JK steering
    #16 Mar 2012, 6:28 PM
    My friend Scott, who owns an 08 2dr jk came to work this morning telling me of a problem with his steering wheel. He told me he was wheeling down a dirt hill and that at the bottom he caught the drivers front tire in a deep rut. Violently pulling the wheel through his hands, almost laying the jeep on its side. I did not ask how fast he was going. The problem he showed me was that his steering wheel was upside down and he could still drive straight down the road. I myself don't know alot about jk jeeps but I would not think this was possible without major steering damage to any 4 wheeler. So I figured I'd ask. Is it possible? I looked under his jk (my first time under a jk) and didn't see anything amiss other than his pitman arm has a curve to it.
    His jeep sits on 35's and stock jk axles.
  2. huck271 Subscriber
    #26 Mar 2012, 8:13 PM
    Have you checked the alignment is everything tracking true or is one there toe out? If its tracking true, and he is lucky he just twisted the spring on the inside of the steering wheel. It has happened to me before. There is an internal "clock" spring that tells the system when the steering wheel in in the straight up/down orientation. It is possible for this to get twisted and not come back to its original state.
    It is also possible, but not likely that he stripped the steering box a few degrees and this is causing the wheel to be off. Neither situation is good, both you would want to have looked at as it will only be a matter of time when wheeling when he could lose control. The clock spring is cheaper than the steering box.
    #36 Mar 2012, 8:37 PM
    Thanks Huck.
    He's going to make an apointment in the morning with his jeep dealer.
    #46 Mar 2012, 9:11 PM
    Probably slightly bent his tie rod.
    #56 Mar 2012, 9:27 PM
    "JohnDF" wrote: Probably slightly bent his tie rod.
    But his steering wheel was completely upside down driving straight down the road.
    #66 Mar 2012, 9:36 PM
    "rick-rock" wrote: [quote="JohnDF"]Probably slightly bent his tie rod.
    Yup, I'd bet that something's bent. Check the tie rod, drag link, and track bar.
    #77 Mar 2012, 9:40 AM
    Bent pitman arm is another option as well to check out..
    #87 Mar 2012, 10:19 PM
    We left work late tonight again, so it was dark and could'nt see much. He's had most of the work done to his jeep at central 4 wheel and he has decided to take it there
    on Friday. I guess he has more mods on order and to install on Friday. I'll post once I here back from him what was wrong.
    #914 Mar 2012, 5:55 PM
    You were right John, he bent the drag link. 🍺
    He bent it out towards the front in a curve which made it harder to see in the dark. New ones on order.
