I figure you guys could help me out with being shafted. Hers is the skinny...
I have an unlimited rubicon on 37's. I have been running the stock shafts for too long. The rock god's have blessed me by keeping my shafts together. But it is time to upgrade and keep these as spares.
So what do you guys recommend?
Longfield's with a no questions asked lifetime warrenty= $810
Alloy shafts (ten factory) 10 year warrenty= $550
Superior discovery shafts warrenty?= $450
Yukon shafts= $400
I don't plan to run these axles forever but I have to make them work til the wife says I can swap. Hopefully 2 years. So what should I do buy the cheapest since I'll have spares? Buy longs and never look back? Buy two sets of yukons? Please help. I'm totally lost on what to do.
I Need to be Shafted!
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Um...what?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I've had GREAT luck with my Superior shafts. After talking to the guys at the plant, they are probably the only one's I'd concider. Throw in some CTM u-joints and you should be good.
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012Do you know the differnce between the discovery shafts and the evolution shafts? Besides $$
Being a Toyota guy I'm partial to the Longs. Great product, great service, great warranty, great guy. My guess would be that they have a good resale value so when you finally do upgrade you can get a chunk of that money back. If you go cheaper, at least make sure to get something with a good warranty. It would really suck to throw that much money away!
"JohnDF" wrote: I've had GREAT luck with my Superior shafts. After talking to the guys at the plant, they are probably the only one's I'd concider. Throw in some CTM u-joints and you should be good.
Just to confuse things...I also agree with John. He's not kind to his axle and it takes what he throws at it! - Guest former userGuest former user
Fred SubscriberFred SubscriberYou might try to get in touch with Lee (Super X). He may still have some alloy axle shafts he needs to sell. I believe they were Superiors.
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012If Lee still has some I would definitely be interested. Doesn't look like he has been on the board in a week or so. Did he upgrade his front end?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003The evo shafts are stronger and made to twist 180 degrees without breaking 😏
Lifetime warranty too...I used to wheel a lot. . .
Fred SubscriberFred Subscriber"finder_87" wrote: If Lee still has some I would definitely be interested. Doesn't look like he has been on the board in a week or so. Did he upgrade his front end?
You might try sending him a PM maybe he'll get the email notification.
When I talked to him it sounded like he had started acquiring parts to build up a Rubicon D44 front end but then he ended up buying another complete front end.
Fred SubscriberFred SubscriberI just called Lee to let him know about this topic.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Lee needs to use the internet more...it's a pain having to call him all the time 😂
Dan-H SubscriberDan-H Subscriber"FAM" wrote: I just called Lee to let him know about this topic.
Wow. white glove web-master service 🙂Closed Mondays.- Guest former userGuest former user
Hi guys, Yes I do know how to use a computer. Yes I still have the axles. Please call or Pm me.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"Super X" wrote: Yes I do know how to use a computer.
Okay, who taught Lee how to use his computer? 😂
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012Lee-pm coming your way. Thanks Fred
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012So one other question. Superiors do not warranty their shafts if there is a failure due to the u joint. But alloy has a no questions asked warranty. Superiors are made in the usa, alloys are not. If I bought longfields there is no u joint to worry about. superiors I would need ctms, ox joints or yukon joints.
I'm really liking the alloys for $500 with no questions asked 10 year warranty. Any thoughts?Um...what?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I just don't see how you can go wrong with Superiors and CTMs.
I've proven my D44 can hang with 37s at the Hammers, Little Sluice, and Fordyce for many years now.
But, it's your baby and you have to rock it. Ultimately it's your decision and your money.I used to wheel a lot. . .
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012No doubt in my mind its one of the best set ups. I just want don't want to buy 600-700 dollar shafts and then spend 500 bucks on joints. Why can't 4 wheeling be cheaper?? :rasta:
Thanks for your imput John 🍺Um...what?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I know what you mean...but rest assured you'll kick yourself even harder when you throw away that $1,000.00 when you upgrade to 60s. Now that's four wheeling 😂
Fred SubscriberFred SubscriberYou do have the factory D44 front axle don't you? Do you have a Warn hub conversion? Can he run CTM's if he doesn't have unlockable hubs?
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"FAM" wrote: Can he run CTM's if he doesn't have unlockable hubs?
I'm not sure...but hubs are a good idea with that setup anyways...the hubs become the "fuse".
Gregulator Member Joined: February 2012Gregulator started this Member Joined: February 2012I do not have the hub kit. But you can run ctms without it. Its just more wear on them.
Thanks For your help FAM. 🍺 I now have some cool torque wrenches. 😁Um...what?
