New Tires for the Samurai|Page 2|General 4x4 Discussion|Forum|Gold Hills Posse 4x4
August 17, 2020
3:17 pm
Gilbert & Betty
El Dorado Hills
Forum Posts: 1445
Have you took it for a spin? How do you like the new tires?
August 17, 2020
4:27 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Wider is more stable... cool
I agree so much John, I like stable. scared Running the spacers with the 1" offset wheels will put to much pressure on the wheel bearings. The solution is doing a axle swap with a Toyota truck. Going to start looking.
4:31 pm
Forum Posts: 7420
Have you considered the older Wagoneer axles?  The narrow track.  They are D44s front and rear and easily run 35s.  I had them for my samarai and paid like 300 total.  But they needed some work...
4:39 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Will take spacers off next week
Well it looks great, possibly even better with the spacers gone...hope everything clears.
Spacers are for sure going to come off. Have to get a 12mm x 1.25 die to clean off the red lock tight off of the stock lug bolts.
I Did the math thinkingand they should be good for clearance. thumbs-upIf not........ That's what the saws-all and wielder are for. weld
4:47 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Yes i did, around the neighborhood and out on the freeway. I like the smoother ride and they are quite. The balancing beads are working great, I did feel a little vibration at 65mph. Yes I did say 65mph.grin It was flat and a Long straight section. I'm thinking, down hill I might even get Samurai warp-drive, 70mph.
4:52 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
I have not, had not heard of doing that. The "standard" axle upgrade has been the Toyota. I would be interested to investigate that and what it entails. What years and are they easy to find?
10:01 am
Gilbert & Betty
El Dorado Hills
Forum Posts: 1445
did you calibrate
Did you calibrate your speedo? if not remember your going faster than it indicatesgrin
August 18, 2020
11:14 am
kris_olof
Forum Posts: 1218
  The 1974 to 1979 wagoneers with the quadratrac transfer case were 6x5.5 dana 44s with rear passenger offset units with about 60" WMS. Non-quadratrac were centered rears. Also 1970 and 71 CJs had offset 44s but with 5x5.5 bolt pattern and narrower at 50" WMS, skip the pre 1970 as they were 19spline.
As for how easy they are to find, not very.  I havent seen a waggy in a junk yard that wasnt missing its axles for over a decade.  Your best bet would be forums, craigslist, FB marketplace, or ebay.
August 18, 2020
4:14 pm
Forum Posts: 7420
On line junk yards.  I found mine in Oregon.  300 for the axles and 150 for freight to the Sac Forward Air Terminal.
10:07 am
Specialsoundman
Sacramento, CA
Forum Posts: 910
The 5x5.5 bolt pattern is perfect, just what I need. I would be able to use all the current rims and tires I have now. Kris it sounds like the 70-71 CJ axle would be a great upgrade. Would the offset be driver or passenger side?
This is the position of the Samurai diffs.  IMG_0720.jpgImage EnlargerIMG_0721.jpgImage Enlarger
The Samurai Axle is spring perch's are at 28" and front brake backing plate measures 48" looks like the face of the rotors are around 51".
The one main of advantage of the Toyota axle is that the diff/carrier will come out as a unit so can take to shop to be set up and not have to take complete axle assembly.
3:50 pm
kris_olof
Forum Posts: 1218
The 5×5.5 bolt pattern is perfect, just what I need. I would be able to use all the current rims and tires I have now. Kris it sounds like the 70-71 CJ axle would be a great upgrade. Would the offset be driver or passenger side?
I would figure out your front axle first since that is the more expensive one also the dangerous one to have spacers on.  As far as I know the only passenger drop 44 in any reasonable width (aka non-full width) and with a factory 5x5.5 is a scout front 44 which is approximately 60" WMS.  To pair that with a 50" WMS CJ rear axle would be odd to say the least and likely introduce some odd handling characteristics.  Swapping to 6 lug wheels would likely be the cheapest part of the axle swap so don't be afraid of it unless you love your wheels.
August 21, 2020
1:31 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Looking at all options. Will have to see the most effective swap. Toyota, Jeep or something else. When we get to that point. Might just build up the Samurai axles.
The reason I wanted to stay with 5 lug is being able to swap tires with Timothy’s Willy’s (For grins & giggles)
I’ve got 3 sets of tires on rims now. 31”, 34” and now 35”.
10:45 am
Specialsoundman
Sacramento, CA
Forum Posts: 910
Ok going to throw this out there.
I Just measured Timothy’s Dana 30 narrow track sitting in my garage. Hub Width, spring perches, and steering arms and diff alinement are exactly the same as the Samurai’s.
Also his rear Dana 44 is the same width, perches and diff off set.
And it’s a 5x5 1/2 lug pattern.
Is there a reason that those wouldn’t work? Another set of course.
12:07 pm
Newcastle, CA
Forum Posts: 1096
I'm nowhere near a pro but when I had my TJ there were runs I couldn't go on cause I had a Dana 30 and Kris one time told me about someone snapping a Dana 30 just on the street so I don't think that would be a good idea...
7:36 am
Forum Posts: 7420
Just an FYI.  The older D30 axles are not as strong as the TJ D30s.  I ran 37s with my built TJ D30 and 4.88 gears.  A properly build D30 off a TJ can be safely run, but I had an ARB and a host of upgrades.  You can't go taller than 4.88s on the axle however.  If you get a D30, get a HP axle and not a Low, as it runs on the stronger side of the RnP...
Also, your Sami may legitimately weigh half what my TJ weighs.  So, I don't know.  It may work with a selectable locker so long as you can get axle ratios to match front and rear.
