More Dodge fun
April 29, 2012
4:43 am
Forum Posts: 3072
So, do you recommend a 3 link for daily driving?
5:05 am
Yes, I think it is the best of both worlds. 3 connections to the frame, panhard bar for good steering with a stock box and very good caster and pinion angle retention. I do not daily drive mine as I don't have to, however I drive it to every trail within 2hrs Rubicon, Fordyce. Deer Valley, Barret, Slickrock and back at 65mph with bias 39.5 Iroks and it is very uneventful on the road. Mine is not perfect and I have learned a lot since building it 8 years ago, however it has been very reliable and works pretty good for a relatively low dollar rig. Mark
May 8, 2012
1:42 am
Forum Posts: 554
Working on making room for the coilovers. I have to move the fuse box over by the batterie.
73061=3061-ImageUploadedByTapatalk1336441335.075669.jpgImage Enlarger 73061=3062-ImageUploadedByTapatalk1336441348.574877.jpgImage Enlarger
May 9, 2012
5:41 am
Forum Posts: 554
Some frame work and plating.
73127=3066-ImageUploadedByTapatalk1336542070.667086.jpgImage Enlarger
May 9, 2012
6:40 am
Forum Posts: 3072
Looks good. :hack:
6:59 pm
Forum Posts: 554
Built a new crossmember and link mounts.
73640=3094-ImageUploadedByTapatalk1338317724.025430.jpgImage Enlarger 73640=3095-ImageUploadedByTapatalk1338317786.872294.jpgImage Enlarger
May 29, 2012
8:59 pm
Tom
Elk Grove, CA
Forum Posts: 1465
Very impressive. Lots of engineering, design and fabrication. Nice work!!
May 31, 2012
5:13 am
Jeff is kicking butt on this thing! I'm just the gopher and flap disker. I really like the clearance of the radius arms gained by doing the brackets on the cross member. True clearance test will be with the arrival of the 4-speed. 😀 I'm guess-ta-mating no clearance issues, but it's not like I've cycled suspension on a daily basis. 😯
I'm betting that his ride height will be in the 8" range.
So, in addition to that cross member, he was also able to get both lower links set and welded.
Good job dude!
June 1, 2012
1:50 am
Josh
Forum Posts: 1630
Nice fab work Jeff. Hope to see that big green rig on the trail again soon!
3:34 am
Forum Posts: 7064
Is it done yet? do we have an ETA?
June 1, 2012
5:58 am
Forum Posts: 3072
My guess he will be done on the 17th.
5:21 am
Forum Posts: 554
I should be done and testing it one week before the rubicon roundup. I need to work out the bugs 🙂
June 6, 2012
3:22 pm
Hey, what do you think about making your cross member bolted to the under side? Make some brackets and drill 'em out.
Box the inside of the frame, 1/4" plate and gusset to receive bolts, etc.??? This will provide more flexibility/access. Indeed would have to modify the tranny mount that is there already, but that's minor detail. 😀
June 6, 2012
6:32 pm
Forum Posts: 554
I thought about it but it's where my links hook up too so I am afraid of it moving to much.
June 6, 2012
8:59 pm
Forum Posts: 7064
"Path 88" wrote: I thought about it but it's where my links hook up too so I am afraid of it moving to much.
My front cross member is also where my lower control arms mount up. It is bolted and seems to work ok.
June 8, 2012
5:14 am
Forum Posts: 554
I will just weld it up. It does not need to come back out.
So up date. My atlas was delayed again. It will be arriving Friday the 22nd. I have asked for the shifters early so I can get to work installing them. And I have a hookup for a 4 speed for mock up. I will get my drive lines all done and belly pan so Friday I can swap it in and head out sat.
June 8, 2012
5:32 am
Forum Posts: 3072
Teaser pic
73864=3101-ImageUploadedByTapatalk1339133533.978401.jpgImage Enlarger
2:51 pm
Nom nom nom
July 7, 2012
4:15 am
Forum Posts: 554
I did some testing. I have a few little things that need work.
74527=3138-ImageUploadedByTapatalk1341634440.706306.jpgImage Enlarger 74527=3139-ImageUploadedByTapatalk1341634460.159696.jpgImage Enlarger 74527=3140-ImageUploadedByTapatalk1341634475.896279.jpgImage Enlarger
July 7, 2012
3:30 pm
Tom
Elk Grove, CA
Forum Posts: 1465
Man, that looks soooooooo COOL!
October 30, 2012
4:56 am
Forum Posts: 554
I got my new rims today. It took me about 4 hours to get them all mounted and torqued to spec. I am very happy with the set up. We will have to see how they are on the truck.
76172=3281-ImageUploadedByTapatalk1351572842.778115.jpgImage Enlarger 76172=3282-ImageUploadedByTapatalk1351572856.656145.jpgImage Enlarger 76172=3283-ImageUploadedByTapatalk1351572890.343649.jpgImage Enlarger
October 30, 2012
12:51 pm
Forum Posts: 3072
Mount them babies up!!
2:31 pm
Tom
Elk Grove, CA
Forum Posts: 1465
Man, those are BIG!
October 31, 2012
4:12 am
Josh
Forum Posts: 1630
Nice rims Jeff. What brand did you go with?
5:32 am
Forum Posts: 554
They are 40" toyos on 20" trailreadys
