Old vs New MTR's
  1. Fred Subscriber
    #125 Jun 2009, 5:06 PM
    I went by America's Tire today. They can't get any of the old style 35" MTR's any more. They'll replace my old MTR with the new kevlar MTR. I'm concerned about running the new tire with the old considering the size difference and my Detroit locker. They won't do anything for me to replace all the tires and suggest I call Goodyear.
    The guy looked up the specs of the old and new 35" MTR's and they're both spec'd at 34.8". Has anyone heard if the new 35's are really sized differently than the old ones? If so can you point me to any information I could use? I plan to call Goodyear in the morning to see if they'll do anything for me.
    #225 Jun 2009, 5:56 PM
    Rob has a picture. We put his old style 37" next to a new style 35" and they were almost the same size. I wouldn't run them together as I bet there is an inch difference. You'd be better able to tell us how much bigger they are. I'd be interested in seeing a picture if it's possible.
  3. Fred started this Subscriber
    #325 Jun 2009, 6:05 PM
    I wonder if new 33's would be closer to old 35's?
    #425 Jun 2009, 6:45 PM
    I have a VERY bald 37 I could loan you if you're in a pinch. I'd guess it's probably smaller than most 35s at this point. 😎
  5. Fred started this Subscriber
    #525 Jun 2009, 6:55 PM
    Joe told me he had a connection for some 35's with about the same amount of wear on mine. Maybe I should get my one new kevlar MT/R unmounted for the future and pick up one of the one's Joe knows of for now.
    #625 Jun 2009, 7:01 PM
    Or...go out and slash the other three tires 😏
  7. Fred started this Subscriber
    #725 Jun 2009, 7:13 PM
    "JohnDF" wrote: Or...go out and slash the other three tires 😏
    I thought about that. I could go out with reckless abandon with the intent to destroy all my tires. Or maybe I should set up an obstacle course in the garage. 😏
  8. RobD Subscriber
    #825 Jun 2009, 7:33 PM
    Have you called a Goodyear store to see if they can locate an old 35 MTR somewhere in the US at one of their stores?
  9. Fred started this Subscriber
    #925 Jun 2009, 7:36 PM
    "RobD" wrote: Have you called a Goodyear store to see if they can locate an old 35 MTR somewhere in the US at one of their stores?
    The guy at America's Tire tried to call but got a message saying to call between 8:00 and 5:00 eastern time. I plan to call them in the morning.
  10. Fred started this Subscriber
    #1026 Jun 2009, 5:40 AM
    I just got off the phone with Goodyear, they weren't very helpful either. All I got out of them was to not mix old & new MT/R's on the same axle.
    #1126 Jun 2009, 6:02 AM
    "FAM" wrote: not mix old & new MT/R's on the same axle.
    πŸ™„ at least you can take that to the tire shop. Maybe they'll replace the other side under warranty. Then you'd at least have two.
  12. Fred started this Subscriber
    #1226 Jun 2009, 6:45 AM
    I'm pretty much resigned to just getting the one tire and keep it as a spare.
    I guess this is another good reason to replace the Detroit locker.
    #1326 Jun 2009, 6:55 AM
    "FAM" wrote: I guess this is another good reason to replace the Detroit locker.
    You'd still need two tires. Just based on the descriptions that I've heard there's enough difference that it could change handling even on an open axle.
    #1426 Jun 2009, 7:00 AM
    No to mention when you throw it in 4WD. The transfer case might not like it when it's spinning a 33.5 inch tire in the front and a true 35 inch tire in the rear.
    #1526 Jun 2009, 7:01 AM
    Might be time to upgrade to some 37s πŸ˜€
    #1626 Jun 2009, 7:43 AM
    or 40's 😎
    #1726 Jun 2009, 7:55 AM
    He would need to intall a ladder for Teddi πŸ˜‚
  18. Fred started this Subscriber
    #1827 Jun 2009, 10:30 AM
    I ended up just getting one new kevlar MT/R to replace the punctured tire. I've got some measurements for you guys.
    Both the old and new MT/R's are 35x12.5x15's mounted on 15x8" rims with 29.5 psi. The old MT/R was measured by America's Tire as having 18/32" tread so its not worn much. I believe new it had 21/32". According to America's Tire both the old and new tires are spec'd at 34.8" tall when new.
    Height with no weight on it:
    Old tire: 34 1/4"
    New tire: 34 3/4"
    Height installed on right rear of my Jeep:
    Old tire: 33 1/2"
    New tire: 34 1/8"
    I suspect some of the difference in the loaded height could be because the new tire's sidewall has not been broken in.
    Laying on the garage floor the new tire is about 1/4" wider than the old tire at their widest points.
    #1927 Jun 2009, 8:12 PM
    I guess the 35s measure more true than the 37s.
    #2028 Jun 2009, 6:38 AM
    How does it feel when you drive it? Does the Detroit notice the difference?
  21. Fred started this Subscriber
    #2128 Jun 2009, 7:32 AM
    "Bender" wrote: How does it feel when you drive it? Does the Detroit notice the difference?
    I didn't drive with it. I just put it on to get measurements.