8:11 am
kris_olof
Forum Posts: 1218
Few things to note. First, the low pinion 30 really isnt an upgrade over the Sami axle.  Yes you can upgrade to bigger u-joints and hubs but the low pinion becomes the weak link.  Second, this doesn't address your width issue.  With your wheels you need to be running wider axles to get out of needing wheel spacers up front, this is a safety issue.  Waggy and toyota axles are the common swaps for a number of reasons.  Mainly that the width is perfect for the 35" tire range, the axles can handle the abuse, and appropriate gear ratios are available.
As for getting upgraded axles onto 5x5.5 without doing custom axles, the easiest way I can see is to do a waggy axles and swap f150 hubs up front to get 5x5.5 and redrill the rear drums and shafts for 5x5.5.  If you don't want to re-drill the rear then from 1982 to 1986 they did make a few quadratrac CJ7s with an offset AMC 20 in 5x5.5.  I think the quadratrac AMC 20 is still a little narrower than the waggy front but should be close enough.
Other things to consider, while a quadratrac wide track AMC 20 will probably be free from anyone who has one, this axle has a big downside.  The lowest ratio currently available for the AMC20 is a 4.88 vs 5.38 on the dana 44s. (technically there are some lower gears for the dana 44 but the pinions get so small they are too weak to bother with)
I could see converting built waggy axles to 5x5.5 if you already have them for the "grins and giggles" or building custom axles as 5x5.5 for the purpose.  But Im not sure I see the benefit in your case.  If you want to swap parts with a CJ then build a CJ?
August 24, 2020
8:13 am
kris_olof
Forum Posts: 1218
That was the rear Dana 35 that snaps on the street, not the front Dana 30.
August 24, 2020
1:40 pm
Gilbert & Betty
El Dorado Hills
Forum Posts: 1445
With the Sammy not weighting as much as a tj and running your stock engine. I think 4.88 should be more than adequate for your 35's.  Also Dave I have a complete Fel Pro engine gasket set for you.  Call Betty or myself to make arraignments, Betty will be spending some time in Elk Grove over the next few days.
August 25, 2020
9:55 am
Specialsoundman
Sacramento, CA
Forum Posts: 910
Kris, so you know, The spacers are coming OFF that is why I ordered the custom built wheels. I Put the new tires on with spacers just to see what it would look like.
So the width was not the issue, at least in my calculations. We'll see in the real world after the spacer removal. In fact with the wider width, I would have to do some major fender mods. The rear axle strength is the current concern. Front is already beefed up, outside and inside.
The ONLY reason i would "upgrade" the axle tube is for strength. THANK YOU !! for all the great input from you guys about doing an axle swap/upgrade.
I have worked up a plan that I will do first that will allow me to keep the lighter weight Samurai axle tubes. There is "now" rear axles shafts that are extra super strong, with doing axle tube beefing up and bracing, I'm calculating that It will be great. If not, then I will have to do a swap.
I also like the removable pumpkin of the Samurai, Can take just that to the diff shop to be set up, slap it back in and go.
The rear axle is due for rebuilding anyway. Seal leaks, the ring & pinion is due to be replaced. The current ring & pinion sets has 310,000 miles on them. Obviously the rear. Front set was installed at the same. Front is good.
The gear ratio to be used is 4.57, (what I am running now) the goal is to also install a ARB locker at the same time.
5:59 pm
kris_olof
Forum Posts: 1218
Funnily enough, I bought a Dana 44 sight unseen this past weekend and looking at it now, it appears to be a very rare 73 wagoneer offset dana 44 which has 5x5.5 and 1-piece 30 spline shafts.  I will pull the shafts in a few weeks when I get time to verify what it is but unless I pick up a CJ with a Dana 20 it will be going up for sale.
September 11, 2020
12:04 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Well after the Prairie City Tire test, Had some rubbing issues. When The front compressed in a turn the Tire corner rubbed the body. IMG_0857.jpgImage EnlargerSo did a little mod and made clearance for the front tires. IMG_0865.jpgImage EnlargerIMG_0896.jpgImage EnlargerIMG_0895.jpgImage EnlargerIMG_0894.jpgImage Enlarger
Next will work on the back clearance. Rear-Tire-Clearance.jpgImage Enlarger
2:12 pm
Forum Posts: 7420
Nice
NICE!  What about simply adding a bumpstop in the rear right before body contact?
12:25 pm
Gilbert & Betty
El Dorado Hills
Forum Posts: 1445
it still looks very nice Dave
September 12, 2020
5:14 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Nice
I believe that when I trim the rock slider and the body there on the rear corners, that I will have the clearance so that a bumpstop won't be needed. But we'll see after the rear body trimming, will do another tire test at PC to see. Then if I do i can add it. If I don't then it's just a little more flex available. Also when I build the beefed axle I will put on saddles that move the axle back about 3/4"-1" that should center the tires right in the center of the fender hump.
What I do need to do is get stiffer shocks on the compression stroke to slow down the body roll on off camber drop offs.
5:19 pm
Specialsoundman
Sacramento, CA
Forum Posts: 910
Thanks Gil, It's always great when one can cut, pound, bend, wield on the body and it turns out good. I am fairly please with the way the front turned out looking. The test is...... will it rub? If it doesn't "then" I will be happy with this mod.
Most Users Ever Online: 472
Currently Online: k-jeep
Guest(s) 16
Gregulator: 3113
Jeff_R: 1991
Guy and Lynda: 1446
Gilbert & Betty: 1445
Members: 140
Topics: 4465
Upcoming: Darrell and Jill, Eric and Dawn
