J-ust E-mpty E-very P-ocket
  1. huck271 Subscriber
    #125 Apr 2012, 2:19 PM
    You gotta pay to play the game but geeezzz..
    I took the beast in to have the diffs checked and change the fluid and inspect everything from the MOAB trip. I had a leak coming from the rear diff. The diagnosis was that something had gotten wedged in the pinion seal and that was causing the leak (new seal $$), with the diffs off we discovered that my rear ring gear had chipped a tooth and there were stress fractures on the adjacent teeth so that has to be replaced. Not sure what happened here, I did everything right.. Hopping at Prarie City -Check, Peeling out with the new Hemi-Check, over flexing in Moab and causing the rear driveshaft to touch the skid plates-check, I don't know what happened... :?: (New ring/pinion/bearrings $$$) The front looked good, just needed new fluid (diff service $$).
    I was hoping to get a roll cage this month, but I'll probably wait till next month assuming I don't break anything between now and then..
    #225 Apr 2012, 3:05 PM
    Yep...thats what comes with putting a V8 in a jeep... Time to upgrade to a 14bolt. dont forget to get spare driveshafts and u-joints.
    #325 Apr 2012, 7:57 PM
    "LJ3" wrote: Yep...thats what comes with putting a V8 in a jeep... Time to upgrade to a 14bolt. dont forget to get spare driveshafts and u-joints.
    x2 on the 14 bolt.
    #425 Apr 2012, 8:26 PM
    I've got spare ujoints, a drive shaft isn't a bad idea.
    #525 Apr 2012, 9:26 PM
    Rock jock makes a HP 70 with a full float option. That's what I'd consider.
    #626 Apr 2012, 5:26 AM
    What axles do you currently run? Sorry if I missed this. Mark
  7. Tom Subscriber
    #726 Apr 2012, 5:34 AM
    And it wasn't covered under warranty? What does Jeep think gets done to their rigs? Do they think we drive Pavement Princesses? ๐Ÿ˜
    #826 Apr 2012, 7:45 AM
    "BKGM Jeepers" wrote: Rock jock makes a HP 70 with a full float option. That's what I'd consider.
    This is actually a really great idea aswell... with the HP you wont have to worry about hanging your rear diff on every other rock like i do....Might be a little pricy though....
    #926 Apr 2012, 9:23 AM
    I haven't heard a price yet. I think it became available 3/1 from Currie. I'll ask next time I speak to my contact.
    #1026 Apr 2012, 12:03 PM
    Get a Super 35 kit ๐Ÿ˜
  11. Jeff- that guy with the foolsize Subscriber
    #1126 Apr 2012, 4:39 PM
    Running a hp any thing in the rear is not going to be as strong as a low pinion because you are then running on the coast side o the gears. It will cause increased deflection on the pinion gear and you will go through pinion bearings faster. That is why hp are in the front. You run the same problem with a low pinion in the front, it is on the coast side gears.
    #1226 Apr 2012, 5:50 PM
    Ya Huck, your axles are junk. You should just sell them to me.
    #1318 May 2012, 6:46 AM
    Yea, Sue found out real quick.
