so expensive!
http://i2.photobucket.com/albums/y43/24ounce/Mobile%20Uploads/20150309_150947.jpgImage Enlarger
March 10, 2015
6:55 am
Forum Posts: 3072
I'll call you when I need to do the job...
1:03 pm
k-jeep
Parts Unknown
Forum Posts: 2240
That sounds like all of my projects. rasta
