1:53 pm
January 27, 2011
So, I got the Toyos installed yesterday and they are set at 35psi, which is WAY too high I'm sure. What is a good starting point?
Figuring the XJ, loaded, will weigh in around 4000 lbs and the tire specs are 2270lbs @ 35ps, would a good starting pressure be ~29psi?
2:51 pm
3:15 pm
January 27, 2011
3:45 pm
If you are not sure here's the super technical method that I read about but it requires a very specialized tool.
Take a tire crayon (or whatever they are called) and mark a line across the treads.
Go for a drive.
If it is only worn in the middle, too much air. Let some out.
If the entire line is gone, just right.
That's off the top of my head. Correct me if I missed a step.
Or just start with 30 and see how it feels.
4:07 pm
11:48 pm
2:58 am
3:23 am
40 inch tires don't flex much until you get around 8 pounds or less. I wheel at 4 or 5 pounds
"BKGM Jeepers" wrote: [quote="Bender"][quote="RobD"]I run 18 in the rear and 22 in the front on the street.
Really? Wow...that sounds super sloppy?
Why's it sloppy? It rides on a trailer!
4:27 pm
Be nice now It only rides on the trailer about 50% of the time..It's half trailer queen :girly:
4:49 pm
9:04 pm
January 27, 2011
Ran around the Pismo Dunes this weekend at 6psi ... WHAT A FOOTPRINT! Unless I had to back up a dune, spent the whole time in 2WD.
Returned home Sunday with the tires at 29psi and still have not rubbed off the molding "hairs" on the outer edge of the tire's face. Dare I drop to 26psi?
1:30 pm
January 27, 2011
1:38 pm
January 27, 2011
7:51 pm
January 27, 2011
"RockinCrawler" wrote: http://www.jeepfan.com/tech/ti.....-chalk.php
I had seen that thread before. At this point, I still have the little "hairs" on the outer track.
