So I have been keeping an eye on my front driveline because I know it has been hitting the exhaust cross pipe and I was just checking from the last run and it looks like the CV on the transfer case has started spraying grease out of it. It looks clean like it happened after the last run, but seems like it is time to replace it before it gets bad and fails on a trail. My rear is a double cardan, 1350, from Drive Line Services of Sacramento and I have been very happy with it. My initial thought is to just go back to them and have them build me another identical one for the front. So my question - Is there any reason I would want to go a different direction?
The main thing I see is that the rear they built me is not much different in tube diameter than the factory front, so assuming they don't change the tube size will it continue to interfere with the exhaust cross bar? With the double cardan it will push the joint further out from the transfer case which in theory will raise the contact point a bit and maybe it is enough. All thoughts and opinions are welcome!
